Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
My honeywell ct87K thermostat will not turn the heater on
Simple gas warm air heater, the pilot is lit. two wires from wall for old thermostat. when I connect red to red and white to yellow the heater stays on. red to red, white to white (the correct connection) it does not turn on at all. thus, the thermostat and heater both do work.
  • Ron Bolander
    Ron Bolander Oct 22, 2013
    I have a replacement thermostat CT87K to replace the old round one.
  • Ron Bolander
    Sorry, it posted last entry before I wrote on. It is haviing the same problem as the original poster. 2 wires, white to white terminal and red to red terminal. the dip switches are both set OFF as the instructions for a gas wall heater. I have tried other configurations on the dip switch, but they didn't help, so I am back to the both OFF mode. Any help getting this wall heater to fire off would be appreciated.
  • Honeywell Expert
  • 252 Answers
On your thermostat - R is the power in terminal. Y is the cooling out. W is the heating out. (G is fan out). It does not matter which wire goes to R, the other should go to W - if no heat with a call, the thermostat is bad.
Posted on Apr 17, 2009
I have the same problem right now. There are only two wires (Red & White) and the white is going to the white terminal where the old one was located. Red is to(R) which I would think was red. Should I try the red one in another colored socket?
Posted on Oct 22, 2013
Need some help. I rebuilt my old wall heater and it won't turn on. New thermopile, pilot and gas valve. The pilot works, but burner won't ignite. New thermostat too.
turn thermostat to off position check wires from thermopile to stat and gas valve for damage etc . Thermopile has to warm up and make 600 mille volts to work . Try this then open stat and see if it fires up .
Dec 05, 2016 | Heating & Cooling
Have a ct87k. Got power at wall. Plug t-stat nothing.switches are both off for gas.
Those normally do not fail, they have a mercury switch in them. However there is a cravat they have to be mounted level and up side up. If that is the way it is mounted then just replace it.
Dec 19, 2014 | Honeywell Ct87k Round Heat Only Manual...
HOW TO TROUBLESHOOT ROBERTSHAW GAS VALVE
check the pressure switch if voltage to both sides its ok then check the gas valve to see if voltage at brown and yellow wires
Oct 14, 2014 | Honeywell Robertshaw Grayson Gas Valve Lp...
What should ther honeywell relay read in ohms on a r8222u 1006
did you check power to the gas valve? Pilot lit? Or electronic pilot on? Need more info on boiler.
Nov 05, 2011 | Honeywell Programmable Thermostat Heater
I have the honeywell round thermostat #, CT87K. I am trying to wire it up to controla gas fireplace. I have two wires coming from the fireplace I have tried every combination of wires. it will turn the...
That Thermostat will not work on a gas fireplace. The voltage is all wrong. You need a thermostat that will work on millivolts generated by the thermopile on the pilot assembly of the fireplace burner. It will only turn on, because you opened the circuit. It will not turn it off automatically or at all, for that matter.
Better yet, why don't you purchase a Wireless Remote Control that has a thermostat built-in. It's a multifunction remote that will work up to 25 feet from the fireplace and comes with a wall hanger. The SkyTech # 3301TH, should work well for you. http://www.skytechsystem.com/
Feb 17, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
How and where do I replace a thermocouple on a warm glo wall furnace? Help
There should be a thermocouple in front of the burners that has a copper colored wire that runs from the gas valve to the thermocouple. It is located in the pilot flame as it is a pilot proving switch that tells the gas valve the pilot is lit and its okay to open the gas valve to the main burner.
Mar 21, 2010 | Desa International Blower Glow Warm Wall...
Replaced mercury thermostat w/Honeywell CT87K - doesn't work!
You need a specific thermostat for a Wall Furnace it is a Millivolt Thermostat and not a 24v standard thermostat....usually it will work anyway however if the powerpile (generator produces millivolts from the pilot light) is weak it may not be producing enough...or the Pilot light may be dirty and lazy...won't produce enough millivolts ...or you can have bad or dirty contacts or connections....or a combination of any of the above.....a 24v Thermostat and particularly a non-mercury thermostat has too much resistance in it for a millivolt system....as your Wall Furnace (other than the fan) runs on less than 1 volt
Oct 31, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
I replaced my old mercury thermostat with a ct87k and it will not turn on. I have tried several so they surely are not defective. Hooked my old one back up and the furnace works. only 2 wire supply on a...
the two wires are hooked to the baseplate at the R terminal and the W terminal. there may be a switch somewhere on thermostat for electric or gas heat. make sure its in gas mode. make sure batteries are fresh and put in correctly in regards to polarity. make sure furnace is on when doing any settings with the thermostat. make sure themostat is set to "heat". make sure themostat is calling for heat (turn way up to be sure its doing that) . check the troubleshooting guide that came with the new thermostat.
Oct 27, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Cannot get new thermostat to work
didn't wire up correctly or if purchased a digital one didn't set up correctly, look at the instructions and should tell you how to set t-tstat up or if you have to remove or move jumper.
Apr 23, 2009 | Heating & Cooling
Heating & Cooling Logo
2,981 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
