Question about Frigidaire Refrigerators
MAKING ICE BUT ICE AND WATER DISPENSER QUIT WORKING.
FRIGIDAIRE GALLERY
MODEL #FRS22ZGEDO SER.#LA61416197
WHEN YOU PRESS GLASS AGAINST DISPENSING ARM NOTHING HAPPENS. I HAVE TO RETRIEVE ICE FROM THE STORAGE BIN BY HAND. WATER DISPENSER ALSO DOES NOT WORK. UNIT IS GOING ON ELEVEN YEARS OLD.
  • 744 Answers
Sounds like a plugged water filter, assuming the water is turned on to the fridge. If you have a manual, refer to the section about water filters. The filter is usually accessible from the front of the fridge at the bottom....requires about a 1/2 turn counter-clockwise. Some units require that the water be turned off first but not all.
If you do not hear a click when activating the dispenser, there could be an issue with the water solenoid (water valve) that opens and closes when you use the water dispenser....agai...check the manual if at all possible.
Posted on Apr 17, 2009
WATER FILTER WILL NOT ENGAGE
Hi friend, I appreciate your post!
I see your question is labeled under Frigidaire refrigerator, FGHB2844LF, and you are having difficulty engaging the water filter. Based off that model you should be able to push on the face of the water filter and slide the old cartridge out. First, to install the new cartridge you would need to remove the caps off of it. Secondly, using the alignment guide slide the new filter into the housing until it stops against the snap-in connector. Thirdly, push firmly until you hear the click which indicates that your filter has been engaged. Lastly press a glass against the water dispenser to verify no leaks are present at the filter housing. Hope this helps. -Matt
Aug 02, 2014 | Frigidaire Gallery FGHB2844LF 27.8 cu. ft....
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire side by side refrigerator model # LFUS2613LPO quit making ice or dispensing watr
Change the water filter and then purge the water into glasses or buckets for about a total of 3 minutes, then you should be fine. Otherwise, if you have problems after completing that, then you have a blockage or restriction in the water valve.
Jul 28, 2012 | Refrigerators
My 7-button Frigidaire Gallery ice/water module is not lighting up and not functioning. No ice or water is being dispensed. Wiring harnesses seem to be all intact.
Hi
If freezer door switch is not working, dispenser won't work. Does the freezer light go off & on when door is opened & closed? If you have a voltmeter, check that water valve is getting 120 volts when dispenser is pushed in. If no voltage, I would suspect the micro-switch that you hear clicking when you push in with a glass. Even though it clicks, the contacts could still be bad in it. However other than that loose/off wire, ribbon cable for front buttons off/loose, bad board, child lock are something that can make the dispenser dead.
Please check the bellow link if it helps:-
http://www.ehow.com/how_6494535_troubleshoot-frigidaire-icemaker.html
http://www.ehow.com/how_6557721_troubleshoot-frigidaire-refrigerator-icemakers.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 29, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water and ice not dispensing on Frigidaire side by side
We have a similar fridge were told that it has a resivoir inside that needs to fill with water before it will start to dispense water. Had to stand holding in the actuator for quite a while befrore it started putting out any water. Shoud be the same with the ice maker, but there is an arm inside the freezer that controls how much ice you get it could be turned off.
Jan 24, 2009 | Frigidaire FSC23F7D Side by Side...
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Psc23sgrd ss ice/water dispenser not working
It is possible. When you put hit your glass against the paddle to you hear the switch click? And can you still select between water, cubed, and crushed ice? Also does the light by your glass come on when you but your glass against the paddle?
When you put your glass on the paddle it pushes in a microswitch. That microswitch will power the light if it is working and also sends power to the board you are talking about to dispense ice or water depending on what you have selected.
Nov 03, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
218 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
