Question about Photography
Film streaked images
Film develops with dark stripes or streaks in most frames
what is the cause
    Problem Solver:
  • 16 Answers
The shutters are broken or the film loader is schratching the film.
Posted on May 06, 2009
How do i re align the head on aMX432 cannon
  1. Open the printer driver setup window
  2. Click Custom Settings on the Maintenance tabThe Custom Settings dialog box opens.
  3. Switch head alignment to manual
    Check the Align heads manually check box.
  4. Apply the settings
    Click OK and when the confirmation message appears, click OK.
  5. Click Print Head Alignment on the Maintenance tab
    The Start Print Head Alignment dialog box opens.
  6. Load paper in the machine
    Load three sheets of A4 size or Letter size plain paper into the front tray.
  7. Execute head alignment
    Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  8. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Even if the patterns with the least amount of streaks are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    When you have entered all the necessary values, click OK.
    [img src="http://ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/MX450%20series/1.0/EN/PPG/images/i_note.gif" alt="" >Note
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
      (B) Most noticeable vertical streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal streaks.
      (A) Least noticeable horizontal streaks
      (B) Most noticeable horizontal streaks
  9. Confirm the displayed message and click OK
    The second pattern is printed.
  10. Check the printed pattern
  11. Confirm the displayed message and click OK
    The third pattern is printed.
  12. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Even if the patterns with the least noticeable horizontal stripes are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal stripes.
      (B) Most noticeable horizontal stripes
Jan 05, 2015 | Cannon Office Equipment & Supplies
How to fix olympus fe-340 streak and peaks verticaly when picture taken
Not sure you can fix this, but most of the time the stripes are produced in a dark environment with one or a few bright lights. The streaks start on the bright light. Most of the time if you shoot the picture the streaks are not on the picture.
You could try to switch the camera to the automatic, or perhaps night scene.
If the streaks are there in normal light, I think your camera is defect.
Jul 27, 2014 | Olympus FE Cameras
Iron has dark streaks
there is an iron sole plate cleaner on the market
the stain is electrolysis from using other that de-ionized or distilled water
Aug 08, 2017 | Rowenta Perfect Iron
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Have a canon c130.changed toner and still getting dark streaks on copies. Have cleaned all I could find inside still dark streaks
    Try doing a "stop test." You would induce a jam before the paper reaches the fuser.
    Just open a cover while printing and hopefully some image has been transferred to the paper. If the defect exists already then the laser unit, or document scanner may be causing it.
    If that eliminates the dark streak, then obviously the fuser FG6-3720-000 should be changed.
    Whit
    Item, Inc
    Aug 18, 2010 | Canon C130F Black and White Copier
    Printed document has white streaks. I've replaced all toner cartridges AND replaced the toner waste unit. The streaking occurs when I print or copy but is much worse when I make a copy. Is there a printing...
    If you are getting vertical white streaks or faded streaks from the top of the page to the bottom. It sounds like the developer blades in the imaging unit needs to be replaced. It cost around $120 to replace, but after a while it will happen again. This is a common problem with this printer. It can be cleaned by taking the unit apart and cleaning the developer blades, if you are handy. I have posted detail instructions in my tips section. or you can click on this link:
    http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300.
    Hope this helps.
    Jun 13, 2010 | Samsung CLX 3160fn All-In-One Printer
    35mm film developed with streaks
    I take it the streak is a hot streak of light. If you're shooting negative, look at the negative and see if it's one long streak. If so the light leak could be anywhere between the film roll and the take up roll. I would open up the back, go into a closet and shine a bright light on the front of the camera and see if you can find the leak and tape it up. Otherwise, 35mm SLR's are very cheap these days. I'd recommend a Canon A-1 for your daughter, but you can't go wrong with any Canon or Nikon.
    Sep 03, 2009 | Photography
    Nikon D80 red and green streaking
    check on the shutter speed and also the Aperture priority..
    Jul 27, 2009 | Nikon SLR D80 Digital SLR Camera Digital...
    What causes the toner to leave color streaks on the paper? It's leaving red streaks and I've replaced the magenta & black developers....but could it be the PCU causing the problem?
    The developers almost never streak. I would be looking at your PCUs. Developers have a tendency to leave voids and dust the paper. PCUs tend to streak as the cleaning blade and charge roller wears out.
    Jan 24, 2009 | Ricoh Aficio CL7200 Laser Printer
    Prints black vertical line at bottom of page on every print. HP 8550gn
    This should help -
    Developer streak
    Developer streak is characterized by a line of dark or missing toner
    that stretches from the leading edge to the trailing edge. Replace the
    toner cartridge corresponding to the color of the developer streak (for
    example, if the streak is magenta, replace the magenta toner
    cartridge).
    Repetitive defects troubleshooting
    Repetitive defects are defects that occur in the same vertical position
    on the page, but not necessarily on every page. Most repetitive
    defects are caused by problems with one of the following, and are
    indicated by the positioning of the defect on the page:
     developer roller (at 38 mm)
     charging roller (at 44 mm)—see additional information under
    “Charge roller set” on page 454.
     cleaning roller (at 56 mm)
     developer DSD wheels (at 65 mm)
     transfer roller (at 66 mm)
     transfer drum (occurs once per 11-by-17 inch or A3-sized page,
    or every other letter- or A4-sized page)
     fuser (at 150.5 mm)
     imaging drum (at 195 mm)
     transfer belt (at 222 mm)
    May 21, 2008 | Office Equipment & Supplies
    Photography Logo
    98 people viewed this question
    Top Photography Experts
    pontelemon
    pontelemon
    TC CAMERA REPAIR.Com...
    Are you a Photography Expert? Answer questions, earn points and help others
