Question about Whirlpool ET8CHEXSQ Dryer
Whirpool gas dryer not heating up
My Whirlpool gas dryer (model LCR7646JQI) is not heating up. I turned on the dryer and looked inside the gas chamber via inside the pilotless hole and it seems as if nothing is glowing. I figured it might have something to do with either the igniter, the flame sensor, the thermal fuse, the high limit thermostat, the operating thermostat or the timer. What can I do to further determine what the problem is?
  • 659 Answers
Take a volt meter and call for the unit to come on. Take the connector off to the igniter and check for voltage to those wires. If you get voltage but it does not start, then you know the igniter is bad. It could also be a limit switch. There will be 2 wires that terminate to a small disk with a button in the center. Depress the button firmly to reset it. It should be located near the burner. If it is the timer, you will need to locate and isolate the power wires leaving the timer and check voltage there. Hopefully this information is helpful.
Posted on Apr 17, 2009
HOW DO YOU CHANGE THE HEATING ELEMENT ON A WHIRPOOL DRYER MODEL LE7000XTW0
The heating element is on the back side under the dust cover.
You gotta remove a strap at the top of the heater chamber and then you can get the heater assembly out. Remove the filter and raise the top:
The element is on the right
The heater
the heater element slides out after ya remove a screw at the base.
Service Manual
Oct 29, 2011 | Whirlpool Dryers
My whirpool gas dryer model number wdg6200swq, wont heat up. the ignitor lights but no gas lights
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 02, 2011 | Whirlpool Dryers
My Whirpool dryer Model LGR 563 isn't heating now. Does it have a manual or electronic pilot light? I don't see a pilot light lit through the hole.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 24, 2011 | Whirlpool LGR5636PQ Gas Dryer
How do I ignite my whirpool gas dryer?
heatman101
Oct 17, 2010 | Whirlpool LGV4634JQ Gas Dryer
I have a whirpool dryer Model LER 4634 PQ0. The dryer turns but does not heat. What could the problem be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Whirlpool LER4634J Electric Dryer
I have a whirpool dryer model ler4634pq. I will not heat. I had the heating element and replaced the theromstats on the element but it still does heat. I had the switch checked. I checked to make sure hose...
heatman101
Apr 13, 2010 | Whirlpool LER4634PQ Electric Dryer
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
Whirpool GGw9250Pw3 no power on Control Panel Inside light works
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
Whirlpool ET8CHEXSQ Dryer Logo
232 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
