Question about Frigidaire FWTBB30DS Front Load Washer
Frigidaire FWT4496FS1 washer problem during rinsing cycle
I have the 1999 Frigidaire FWT4496FS1 washer and there have been problems during the rinsing cycle. Nothing happens during the washing cycle, but once it starts the high speed rinsing cycle, the chamber tub starts to girate with a disturbing cacophany, even when it is empty. Opening the back, I have confirmed that the motor and bell are fine. The pulleys are not loose. I tried to take the bell and the pulley out. But I still don't know what the problem is. What do you think the problem could be? What can I do? Is it worth fixing? If not, how much would it cost to ask a mechanic to check it out and fix it himself? Thanks.
  • 686 Answers
YOUR SHOCK ABSORBERS MAY BE WEAK OR BAD
Posted on Apr 17, 2009
Cold water will not fill tank at beginning of cycle, but cold water will come during rinse cycle...why
Thank you for your post, friend!
Based off the information you have provided I see that your Frigidaire washer will fill with cool water but not during the rinse cycle. A few possibilities that you could be seeing an issue with a faulty pressure switch or water valve. I would suggest seeking assistance from a professional for proper diagnosis and repair to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Oct 15, 2014 | Frigidaire Washing Machines
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Water not draining during rinse cycle
check the drive belt for the pump under the machine
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Timer Stalling
I would check the water hoses for twisting, make sure the water faucets are turned on all the way, and check the filters at the washer end of the hoses to make sure they are clean. I would also check the drain system to make sure it is clean and the machine is draining well.
Jul 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Frididair GLTF1670AS Front loader washer problem-water will not run in
IT could be the water heater element it would prevent it from moving to next cycle . Close Ireland bye bye
Nov 13, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire FWTBB30DS Front Load Washer Logo
292 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
