Question about Dell W5300N Laser Printer
I have a Dell 5100cn. When sending a print job
I have a Dell 5100cn. When sending a print job for legal paper the display shows the following message:
Load MPF
Legal Plain 1
The MPF has letter, tray 1 legal. I have configured it every possible way. Dell replaced the tray three years ago, under warranty and it worked fine for a couple of years.
  • stannorris Apr 17, 2009
    Open up the printer in control panel and right click on the printer, property, click on the option tab. You will see some optional tray under "Items". If you click on it below you will see "change setting", select the Tray paper size on both the option 1 and 2 tray module, click apply or ok. Go back to the general tab and click on printing preferences, paper tray, under paper source select auto from the drop down list and click apply or ok. This will auto feed paper from the optional trays only not the MPF tray.
    From Dell settings
    The recommendation did not work. I want the MPF to automatically feed letter, and tray 1 to feed legal. When I send a legal print job I get the following message: Load MPF Legal Plain 1. Please try again.
    I have a Dell 5100 cn printer. I have it set up to print legal from tray 1, and letter from the MPF. When I now send a legal print job I get the following message; Load MPF Legal Plain 1. I have had this problem before when the printer was still under warranty, and Dell sent me a new tray. It worked fine for about two years, and has started acting up again. The printer has been configured every way I think it can be, but still does not work properly.
  • 854 Answers
Try this link below;
http://support.dell.com//support/topics/global.aspx/support/dsn/en/document?c=ag&dl=false&l=en&s=gen&docid=FE5FB4390ACBE2AFE030030ABD6242C0&doclang=en&cs=
You can also check the properties of your printer settings on the control panel;
Setting Printing Defaults
To set default properties for the printer, click the Printing Defaults button and choose options in the resulting Printing Defaults dialog box. For example, you might want to change the printer from printing in portrait orientation to printing in landscape orientation, or make it print in back-to-front order instead of in front-to-back order.
Device Settings Page Options
The Device Settings page of the Properties dialog box contains settings specific to your printer. For example, for many printers you can change the paper assigned to the paper trays or choose options for manual feed.
Hope this info can help resolved your printer issues.
Posted on Apr 17, 2009
  • Dell Master
  • 19,396 Answers
Try the following:
From Dell settings
When I go to print I get message load mpf 024-969
This error typically means that the Size of paper defined in the print job being sent from the application does not match the size of the paper the printer has set for the MPF. (in this printer, MPF = Manual Feed)
For example: If you send a Letter size job to the printer from, lets say MS-Word, but the printer currently has Legal size paper assigned in the MPF, this error will result.
Change the Windows printer to default settings
Apr 03, 2014 | Dell 3010cn Laser Printer
Error Message on Dell 5100cn
check the page setting in the printer as well as in the print dialog box in the, if the problem persists then you have to send it for servicing
Apr 29, 2008 | Dell 5100cn Laser Printer
Load legal message
You will need to go into the printer's settings and change the tray 2 paper size back to letter. This printer is an oldie and does not rely on the paper tray to tell it what size paper the tray contains. Another possibility is that If your program is sending a print job (which will over-ride the printers settings) that somehow is set up as legal, then you will need to either abort or cancel the print job on the printer or install a legal size piece of paper into tray #1 (the manual feed tray) and then press GO or CONTINUE on the printer to complete the print job!
Good Luck!
Rich Lilja
Oct 28, 2013 | HP LaserJet 4 plus Printer
I have a dell 5100 cn it keeps beeping to say load legal tray. everyone in the office can print find except one member when he prints we get the load legal tray beeping
this member needs correction of printer drivers options. Look for IT specialist for help. Maybe regional settings of operating system is not OK
pifonski
Feb 23, 2011 | Dell 5100cn Laser Printer
Legal size no print of hp Laser Jet 2420n printer
Hii It could be wrong on this but there should be a setting on the printer for paper size and type for tray 1. Use it to set tray 1 as legal size and then use your program to send to the printer. Another way would be to have no paper on tray 1 and send the job. The display on the printer should say to load legal on tray 1 and hit the button to continue. When you do the printer will now know it has legal paper in tray 1. The last method is only good for that job and will have to be done the same way for another job. Specifying tray 1 as legal paper will allow you to have legal paper in the tray when the job is sent and not have to press the button.
All the Best.....
Dec 11, 2010 | HP LaserJet 2420 Printer
Dell 5100cn
How do I remove a job history page from printing on a Dell 5100cn printer?
Aug 06, 2008 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Multipurpose Feed Problem
I had the same problem, my solution was:
1) Go into the Print dialog window, select your 5100cn printer and click the "Properties" button next to it.
2) Select the second tab, labeled "Paper Tray".
3) Select "MPF" from the "Paper Source" drop-down list.
4) Click the "MPF Settings" button and select "Envelope".
That should allow your program to print to MPF for envelopes. This needs to be done in your software, setting it on the printer's control panel didn't work for me.
Dec 17, 2007 | Dell 5100cn Laser Printer
Printing legal documents
Absolutely. Just click on the "PROPERTIES" button found on the "PRINT"menu. Find the "PAPER SOURCE" option, open it and select "Manual Paper Tray" or "Manual MPT". As soon as you confirm your print job, you unit will display a message asking for paper on the manual tray, which is the horizontal slot just above the paper tray. Insert each legal paper manually until your print job is done.
Oct 30, 2007 | Samsung SCX-4016 Laser Printer
you select the cassete of your printer it is saying to put paper by manual feed
Sep 11, 2007 | Dell 5100cn Laser Printer
Dell W5300N Laser Printer Logo
387 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
