Onboard video not working
My onboard video worked fine yesterday, but today i tried adding a 9800gt graphics card to my Foxconn A76ML-K but it didn't seem to work so I tried to go back to the onboard video and now my monitor is not getting a signal
  • twest77 Apr 17, 2009
    Yes there was a jumper to reset the CMOS but it is set on normal and not reset.
    The new card also would not get a signal out to the monitor and yes i cycled through all available inputs.
    I would download the drivers but I never could get an OS on the computer since the onboard video isn't working I can't even install it
  • Dick
    Dick May 11, 2010
    Do you see a jumper to reset the CMOS? It probably disabled the onboard automatically.
    What happened with the new card? Did you cycle the monitor through all available inputs?
  • 594 Answers
You need to download the drivers for either the onboard video card or the 9800gt video card to make them work.
Posted on Apr 17, 2009
Adding a Video card
No, When you plug in the Discrete graphics card it causes a bypass of the onboard video chip. The only system that will use the onboard video is the new APU units, and these only give a boost to the graphics card.
Sep 20, 2013 | Acer eMachines Black EL1352G-41w Desktop...
I have a asus p5g41-mlx3 mobo and i'm trying to install a palit 8400+ 1gb video card, but after installing and starting up my pc i get a blank screen. if i take out the card my computer works fine....
Check if it a jumper to disable the onboard video. If not, try disabling the onboard video in BIOS or selecting the option in BIOS to use a plugin card rather than onboard.
Where do you have your video cable plugged in? With the new graphics card installed, do you have video out of either connector?
Jim
Preston Computer Services
www.prestoncomputerservice.com
Jun 03, 2011 | Palit Microsystems GeForce 8400GS,, PCI...
I bought Foxconn 755A01-6EKRS Motherboard for my HP pc replacement. i install my AGP VsionTek x1300 graphic card and turn it on and nothing show up on screen...then i put the graphic card back to my old HP...
Your new Foxconn motherboard Primary Graphics Adapter settings in set to onboard vga that is why there is no display in your monitor. Do not install yet your agp video card. Use first the onboard vga of the motherboard.
Power up your computer and go to the BIOS settings. Locate in bios about the Primary Graphics Adapter settings and then select AGP. Save changes and the exit. Turn off your computer and now install the agp video card.
Dec 16, 2009 | Foxconn 755A01-6EKRS Motherboard
PCI-E card does not work, onboard video works fine, this is the second card.
The Abit IP-95 manual doesn't show you how to adjust your bios settings when adding a PCI-E x16 graphics card. When adding a PCI-E card you'll need to adjust a few settings within, Advanced Setup.
Press the delete key on your keyboard every two seconds to load your bios menu. Within Advanced Setup look for, Onboard Device Configuration and open it. Find, Primary Graphics Adapter.
Set this to read as [PCI-E, VGA] save your changes and exit.
Currently your onboard graphics is enabled. You'll need to change this setting to PCI-E first. When you use the onboard UniChrome Pro 2D/ 3D Graphics & Video Controller you are also using some of your system memory to run the UniChrome graphics. Once you enable the bios to boot to the PCI-E card you can also stop using your system memory assigned to the UniChrome card. Link to Abit is provided below, click on it to open;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=IP-95&fMTYPE=LGA775
Cheers!
Mike
Nov 12, 2009 | Abit IP-95 Motherboard
Onboard graphics card for my X3200 disabled
No need to break the seal on the box -- there's nothing to jumper or switch inside there anyway.
Some video card/motherboard combos will let you do this, others force you to choose one or the other, but here's how you find out.
Right-click on "My Computer" and select "manage" This will bring up Computer Management
On the left side of the Computer Management window, find Device Manager and click on it.
Now, on the right side, look for Display Adapters, and expand it. There should be an entry for your GT120 and hopefully another entry for your onboard video. Right-click the onboard video device, and one option should be "Enable"
If you don't see this option, it's because your onboard video can't work at the same time as the GT120.
Let me know how it goes! Rate me if it works, comment back if it doesn't work and I'll see what else I can do.
Sep 16, 2009 | Acer Aspire X3200 PC Desktop
Foxconn A74MX motherboard will not pick up my PCIe Graphics card
disconnect everything except the power supply, the power on switch, one stick of memory and the graphic card (if you don't have onboard adapter), turn it on and see what happens.
Mar 28, 2009 | Foxconn Computers & Internet
Were are the jumpers to disable the on board videofor aopen mx3w pro-E
Why do you need to disable the onboard video??
If you have added a new graphics card it should automatically select this new card.
If it doesnt, you can go in to the bios and disable the onboard graphics card from there.
For example, Onboard graphics can usually be refered to in the bios as PCI, so if you've added an AGP card or PCI-E card then you would just need to select either one of these from the bios menu.
Not sure what bios your using but it may even have ann option to disable onboard graphics.
Oct 23, 2008 | AOpen MX3W Pro-E (91.88210.241)...
No Video (Overlay) and no 3D-function
It sounds like you're onboard video card is faulty. Try installing a PCI-E card into the system. Foxconn claims they warant their board for life. It would be worth checking with tech (New board).
I found no bios update that would address a fix for the onboard graphics card. (Unable to function in 3D).
Onboard VGA, page 42 in the user manual.
Foxconn tech support: http://www.foxconnchannel.com/contact.aspx
Jun 04, 2008 | Foxconn 6100M2MA-RS2H Motherboard
Video graphics card
being a PCI card, not a AGP or PCI-E the system may not simply switch to that one a primary display adapter when you install it, in the bios under advanced system settings or intergrated periferals, you should have an option to change the primary display adapter, make sure a PCI adapter is included.. if it isnt, chage it to recognise a PCI card as a primary adapter, turn the system off, and install your card then, depending on the bios/model of the mainboard on some of those dells, it may be a little hard to find, ive had to play with a few of them
Nov 24, 2007 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
844 people viewed this question
David Payne
David Payne
