Question about Hotpoint Aquarius WMA52 Front Load Washer
Aquarius 6kg wma52 blows main power breaker
Hi When the machine starts it will fill with water and then after about 1 or 2 mins the breaker trips on the circuit board any ideas.. its 2 years old
  • Anonymous Mar 12, 2014
    westinghouse lt819s keeps tripping circuit breaker leaking water
  • 209 Answers
Yes check for a heater element down to earth or at least a wire on the element off and touching the case, but i am confident its a heater element, rate me when you fix it, work with safety unplug when working on machines
Posted on Sep 16, 2007
Machine keeps tripping out when starting wash cycle - electrics have been checked by electrician - no problems- have managed to get it to spin but not to wash
Hi
The washing machine is obviously drawing too much current for the breaker to handle. This could be due to the washing machine drawing more that it should or because the breaker cannot handle the current the machine needs, coupled with the other machines on the ring main. If the fuse on the plug of the washing machine does not blow, then it could be that there are too many appliances on the ring main. The fuse on the machine may not blow however, if the breaker has a faster blow time than the fuse in the plug. Try plugging the washing machine into another ring main. Or try plugging out all the other appliances on the same ring main and test it out.
If the ELCB (Earth Leakage Circuit Breaker) is tripping only when the washing machine is running then something in the machine is faulty.
One common problem is the heating element. Over time they tend to crack and when the water gets in, the ELCB will trip out. This can be problematic to diagnose as offten the element will only trip after a period of heating. Bottom line, if it is tripping the ELCB then it is dangerous and should be fixed before any further use.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Creda W120VW Front Load Washer
New whirlpool wtw5100VQ, will not fill hot/warm water,
Remove lid and just check connectors on rear of inlet vaulves are not earthing. Hope this helps. Also to check it is not a faulty solonoid remove wires from 1 terminal and tape them up, then put machine onto hot fill, if this does not blow trip switch then solinoid most likely at fault. Please ensure you disconnect power before touching wires. Good luck hope this helps
Feb 12, 2010 | Washing Machines
Hi could anyone help me please..My Hotpoint WMA52 keeps flooding
It is not draining properly, or overfilling due faulty pressure switch.
Try cleaning the filter first.
Remove lower rear cover of washer.
Remove large black hose onto bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Hope this helps.
Dec 07, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Same problem
Power it off at the mains for 60 mins and then rety. If it still does the same then call in a repair man as it is most likely thatthe main controller board is faulty and needs replacing.
Sep 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Door will not lock
Sorry I think it needs a service call as the door control is controlled by the main board if not the part is the door lock.
Thanks J
Feb 17, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Help me
have you checked the drainage pump or filter to see if there is ablockage .
Dec 15, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint Aquarius 1000 WM62 motor problem?
hotpoint aquarius 1000 if motor is connected (plastic plug in socket) RCD earth trip trips in main board when washer is switched on, trips as soon as water starts to fill.
Oct 16, 2007 | Washing Machines
Hotpoint Aquarius WMA52 Front Load Washer Logo
137 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
