Question about Olympus FE-140 Digital Camera
Olympus FE-140 The hair-thin "eject" tab for the memory stick broke off the first time I tried using it! Now my camera says "card-cover open" and can't be used! Now what?
Just got an FE-140 off of ebay that looks like it had the same problem.  Somebody just opened the case and made a  solder bridge across the switch contacts.
Posted on Jan 26, 2008
Yes I had the same problem, however, where is says "push to eject," it means to push the the memory card down and it will eject. You pushed down the latch for the plastic door cover. Try pushing something into the hole so the camera thinks the door is closed. I am still having trouble with mine. Hope this helps alittle.
Posted on Dec 27, 2007
The cover on the battery and SD card opening on the camera broke off and couldn't be found on the ground. A small piece of cover and the hinge are still on the camera. When the camera is turned on a...
I imagine the only way to obtain a proper part is to send it to an approved Olympus service centre, hopefully under warranty (though I expect they would not regard this as covered).
The camera must have some way of telling that the door is open. Is there a tiny switch on the catch, or behind a little hole that something on the lid poked through? If so, perhaps you could jam it. Maybe there is a reed switch that was activated by a magnet in the lid.
I don't really see why this should be an issue for the camera to worry about, as long as things aren't falling out. My high-end Lumix pays no attention to hatches being open.
Nov 03, 2010 | Olympus FE-240 Digital Camera
Card cover open fe 280
You can fix it with a small piece of tape inside the unit where the memory card goes. Just look inside for a sensor or a small button, and try pressing it down yourself. If that works, then maybe a slip of tape over that spot would fool the camera into thinking the cover is closed. If this is not fixing your problem take your camera to Olympus as this problem involves some built in mechanism troubleshooting.
Thank you !!
Jun 18, 2010 | Olympus FE-280 Digital Camera
Fe 5020 digital camera plastic tab that holds battery in broke off and now receive an error message that the card cover is open
The base is working as a complete circuit when it is closed completely. Now as the plastic tab which holds battery is broken so the circuit is not getting completed and the software of your camera is not getting message that all parts are functioning accurately. You need that plastic tab or similar tab to fix this problem. Please show your camera in a repair shop and they will get it fixed at very low prize as they normally have such parts with them.
May 29, 2010 | Olympus FE-140 Digital Camera
Transfer internal memory to memory stick. Olympus camera
Place a memory stick in the camera. Next, go to MENU, then press BACKUP. This will save your internal images to media card.
Jan 11, 2010 | Olympus FE-280 Digital Camera
Probably not a fixable one, but here goes. I
Hopefully you know by now that the message wanted you to push on the card to eject it. The pictures you want to retrieve...are they on the card or the internal memory? You can easily download from the card using a simple card reader. If you've ruined the mother board circuit on the camera, then you probably can't retrieve the pics from the internal memory. In retrospect, you should never use the internal memory on a camera. It's too small to be of any use and it usually causes no end of troubles.
Dec 29, 2009 | Olympus FE-140 Digital Camera
Card cover wil not close
Unfortunately this is a repair issue with the camera. There is a sensor on that card cover door that may now be missing and needs to be replaced. You may want to call Olympus Customer Service to discuss their repair policies and procedures. Their telephone number is 800-622-6372 option 2 and then option 3
Jan 05, 2009 | Olympus FE-140 Digital Camera
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
Card cover open error, but I have pics on the camera!!
Look on ebay for a replacement door. shoundly be too expensive
Sep 25, 2007 | Olympus FE-130 Digital Camera
Card-Cover Open
YOU HAVE A BROKE SWITCH
THERE IS A VERY SMALL SWITCH BEHIDE A BATERY DOOR, JUST ABOVE A SIGN "PUSH TO EJECT" THIS SWITCH IS VERY SMALL AND YOU CAN NOT REPLACE SO WHAT YOU CAN DO IS, TAKE THE VERY SMALL SWITCH OFF (YOU WILL NEED TO USE A NAIL OR A NEEDLE TO REMOVE A SMALL PLASTIC SWITCH ) AND THEN STICK A SMALL PEACE OF METAL INSIDE OF THE HOLE (METAL TAPE WORKS GREAT) IT WILL BY PASS A SWITCH.
I USED TO BUY BAD CAMERAS ON EBAY FIX AND RESELL, ANY PROBLEM CONTACT ME KUNGLAO007@HOTMAIL.COM
TKX
Jan 05, 2007 | Olympus FE-140 Digital Camera
Olympus FE-140 Digital Camera Logo
275 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you an Olympus Camera Expert? Answer questions, earn points and help others
