Question about Kitchen Appliances - Others
I have a Cecilware Commercial Electric Deepfryer SN661044. All of the apropriate lights come on but the contactors are not energising
  • jproman Apr 20, 2009
    All the lights and switches are working but the contactors are not energising. No loose wires that I can find
  • 19,396 Answers
That is probably a bad heating element.
to test the heating element you use a Multimeter . Set the multimeter on ohms (impedance) and touch the two contacts of the element with the multimeter probes. If there is no continuity (impedance infinite) then the element must be replaced.
If the element is fine, try replacing the temperature sensor, that is more difficult to test , if still no luck , control board is bad.
See also Testing Heating Elements.
To get parts call the phone number listed on documentation, or try calling toll free at 1-877-477-7278.
Don't forget to leave feedback.
Many thanks.
Posted on Apr 20, 2009
  • 3,037 Answers
Sounds like a connection inside the unit is broken. I actually had this happen on our deep fryer not too long ago (small world). Anyway, unplug the unit and start taking it apart if you have any electronic expertise (even if you don't, it isn't dangerous as long as you have it unplugged). Be looking for any broken contact or wire (one may just be loose or disconnected). Start at the heating coils and work to the power outlet following the wire. Let me know if you have any concerns while doing this or need anything else. When you find the broken contact, I can help you figure out what to do but its usually pretty simple.
Benjamin
Posted on Apr 18, 2009
Commercial fryer cecilware
The valve could be defective.
Sep 14, 2016 | Cecilware FMS-40 Deep Fryer
Wells 3 element commercial deep fryer. One element heats up other two do not. So all the work of heating is one element. Eventually the reset button trips off. All three tested good for continuity. Is...
All electric commercial fryers have a contactor relay due to the amps involved.
You will see contactors on this parts list. It seems they have one depending on voltage. Depending on model, you may have more than one. The other possibility with yours is heat damaged connectors. I have seen commercial equipment stop working because wires have burned through at terminals. I am a trade chef.
http://www.wellsbloomfield.com/oldsite/new-bloomfield-ind/~WELLS/WELLS%20LIBRARY/Wells%20Parts%20Lists/PL301NEW(a).pdf
Fryer Products
wells deep fryer parts Google Search
Dec 17, 2017 | Kitchen Appliances - Others
Cecilware FCM-120 Professional Electric Crepe Machine manual
Try to look for Cecilware manuals at http://www.grindmaster.co
Jun 10, 2011 | Kitchen Appliances - Others
What do I need to buy to properly vent a 40 lb. deep fryer?
Well, these are commercial fryers that are typically under a commercial exhaust hood with a fire suppression nozzle located directly above them. Why, are you doing something out of the ordinary?
Oct 29, 2009 | Cecilware FMS-40 Deep Fryer
Commercial Deepfryer
The thermostat for a GF28 is a Cecilware L099A or F. It is not repairable, but any reputable commercial parts place should have it available for around $90 US.
May 02, 2009 | Cecilware GF-28 Deep Fryer
I have cecilware deepfryer and it only work on a high tempersure
Hello. It sounds like your thermostat is bad, without anymore information of the problem, that is what I am going to say. Here is a link to the manufacture with owners manuals, you can get parts lists also.
http://www.cecilware.com/product_manuals.aspx#kitchen
Hope that helped, and thank you.
If you have further problems, "ask me"
Apr 17, 2009 | Kitchen Appliances - Others
True Commercial freezer not cutting out
Tech. can not find freeon leak in line but endicator is regestering freeon leak in side of back panel.
Jun 04, 2008 | True 52 cu. ft. / 1472 liter Commercial...
Cecilware Fryer electric
you have a bad high limit the range on this should be around 600 degrees.
Apr 16, 2008 | Cecilware EL-250 Deep Fryer
goto this site http://www.3wire.com/foodservice/ sign in and look for your model.
Dec 21, 2006 | Imperial IFS40 Deep Fryer
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
