Question about Toshiba Satellite Pro 4600 Notebook
SCREEN The screen is only half the full size. How can I fill the screen in it.s entirety. This a second user laptop.Any advise would be very useful.
  • davlong Sep 16, 2007
    MANY THANKS - PROBLEM SOLVED
    Scholar:
  • 84 Answers
Go to control panel Click on display Click on settings Slide the Screen resolution bar to 1024 X 768 Change the color quality to 32 bit Hope this helps you
Posted on Sep 16, 2007
SOURCE:
How do I enlarge the screen so it fills the page?
put ur cursors on the edges of the screen and then manual move edges using touchpad click and cursor movement.
Mar 17, 2015 | Apple Computers & Internet
How do I fix my Google screen? It only fills half the screen.
Are you talking about the window of the browser?
In which case you expand the window to full size, by pressing the square on the top right hand side, of the window border.
Feb 19, 2015 | Computers & Internet
My Acer aspire 15 laptop flagged up a messagesaying Your computer is low on resources and no new users can log on. Please use another account. When I clcked the OK the screen just shows blue and will not...
Your Hardrive is full. Full of stuff or a virus filled it.
Try to start on Safe mode: Press F5 and F8 simultanously during the first second of the boot. If it starts then go to your home folder and start deleting...
Nov 02, 2014 | Computers & Internet
My panasonic th-50pz800u will not display full screen?
The screen is probably adjusting to a particular aspect ratio. Not all images displayed will fill the screen. It is possible to modify the scrren size by using the FORMAT button ob the remote and choosing other aspect ratios or screen formats. Be advised that some of these may cause distortion of the image, so choose the one that provides optimal viewing and best screen coverage.
Aug 05, 2014 | Panasonic Viera TH-50PZ80U Plasma TV
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
I have an IBM ThinkPad running Windows 98 Second Edition used to program older radios so it needs the older version of Windows. The display power on showing IBM Thinkpad full size, but when windows or DOS...
I've seen this before, the main problem is that the resolution is set too low, so it only fills part of the screen.
two ways to solve it.
1. Adjust the resolution to the optimal setting so it fills the entire screen.
2. Find the Picture Scaling option and have it Scale the picture to the entire screen.
To adjust the resolution, now its been a long time since I used windows 98, but I think you got to it by going to your desktop with the background, right click anywhere on the empty space and select properties, now on the window that opens it was the last page, settings I think, you should get an representation of your screen with a resolution lever and color options, pull the resolution lever one point to the right and hit apply and ok, do this until the picture fills the entire screen.
If your laptop has internet connectivity, I could take a look at it over remote support and solve the problem for you.
Oct 23, 2011 | IBM ThinkPad 380 Z (2635HGU) PC Notebook
I cannot get my game to go to full screen with out it cutting it in half and looking like the whole screen has been painted 2 different shades of green
change screen size of your game settings.
just go to option and find screen size and change it into appropriate size.
thank you,
Mar 20, 2010 | Toshiba Satellite A135-S4527 Notebook
My dell laptop/windows xp now has a half-size, upside down screen
Hold down CTRL and ALT keys and press UP arrow to turn it back to normal. For the screen size, right click on an empty space on Desktop and select Properties then go to Settings tab. On screen resolution move the bar to adjust the screen size to your desired one.
Jul 12, 2009 | CMS 250GB HARDDRIVE 2.5 DELL INSPIRON 500...
Half moon cubes too large. Intermittent harvest.
Counter clockwise should decrease it. Just turn it 1/4 turn each time and check it after it makes another batch of ice. Then reread this post and do it again till it's the way you want it.
Jun 30, 2009 | Whirlpool EL05CCX 4.3 Cu. Ft. Compact...
To have a full size screen on my games
hi, sound like you have a wide screen and wish to fill the screen with the game. open your graphics properties and adjust the screen resulotion to the one size that looks like full screen,you will see examples as you change it. use the graphics software ati,nvidia. the easy way is right click on middle of screen, select properties-then resulotion- then good luck! hope this helps you.glen
Feb 18, 2009 | Acer Aspire 5500 5570-2609 Laptop
Toshiba Satellite Pro 4600 Notebook Logo
289 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
