Question about Frigidaire FEF355 Electric Kitchen Range
The top burners come on but my oven wont heat up. The elements are working, i had them tested.The stove is only two years old.
  • Anonymous Mar 21, 2014
    Top element not heating
  • 3 Answers
There is an open circuit in the oven circuit.
If you have a timer, make sure it is set to Manual Operation.
The thermostat rarely fails unless there is mechanical damage to the gas tube inside the oven. It is common for terminals to open circuit due to the high power consumed by oven element.
It is also possible to have a blown fuse to oven supply if it is fed by two or three phase power.
Check for supply form terminal block to thermostat and from thermostat to element.
A simple test is to remove oven element and insert light globe. When oven turns on globe should light. This confirms element is blown.
Posted on Apr 17, 2009
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Heating elements on whirlpool electric range do not work
They may just be loose,try push the heating element in to socket,Or remove and check ends,may need cleaning to get good connection.
Dec 25, 2012 | Whirlpool Kitchen Ranges
We have an 8 year old Frigidaire electric range. When going to use the oven a few nights ago, we discovered that neither the top or bottom oven burner was heating at all - tired both Bake and Broil. The...
You will have to check that the switch is is working ok , with a vault meter check for voltage at the burner , if none check at the switch and so forth back to the wall switch, if there is vaults at the burner it is faulty .
May 27, 2017 | Frigidaire FEF339E Electric Range
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Oven wont bake
sounds pretty simple a bake element
Oct 03, 2009 | Jenn-Air JGR8750 Gas Kitchen Range
I have kitchen aid in the counter range, the bottom heat element is bad. The element has burnt and has a 3" piece that has separated. At the same time the oven stopped working the burners stopped working...
The oven element will not affect the top burners, Unless it tripped the breaker at the panel when the element burned it two. Is there power to the stove? The top burners have their own power and control separate.
Aug 01, 2009 | Kitchen Ranges
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire FEF355 Electric Kitchen Range Logo
308 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
