Question about Samsung SC-D382 Mini DV Camcorder
Samsung SC-D382 mini DV tape transport mechanism is stuck
When mini DV tape is inserted, thin plastic cover is pressed, closes as it should, then entire tape holder (metal box + thin plastic cover), should retract into camera.
Tape box / mechanism refuses to retract into camera.
Instead, it makes whirring noise (not clashing or chrunching), fails to retract into camera body, then thin pastic cover pops open, exposing tape.
Of course, outer ''clamshell'' door, which makes up whole lower right side of camera, remains open, too.
I'm afraid to try to forcefully push tape 'box' back in, as sticker warns: ''Do not push in the compartment''
Thanks David
  • Anonymous Apr 19, 2009
    i have the same problem it ate the tape
techman
  • 3130 Answers
SOURCE: Tape Won't Load
something is blocking the mechanism and not letting it load or the mode switch is bad and the mechanism dosent know where it is. These camcorders are common for this type of problem and these days Im sorry to say that most places charge an arm and a leg just to look at them. good Luck
Posted on May 25, 2006
  • 64 Answers
SOURCE: samsung SC-D103 Mini Dv camcorder
the m-chassis is no good, needs to be sent in for repair sorry.
Posted on Nov 19, 2007
  • 73 Answers
SOURCE: "No Tape" on Samsung SC-D353 Mini DV
BAD TAPE TRANSPORT PROBLEM NEED TO SEND TO SAMSUNG FOR REPAIR.. THEY ARE CRAZY SO U MIGHT WONT TO CALL ME 717 733 3543
Posted on Mar 02, 2008
charcois
  • 763 Answers
SOURCE: Samsung SC-D363 Mini DV digital camcorder
sir if your camcorder is new then it has a warranty. we should send it first for their service because they have a spare parts for replacement and info. if your going to fix it by yourself then the warranty of that will be void. by the way the place for the service center for camcorder samsung in the philippines is in makati i think. i got a problem with my samsung just like your model and they told me that it is located at makati. hope that helps!
CHARCOIS
Posted on Oct 03, 2008
caroldon
  • 17130 Answers
SOURCE: I have a Samsung SD263.
There is a fault in the loading mechanism that has resulted in the mechanism being out of alignment or failed.
If you hear any motor noise as you switch on the camcorder then the problem is related to failure of link of the loading mechanism , can be a gear , belt or pulley that has slipped off.
However if you do not hear any noise then the possibility of failure of the motor drive, driver circuit- loading IC- or the motor. Now this needs a technical check of the voltages to the circuit to confirm and you must be versed with basic electronics and some mechanical skills, so as to remove carefully the panel , boards and check the mechanism.
In fact it is no as easy as mentioned above but the work needs good attention and skill to infer.
Posted on Feb 23, 2011
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung sc-382, the tape transport will not fully come out, if it is pulled it does come out, but when it goes back in, it will not fully seat.
it is seems like a belt capstan drive slip;if your tape get stock when you eject that is 2 problem ;the belt or your mode swith mechanism....
Feb 08, 2010 | Samsung SC-D382 Mini DV Camcorder
Samsung SC-D103 Mini DV
sounds like your tape transport is bad.. something might of broke inside since it almost all plastic.. try to run a dry tape cleaner through..
Aug 28, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Samsung Mini DV camcorder (Protection-Problem)
SOUNDS LIKE THE TAPE TRANSPORT IS BAD. IT WILL EAT YOUR TAPE SOON. YOU WILL NEED A NEW TRANSPORT OR A NEW CAMCORDER ...SORRY
Dec 14, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
Wont Take Tape
BAD TAPE TRANSPORT. NEED TO SEND IN FOR REPAIR
Apr 25, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Apr 22, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung SC-D382 Mini DV Camcorder Logo
193 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
