Kenmore 80 Series washer wont spin or drain at end of cycle
I have a Kenmore Series 80 washer that fills fine and runs its course but when it approaches the spin cycle, it just turns off and the tub is full of water. Tried multiple spin options, all with same result
  • jrdy6 Apr 17, 2009
    Thanks for the updates. The model number is 11023822100. The tub is still full of water. Once it passes the rinse point on the dial, the machine just turns off. It does not reach spin. Makes me wonder if there is some sort of fuse.
  • ERIC BAKER May 11, 2010
    If you leave it on the spin cycle do'es it eventually drain the water out and end the wash cycle?
  • 686 Answers
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Posted on Apr 17, 2009
  • James Chandler Apr 18, 2009
    gravity drain it into a bucket by lowering the hose till it is empty enough to move out side so you can drain it the rest of the way and it sounds like a bad lid switch. drain it and change the lid switch then repost.
    to change the lid switch you have to remove the 2 screws on the front bottom of the control panel and slide it forward and lift it up . it's hinged in the back. then nudo your lid switch connector(the one that looks like it is going down through the top panel, then remove the two brass looking clips, then grasp the cabinet and pull it toward you till you can disengage the bottom from the base. now you can change the lid switch. re-assembly is in reverse and make sure bottom is locked in place before final setting of cabinet.
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Washer works fine until it starts filling on the rinse cycle, then the water just flows out of the drain. Last night the water was running for 3 hours, before I realized it. The tub fills fine when it is...
Make sure the drain hose is not sealed to the drain pipe, and that the hose is not shoved into the drain allowing the end of the hose to reach the trap. That will prevent the machine from syphoning out the rinse water as it fills.
Mar 29, 2011 | Washing Machines
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
624 people viewed this question
Top Washing Machines Experts
