Question about Safety 1st Alpha Omega Elite 22456 TTN Convertible Car Seat
How do I rasie the back inside so the shoulder straps move up?
You squeeze the red handles at the top of the car seat and lift them up or push them down to whatever height you want. They're connected to a bar in the back of the car seat that moves out and goes in to slots.
Posted on Apr 29, 2009
What is the purpose of the shoulder straps?
The shoulder straps help you carry heavy loads more comfortably. They are designed to divide the weight load equally between your back and shoulder muscles.
Sep 06, 2012 | Burton Camping, Backpacking & Hiking
How do you move the straps for a bigger child
Hi
Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap.
Unhook the metal D ring.
Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height.
Re-attach the D ring. Adjust the harness straps accordingly.
Slide harness pad back up shoulder harness and re-attach popper.
Sep 11, 2011 | Quinny Buzz Three Wheel Stroller
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
The automated shoulder strap part of the driver side seat belt will not move to position over the shoulder
pull the strap out till it stops it probably just has a twist in it tightening the retractor
Jan 03, 2011 | 1989 Toyota Camry
Please can you tell me how to alter the shoulder straps. I would like to move the straps up to the centre position on the back of the child seat. Can you help?
open the little door behind the seat back, unhook teh straps from teh metal holder. Pull one side out completely from the back of teh chair and the shoulder pad.
Thread the free pad into the back of teh seat then out to teh front on teh other side,
Reverse the above but at the height you want
takes about 3 minutes
Nov 09, 2009 | Maxi-Cosi Priori
How do I put back together the straps on my car seat
would assume you're talking like a booster seat with the back just no 5pt harness. You just buckle them up like you do. If they have those arm rest looking things, the part where it buckels goes under that one arm rest and the shoulder strap should go resting over his shoulder like yours. Some of them have a loop up top for the shoulder strap to go through. Just make sure that the toddler does NOT put their arm over the shoulder part of the belt. If you get into an accident this could break his/her ribs.
Apr 20, 2009 | Britax Eclipse Si - Paris Convertible Car...
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
Shoulder restraint adjustment
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
Jul 31, 2007 | Evenflo Embrace - Rainforest
Shoulder straps
You can contact EvenFlo directly, they will be happy to help you out: http://www.evenflo.com/ Evenflo ParentLink Department: 1-800-233-5921
Mar 31, 2007 | Evenflo Aura Traditions Travel System...
Safety 1st Alpha Omega Elite 22456 TTN Convertible Car Seat Logo
106 people viewed this question
Top Safety 1st Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Safety 1st Baby Gear Expert? Answer questions, earn points and help others
