L7vmm mb. display went out. Monitor works on
L7vmm mb. display went out. Monitor works on another machine. L7vmm3 powers up; just no display. wanted to put a agp card in, but can't see the cmos/bios. Help
  • Anonymous Apr 17, 2009
    In my gigabyte 845G moptherboar ddisplay went out. Monitor works on. How to solve it
  • 103 Answers
Dear User. to plug in the AGP card you dont need to check or see the CMOS. if u have pluged an AGP card and problem still persist then the problem is at *********** side or in RAM. just plug out RAM and other hardware except Processor and cables of switches. the switch on it and if it gives beep then your motherboard and processor is OK. there would be problem in your RAM so change RAM. and if it dont give the beep at startup then the problem is in your motherboard or power supply.
Posted on Aug 31, 2009
Agp cards not working
ok hmmmm maybe it only except 4x agp? is it very old? maybe the slot maybe burned out? do you have enough power source to run the card? i cant think of anything else.. good luck. my agp card did the same thing when the power source burned out. some day i would get nice veiw someday a dark screen. i though restarting would help and eventually the power source burned out.
Jan 21, 2010 | Intel D865GLC Motherboard
Where can i download the ECS L7VMM3 motherboard software cd..? because of some occurrence i've lost my software cd a year ago.. i reformatted my pc thats why i want to find where does the specific cd can...
here's the link
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=61&DetailName=New&DetailDesc=L7VMM%20%28V1.0A%29&CategoryID=1&MenuID=82&LanID=0
Jan 18, 2010 | EliteGroup ECS MB L7VMM+ W/ CPU-ATHLON...
Video black with 7600gs card installed
Hi bandit11,
First how did you get a PCI-Express X16 like the 7600 onto a AGP 4X port?? Two different animals. To answer your qustion, no that Card will not work on that Board. You can spend your money if you want to on some of the higher speed video cards but, to be turthful, I wouldn't. The CPU and memory will limit any of the newer cards that will fit that board today. But, if you really want to keep that board, then I might suggest to look for a $40-50 Radeon 9700 pro or 9800 pro. Anything more than that is a waste of your money.
Bottom line a lower end AGP cardwon't give you any more card performance then high end AGP card if you must upgrade, go used and cheap...nothing fancy.
Best of Luck
Mark
Dec 11, 2009 | Syntax SV266M Motherboard
No color on my tv
this system requires about 64 MB of system memory and requires CD ROM as a software where we can install it.
128 MB of ddr memory
display support.
  • BIOS compatible with VESA for super VGA
  • DDC1/2b/2b+ monitor support
  • VESA Display Power Management Support
Nov 28, 2009 | ATI RADEON 9200 SE (128 MB) AGP Graphic...
ATI AGP card and Compaq Presario S3100NX with open AGP Slot
This particular model of the system is basic home use system not built for games.
You can put in either a PCI graphics card or an AGP 4x graphics card that should not take more than 1.5v of power.
The max you can put is 128 MB , you can try the 256 MB, but i would suggest against it .
Thanks for using fIxya
proton
Nov 07, 2009 | HP Compaq Presario S3100nx (DC477A#ABA) PC...
Where is the option to run dual monitors for this card? I can see the option for spanning but that just puts the same display on two monitors but I want to use two monitors as one screen
1st option is CRT monitor 2nd option is TV out or LCD..locating at this options is go to control panel and click Display Settings or right click on desktop then properties then display settings..Good Luck
Jul 10, 2009 | HP NVIDIA Quadro4 750 XGL (128 MB) AGP...
I have a L7vmm3 motherboard - everything is
If you have onboard video disabled in BIOS, then the driver can't find the video chip.
Enable onboard video in Bios and you should then be able to install driver.
Hank
Jun 09, 2009 | EliteGroup (L7VMM) Motherboard
GeForce 6600 AGP 8x 256 MB in Asrock 7s41gx
get another hard disk and do a fresh install of xp then the drivers and the game see if its all ok
if it is then its your drivers get them out and replace them
with the latest from nvidia. or format and go again
hope this helps
Dec 30, 2008 | Nvidia GeForce 6600 256MB 8X AGP Video...
No display at post
There are a few things that can cause no display on the monitor.
That single beep means POST = Power On Self Test. Post has tested everything on you're board to be good.
The cable between video card & monitor may be bad or not connected correctly (Swap out the cable as last resort).
2. You're monitor is defective, try swapping it with known working monitor.
3. You're video card is not functioning.
Lastly, when you reset the system cmos/bios everything went back to default. This means you're bios is now using the onboard PCI video graphics. Remove you're radeon 9600 video card. Try booting the system. You should see display again. The only way to test you're radeon would be to boot to the bios & set bios to boot using the AGP radeon. You need to change Init Display First to AGP & not PCI. If you loose video than you know you're AGP card is bad. Reset the cmos/bios before adding another AGP card or you will not get display. This setting is on pg 3-5. Integrated Peripherals. If you need you're manual you can download it from this link: http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF7-S2G&fMTYPE=Socket+A
Good Luck!
Mike
Jun 06, 2008 | Power Color RADEON 9600 (128 MB) Graphic...
Video signal
If it worked fine before the AGP card was removed then the problem is probably related to your BIOS settings. The BIOS setting that controls the integrated video may be set to OFF.
  1. Insert an AGP video card
  2. connect the monitor to the card
  3. boot to BIOS
  4. check settings
  5. turn ON integrated video
  6. save and exit BIOS
  7. shutdown
  8. Remove AGP card
  9. connect monitor to motherboard video port.
  10. Reboot.
What happened?
Jan 26, 2008 | EliteGroup 661FX-M Motherboard
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
