Waher fills but doesn't continue cycle
My washer just finished filling however the cycle didn't continue. I have tried the electric supply and that is not the problem.
  • 686 Answers
TIMER MALFUNCTION
Posted on Apr 17, 2009
Water is filling tub after cycle is finished?
Probably bad electric valve for supply in the washer or control to it. If you unplug washer is it still filling? If so that confirms above. How old? Are you considering changing? If so ask cost to fix. You may want to "accelerate your buying decsion". For temporary solution you can turn off supply faucet. and back on when you want to wash.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Sears washer dryer commbo model 417.94712400 didn't stop filling with water and water went everywhere
Generally you could have two problems. Number one may be a sticking water solonoid that doesn't want to close after the fill cycle has stopped. Number two, if the machine has not started to agitate the clothes that means the timer has not reached that part of the cycle and is stuck in the fill mode. My guess is number two would be more likley, the timers **** out nowand then. Hope that helps
Sep 06, 2012 | Washing Machines
Washer turns on and stays filling water and does nothing else
If your machine fills but does not start the agitation cycle, the limit switch which detects that the lid is closed is probably defective. (Same as when the machine is washing, but you open the lid and it stops.) It's an inexpensive part to replace.
Aug 31, 2012 | General Electric Washing Machines
Water continues to fill after it should have
first does it over flow.if not pull your drain hose up from the drain till it is aleast the same level as the back of the waher control panel.
If the Drain hose is to far down in the pipe this will cause the water to drain out by gravity.the other least likely problem is a bad fill pressure switch.
Sep 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Waher takes 2 hours to fill on rinse cycle,fill up pretty quickly on wash but than on rinse takes 2 or more hours to fill
This is a cold water supply problem, obvious since cold water is what is used in the rinse cycle. Check the water inlet valve. Remove the supply hoses and check the small screens inside the valve. Make sure they are not clogged with rust or debris. The solenoids can be tested using a multimeter or ohmmeter. Test for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve will need replaced. I will attach a photo for reference. Hope this helped and best wishes.
Aug 13, 2009 | Washing Machines
Washer fill with water after the cycle is over
well ,either the machine wasnt finished (it may have been doing a second rinse and spin) or the electric valve not shuting. try let it fill and see what happens
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Maytag Neptune washer continues filling with water e
Does it fill when the machine is powered down?
If it does then the fill valve is stuck open and needs replacing
If it does not then you need to check the pressure switch and the air bell on the outer drum which probably has a ball of jellyfied soap in it.
If you take the back off you will see a thin plastic or rubber hose going from the bottom of the drum to a small flying saucer type object.
If you pull the hose off the bottom connection and blow into it you should hear a clicking noise from the pressure switch.
If it clicks then clean out the air bell and refit the hose .
If it does not click then get a new pressure switch
A repairman would test it live but that is not recommended for untrained people
Jun 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water Level and Water continues to drip after cycle has ended.
The water dripping into the tub is caused by the fill valve solenoid not closing completely. The fix is to replace the fill valve. The overfilling of the washer is caused by the pressure switch. Over time the diaphram within the pressure switch becomes fatiqued & fails. The fix for this is to replace it as well... Hope this helps... Bill
May 18, 2009 | Maytag MER5775Q Electric Kitchen Range
Washing machine will not spin
If this is a Whirlpool washer, you have a broken motor coupler
Jan 23, 2009 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
