Question about Frigidaire GLTF2940ES Front Load Washer
Soap dispenser keeps filling with water after everyload. I have to empty after load. The dispenser is also growing mold.
  • 36 Answers
You should clean the soap dispenser regularly by removing it from the washer.
Some units have a release clip but some just need to be pulled out firmly by hand.
Then give the tray a very good clean as no soap residue should be present. It sounds like the fabric conditioner cycle is filling the relevant tray section but unable to drain through blockage.
Should be pretty straight forward to remedy.
My regards
Marc
Posted on Apr 17, 2009
Why does My Samsung VRT front loader leave the soap dispenser full of water at the end of the wash cycle. I have to empty it in order to add detergent for the next wash cycle.
there are 2 components to the soap dispenser, 1 using liquid soap has a little tub that you dispense soap into and 2nd you remove the tub when using powder soap. I assume that you are talking about the little tub is filled with water. How this works is by adding water to the tub the level rises and siphoning empties the little tub. If any water remains it is due to water being added after the little tub has already emptied. That is not a big issue and will happen. Just empty the water or add some water to start the syphon process.
Oct 11, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Tip
Proper cleaning and caring for your hydration packs
Properly caring for your hydration packs will help to prevent and clean up mold should it build up in your pack. To prevent mold from building up to begin with after every use you should be emptying the pack and letting it hang upside down to air dry.
Mix 2 tablespoons of baking soda or bleach with hot water, pour the solution into the hydration pack and mix it up well. After mixing hold the pack or hang it upside down, and pinch the bite valve to let the solution fill the tube. This will clean out the tube that the water comes out of. Allow this solution to sit in the pack for 30 minutes.
After letting the cleaning solution out, fill the pack with hot water and a mild soap. Make sure that you get all the bleach and soap out of the pack before you use it again.
When you get all the soap and bleach mixtures out of the pack hang it upside down to air dry. If you are going to pack it up and put it away make sure that there is no mosture in it otherwise you will start to grow mold.
If you care for your hydration pack on a regular basis then you shouldn't need to follow these instructions all the time. Just emptying and hanging upside down to air dry is usually all you need, but its safe to every once in a while to do a thorogh cleaning.
on Jan 02, 2014 | Camping, Backpacking & Hiking
Black stains on door
If it is inside, it is probably mold growing. Front loaders are much more susceptible to mold growth as they seal up tighter, and we all tend to keep the door closed when it is not in use.
Clean the inner door and bellows surfaces with a 50/50 bleach/water solution, applying liberally, and dump the rest into the tub of the washer. Add 1 more cup of bleach to the tub. Fill all of the dispenser cups with bleach. Run the hottest , longest cycle available with the hottest rinse cycle available. For us, it is the "sanitary" cycle. Run a normal cycle immediately thereafter to flush out residual bleach, and leave the door open. The cleaning along with the air drying will keep the mold from growing, and reduce the odors that these machines are famous for. Leave the door open between loads.
Best regards, --W/D--
Jan 23, 2011 | Zanussi FJS1225W Front Load Washer
Moldy door gasket, smelly clothes
Mold growth is a common problem due to tight seals and poor drainage.
Pull back the rubber or plastic around the tub or basin to reveal the problem. You should also check your detergent dispenser as this is another common area for mold growth. Remove any visible mold. You can use a solution of water and dish detergent or bleach (1 part bleach to 10 parts water). You could also use bleach wipes to do this depending on how stubborn the mold is.
Because of the set-up of the washer, mold can also tend to grow in pipes, traps, and outside the drum where you can't see it.
You can run an empty load on the hottest water setting with 1 cup or more of bleach. Run an empty load on the hottest water setting with 1 cup or more of vinegar. Use a product designed to attack build-up from detergents and fabric softeners. Call a repair man to service the parts of the machine you can't see or attempt to do it yourself
However Mold needs moisture to grow. Leave your washer door and detergent dispenser cover open in between loads to allow for complete drying. This will dramatically decrease or eliminate the problem.
2. clean the machine monthly to stay away from the problem.
