Question about Maytag Neptune MDE7500AY Electric Dryer
Correctyly wiring power supply to Kenmore dryer
My friend tried to connect a power cord to a dryer he had in his house. When he plugged the cord in there was a loud pop and a spark. I noticed one of the wires was not connected. I need to know where the leads on the power cord should be connected in order for the dryer to be operational. The dryer is a Kenmore. The model number is 86673100.
  • Anonymous Nov 19, 2007
    changing the power cord from a 3 prong to 4 prong need to know where the 4 wires go
Need to know how to connect 4 wire power. There is a 3 wire cord connected now.
Posted on Oct 01, 2008
  • 625 Answers
A three wire pigtail is connected thusly. The two outer wires go to the two outer terminals on the dryer, the center lead goes to the center of the dryer terminal block. If its a four wire pigtail, the outer leads go to the two outer terminals on the dryer, the white goes to the center terminal. The jumper strap on the center is removed and the green goes to chassis ground.
Posted on Sep 17, 2007
SOURCE:
Started drying load, dryer shut off. won't turn on. checked door, changed thermal fuse, checked breaker. still doesn't work. light also not on.
If this is an electric dryer, you may have lost half of the power supply to it. Unplug and remove the little cover plate above where the power cord enters the dryer. Look at the 3 screws holding on the power cord for burned/black looking or loose connections. If nothing wrong there, shut off house breaker and remove cover on house plug where you plug the dryer into and look for same type of issues.
Mar 17, 2015 | Kenmore series 70 80 90 Dryer Motor...
Hoover 0910dryer not heating. element replaced not long ago
Hi, the possible causes are: Possible Causes: The wall receptacle, power cord (plug) and electrical supply must be in good condition and wired correctly for the dryer to heat.
  • Supply Issue - Loose or missing connection on supply wire from circuit breaker.
  • Plug Issue - Loose or missing connection in the wall. Defective, worn or damaged wall plug.
  • Cord Issue - Loose, missing or incorrect connection of the power cord to the dryer terminals.
If gas dryer and does not heat, Gas Dryer heats with a gas burner, make sure the gas supply line valve is open.
Also, for electric dryer,
Electric dryers require two 30 amp breakers or fuses in the house electrical box to run and heat. If one breaker is tripped or one fuse is blown, the motor, the timer and lights can work but the dryer will not heat.
May 01, 2010 | Washing Machines
I have an electric Kenmore dryer that wont turn on
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
Apr 16, 2010 | Kenmore Dryers
HE3t Kenmore dryer runs fine but suddenly stopped producing heat
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 31, 2009 | Kenmore Dryers
No heat gas kenmore gas dryer
Hi, I live in Argentina and I have a kenmore 96093800 Dryer. This Machine has 120/240v and his plug has 4 pins. Two pins are flat, one pin is cilindric, and the fourth pin is en angule. How can I connect...
Are you connecting this Dryer cord to the Dryer or are you looking for a wall plug with this same configuration to plug into. This is a standard double ground configuration and you can buy the wall receptacle at a hardware store. Your house should have 4 wires to this, 2 lines, a neutral, and a ground. As always the recommendation is that you have an electrician install your house receptacle. Your Dryer power cord is something you can install however. The two outside terminals on your dryer 240 volt wiring block are connected to the two outside wires on your power cord. It does not matter which wire goes to which side. Your two inside wires on the power cord are connected like this. One to the middle terminal on your 240 volt dryer terminal block and one is connected to the dryer case itself. Again it does not matter which wire goes to which ground. Make sure all of your connections are tight, as loose terminals eventually burn up. Do Not plug in your dryer power cord until everything is hooked up tight. I actually had a customer plug in his cord and then try to connect the wires to the dryer. The wires arced together and blew the terminals into molten metal which burned this customers hands and face. Do not do and electical repair unless you know what you are doing. On your cord the two straight terminals are line terminals, the round and L shaped terminals are grounds or neutrals. Good Luck, Appliance Specialists
Dec 15, 2009 | Washing Machines
Kenmore series 80 power cord melted
This is extremely distressing to me. If someone advised you to jump acoss (bypass) the thermal fuse on the dryer then I am in disagreement. My advise is to trip the breaker at the house power center, remove and replace the dryer main power cord, and replace the thermal fuse. Something is causing the dryer to pull more amperage than it should be, which is what resulted in the melted cord to begin with. You may want to contact a qualified appliance technician to assist in throughly checking the electrical system on the dryer. Until this condition is properly addressed there is a very real safety issue. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 27, 2009 | Kenmore 63942 Dryer
Dryer doesnt start, 600 series kenmore
Q - My dryer is dead, what could do that ?
A - Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first, then it is sometimes a good idea to replace the operating thermostat at the same time. This is a picture of -some- modern thermal fuses.
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with:
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Apr 01, 2009 | Kenmore 63942 Dryer
Dryer is not heating up
Hi there
I think that you are going to need a new heating coil, sorry . I would contact your local appliance dealer to see how much a new one would cost.
best regards mike
Mar 24, 2009 | Kenmore Elite HE4 Electric Dryer
Maytag Neptune MDE7500AY Electric Dryer Logo
1,805 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
