Question about Minolta DiALTA Di620 All-In-One Laser Printer
DI620 C0920 code
Just moved this machine. Tested ok. Code came up 3 hours later. What does this mean?
  • Minolta Master
  • 6,161 Answers
! st draw lift motor failure
Posted on Nov 21, 2015
Code c-0540
Open the front door, up left small access cover remove, with machine on press small push button on the left side, to reset code, if the code comes back FUSER is bad (HOT PART) could be thermistor thermostat lamps BOARD!!!!
try this site for parts or something like it.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Nov 24, 2011 | Minolta DiALTA Di620 All-In-One Laser...
I have a Dialta Di-620 copier with an error code C-0540
i have a problem di620 code error c0540 please solve this thanks alote
Aug 23, 2011 | Minolta DiALTA Di620 All-In-One Laser...
Freelander td4 bmw engine will not start
fuel rail preasure rgulator valve may be faulty
Sep 12, 2009 | 2003 Land Rover Freelander
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error code C-14F2
Check the filter operation and harness and, if they are okay, change PWB-IB or PWB-IC meaning check the connections one board B is located under the scanner C is located behind the scanner, get tech to this is is going to get complex open close front door to reset.
Jul 11, 2008 | Minolta DiALTA Di620 All-In-One Laser...
Minolta Dialta620 copier error code c-0000
Code C0000 if a fuser motor failure.
Check to see if anything is damaged in the fuser (the thing that gets hot).
Also, check for a jammed transparency (if you use them).
Feb 10, 2008 | Minolta DiALTA Di620 All-In-One Laser...
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
Whirlpool duet washer problem
Our machine was giving the HF code at 37 min after over filling with water. I unplugged the machine, popped the top (took the 3 torx screws off the back) pulled the small hose off the pressure switch sensor (round sensor on the upper back right of the machine) and blew it out just by mouth. It obviously cleared some junk. It works fine now. (also unplugged the 6 wires on the sensor, turned it around and blew on that and heard it clicking, so I knew that was ok.) Hope this helps someone.
Oct 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
75 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
