I have a HDTV hooked to a Scientific Atlantic HD cable box. I would like to know how to hook up this previous setup with a DVD player and a Play Station 2, to where they both will work at anytime and seperate of each other. Thanks
  •  George Vernon
    George Vernon Apr 17, 2009
    How would you add a playstation2 into that mix also?
    Thanks
  •  George Vernon
    George Vernon Apr 19, 2009
    I beleive this will be an acceptable solution to my problem. My many thanks to the expert that helped us out.
  • 15,935 Answers
They will have to be on seperate inputs on your TV.
You have not given a model # of your TV - so I can only give you a generalized answer.
Since its an HDTV - im assuming you have the Cable box connected via HDMI cable.
Use the component video cables on your ps2 to the component input on your TV.
Then on the TV remote - simply press the corresponding button you have the desired input hooked up to.
Thanks for using FixYa.
Using the "continue with this expert" function - please post the make&model # of your TV for more specific help.
Posted on Apr 17, 2009
  • 19,396 Answers
Procedure may be slightly different depending on the model you have. Also there is more than one way to connect devices.
The best choice for the playstaion would be connecting it straight to the TV. If TV has no free connector connect PS to DVD aux input if DVD has two in.
Connect Video and audio out from cable box to DVD input using RCA cables on red , white and yellow connectors.
Connect DVD to TV using RCA cables on DVD output, or HDMI, SCART etc.
Connecting the Explorer 8300 Digital Video Recorder
I have a 70" element TV bought used no remote how do I get the DVD player to work? What channel ??? tv av component etc.....
How do I hook up my tv,dvd player,vcr, and cable box?
askville.amazon.com > Entertainment > Television
Dec 3, 2009 - Recent Questions About: hook tv dvd player vcr cable box · Entertainment > ... Exclusive Coupons To Get 30% Off ... Check the back of your TV to see which type of hookups are available and use the appropriate cables.
Element 46" Class LCD 1080p 60Hz HDTV, ELDFW464 ...
www.walmart.com/ip/Element-46-Class-LCD.../17188433
Walmart
Rating: 4 - ‎190 votes
The Element 46" 1080p HDTV features a brilliant full-HD picture for your viewing ...ShippingPass. H&R Block Tax Software 15, Deluxe + State. $34.70 .... I really cant stand having to use another remote...thats the point of having a .... Just a regular DVD player and it works perfectly fine with the TV. ..... Get to Know Us.
5 Easy Ways to Hook Up a DVD Player (with Pictures)
Jan 10, 2016 | Televison & Video
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
How to Hook Up a Receiver to an HDTV
Things You'll Need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
Hook up
Hi:
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Apr 27, 2010 | Sylvania Dual Deck DVD/VCR
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Can not hook my hdtv phillips tv to my dvd and
That is because your player does not support an HD signal and cannot complete the signal from one system the other.
Nov 28, 2009 | Pioneer DV-563A DVD Player
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
HDMI->DVI cable won't work
Are you using a HDMI to DVI cable or are you using a HDMI to DVI adapter? Sometimes, though not on all products you have to go into the menu and select which out put your using for each source and whats going through it. You might need to go into your dvd player menu and tell it not to try to run audio through the cable. That way it's not trying to force a signal through the cable that cant be accepted by the TV. That might possible solve your problem for the DVD player. Let me know if it works
Have a Great day
Aug 11, 2008 | Televison & Video
Vcr hook up
Have you tried to run:
Coax from the wall to your cable box.
Coax from the cable box out to the VCR cable in.
Coax from the VCR cable out to your TV?
What connections does your TV have? RCA or coax?
Mar 21, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Picture, No Sound from HDTV Box
CON-YOU'VE DIAGNOSED YOUR OWN REPAIR.GET A NEW CABLE BOX.JOE TV
Apr 20, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Televison & Video Logo
Top Televison & Video Experts