3. Switch to powder and/or low-sudsing detergent.
Let us know if you need further clarification else please accept the solution.
Thanks for contacting fixya.com
Mar 21, 2010 | LG Washing Machines
My Maytag front loading washer constantly gets a build up of moldy looking stuff on the inside of the tub. What can I do to clean it off (bleach doesn't do it!) and what do I do to keep it off!!????
Hi. I have seen where some people leave their washer door open when it isn't being used to help with this issue. There are also various chemicals available to help with this issue. What I find to be most preferable is to clean the strainer, and flush the washer thoroughly. Here's how:
1. Remove and clean the strainer. It is located at the front base of the washer, behind the kick panel. The strainer is located between the drum and the pump, being connected to the drum with a rubber hose. Usually, the strainer unscrews. Clean it thoroughly, and look up into the pump cavity. Remove any debris that you find there also.
2. Flush the washer. Use a solution of soapy water and bleach to wipe down the seal face, and in the grooves of the seal where mold tends to grow. Wipe it down, let it sit so it can work, then wipe it down again. Pour 1 cup of bleach in the machine. Fill the dispenser cups (soap,bleach and softener) with bleach. Run an extended sanitary load, empty, with the hottest water selectable. After running, run one more empty cycle to flush the system completely.
This should have your washer clean and sanitary. Repeat the bleach washes monthly or more often, based on what you see and smell.
Some detergents are more condusive to allowing mold to grow than others. You can make a detergent that has borax, sodium carbonate and a mild soap in it. This has been satisfactory for us, and we can wash a load for ~.02 cents per load. You can look into this by going to YouTube, if you like. Type in Laundry detergent in the search bar.
Aug 09, 2009 | Maytag Washing Machines
I have mold growing where the rubber seal is around the door. I have a ine year old and I am worried about washing his clothing.
A nicely moist area,
...could try to kill all the mold with dilute chlorox (put some in a spray bottle--can also use on feet after the gym to prevent contamination from athlete's foot/feet)(or the shower mold killers which usually just have chlorox [sodium hypochlorite or similar]); then in future leave the door ajar when not in use so the area can dry (assume front loading), and if it is the large gasket style that still leaves a moist area behind itself--could put a wedge like a popcicle stick or few to allow air behind the gasket.
...any mold that is visible and therefor in contact with the clothes going in and out, should be easily removed...there should not be any mold in the washing compartment as the bleach and hot water used for whites would always kill the mold; so the only contact point is at the exterior (cleanable) when removing finished clothes.
..likely there is plenty of mold exposure in his environment beyond this----this is nothing like the problem with flood contaminated walls/floors and unseen mold that could spew forth significant amounts of spore load.
Aug 09, 2009 | Washing Machines
Bosch Washing Machine Softener Tray not emptying
You need to replace the cold water inlet valve. If the machine is older than one year it may be clogged on the side that moderates the cold water to the bleach and softener compartment. Replacing the valve fixed the problem. During the cycle when the softener dispenser fills it should fill quickly and no or little water should be seen in the soap dispenser area. If a lot of water goes into the soap dispense and little into the softener area the valve is clogged.
Feb 15, 2009 | Bosch Logixx WFT 2806 Front Load...
Water smells when draining
put yourself out of misery - get rid of it !!!! It will never get better...
Aug 04, 2008 | Kenmore Elite 45986 Front Load Washer
Dispenser full of water
believe it or not whirlpool says that's normal its in your owners manuel under dispenser because the washer mixes the bleach soap fabric softener with water for it to dispense they say its normal for water to remain but if you want to empty it there is a tab that you can press down on in the dispenser and remove it have a bowl handy
Jan 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Smell on towels
It's good that you are using HE detergent but you're probably using way too much. To test this run the washer empty (no soap) and if you see bubbles inside that's left over soap that's still in the unit. If so, keep running it empty until the bubbles are gone then start using only about 1 tablespoon of soap per load. The washer uses about 1/10 of the water so you need to use 1/10 of the soap. Use the same amount of softner. The excess soap and softner build up in the unit and cause the smell.
Jan 18, 2008 | LG WM-2277HW Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
300 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
