Question about Dacor ED24 Built-in Dishwasher
Why the dish washer said f6 floor guard - Dacor ED24 Built-in Dishwasher
    President:
  • 1,891 Answers
F6 is a fault code . this dishwsher is self diagnosing / inside the control panel you will find a tec sheet with a list of codes .. you will the know the failure . such as a float problem . no drain / no fill ect .. for more info i need to know model # hope this will help m.m
Posted on Nov 20, 2009
My kenmore precision quiet guard dish washer won't start. The lights come on like normal but nothing happens. Please help
manual / mechanical fault on main switch......repair or replace...........might be pushed in too far!
Jan 09, 2015 | Kenmore Dishwashers
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
I have a brand new washing machine that vibrates across the room on spin cycle. It is level and the load was checked for even distribution. Any ideas
Is the washer on a lino floor? If so you'll have to place some sort of stops on the floor to keep it in place .Unless of course the floor is unlevel and that would be another problem in itself. corner guards are a good bet for sliding problem
Feb 26, 2010 | Whirlpool Washing Machines
Kenmore Quiet Guard
You dont really need it, when the washer gets done Open the door for a minute and let the steam out and shut the door dishes will then dry. the reason there still wet is because of the steam from the Hot water
Sep 16, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
My dishwasher has water on the bottom that wont drain. I poured some Draino on the bottom but it didn't work. So I tried to run it (without dishes in it) and bubbles and water came out onto my kitchen...
**** out the water with a wet vacuum machine. Remove the sump guard and check with you fingers for any obstacles that prevent the draining. **** out the water and anything else from there. Put the guards back.
Sep 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore HE3,what F6 means
f6 is a communication error with the motor control board, i would unplug unit , remv eth bottom panel)3 screws across the botom of nit) andthe motor control board is rightthere on the left floor of the unit. check for good non corroded terminal connections, ive also seen extreme humidity/ water in surronding area trip this code
Jan 26, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Drain Clogged
you might try pouring liquid plummer in the drain part and jet it set it shouold eat through whatever is in there
Dec 26, 2008 | Dishwashers
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Dacor ED24 Built-in Dishwasher Logo
279 people viewed this question
Top Dacor Dishwashers Experts
Owen Barnes
Are you a Dacor Dishwasher Expert? Answer questions, earn points and help others
