Question about Panasonic CQ-DP133U CD Player
Connector pin out (12volts, gnd, speaker out )
Connector pin out Panasonic CQ-DP133U
  • Kevin
    Kevin May 11, 2010
    can you clarify the question/issue. Are you asking if the pin is 12v,gnd or spkr out?
3 Suggested Answers
zzedly
  • 300 Answers
SOURCE: wiring diag. panasonic CQ-DF66EUC
Click the "Start Download" button on this page to download the owner's manual for your receiver. Page 30 has the wiring diagram.
Posted on Mar 05, 2008
kenw392
  • 2226 Answers
SOURCE: I HAVE PANASONIC CQ-C700U STEREO PLAYS ON ALL
are you running the rest of your speakers off an amp? if so, it sounds like you have the amp remote wire connected to the power antenna wire. on some radios there is an amp remote wire and a power antenna wire. the power antenna wire loses power when not listening to the tuner (radio). usuall there is a solid blue and a blue with white stripe. the blue with a white stripe should be amp turn on.
Posted on Aug 19, 2009
Testimonial: "YOU GUYS ARE RIGHT ON! THANKS FOR YOUR HELP IT WAS GREAT >"
Installing an internal speaker on a Desk top pc mother board do you need to reconfigure your system.
Typically, the speaker is connected with 2 or 3 wires. The connector block should have a pin labled "SPKR" or "Speaker". From there, count three up and find a pin labeled "+5v". These two pins are typically separated by two ground pins.
So, the connection would be: spkr, gnd, gnd, +5v. The ground pins may, or may not be used depending on your design.
Nov 06, 2014 | Computers & Internet
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
I've bought an adapter thing, but I don't understand how to wire these wires.
  • Yellow - To the car battery of continuous +12VDC
  • Red - To ACC Power, +12VDC
  • Black - Ground, to bare metal or clean part of the car
  • Dark Blue - Motor Relay control lead for Antenna
  • Dark Blue / White Strip - Amp Relay Control lead
  • White - Front/Left Positive Speaker
  • White / Black Strip - Front/Left Ground Speaker
  • Gray - Front/Right Positive Speaker
  • Gray / Black Strip - Front/Right Ground Speaker
  • Green - Rear/Left Ground Speaker
  • Green / Black Strip - Rear/Left Ground Speaker
  • Violet - Rear/Right Positive Speaker
  • Violet / Black Strip - Rear/Right Ground Speaker
Nov 11, 2010 | Panasonic CQ-DP133U CD Player
Trying to wire in a 92 chevy s-10
Buy a wiring kit for your vehicle (available at walmart, autozone, etc) It takes the guess work out of which wire is which coming out of your dash.....Panasonics wiring is standard to that of other cd decks....Red=ignition Yellow=memory or battery Black= ground Blue=remote turnon for amp or antenna, Orange=illumination, Then the green, white, grey & purple wires are speakers (positive and negative).
Sep 19, 2010 | Panasonic CQ-DP133U CD Player
Logitech x-230 9 pin problem . i need to manualy insert wires into pin holes.. So can anyone tell me the color and pin hole nunber to put right wire into
worked on this for 3 days but i finaly got it I had to open it an follow coper lines using datasheet, the connector is RS232 the pins are
1 = LED+
2 = IN R
3 = OUT R
4 = OUT L
5 = GND
6 = ON
7 = 5V
8 = GND
9 = IN L
so you have to put a swiths between pin 6 and 7
you should also put a potentiometer GND-IN-(AUDIO SOURCE)
and a led between pin 1 and GND
and that is it!
---POXTRON---
May 15, 2010 | Logitech X-230 Computer Speakers
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
Flashing power light
Check for these power supplies on the Sub deflection board first on the right side of the board there are two Connectors one is a 12 Pin connector CN803 From the top of the connector the wires should read;
30V
Gnd
Gnd
-30V
8.5 V
8.5 V
Gnd
Gnd
-8.5 V
Gnd
Gnd
13.5V
Next is the connector below that one which is a 10 pin connector CN802 they should read
11.7V
11.7V
N.C
Gnd
CTL
Gnd
34V
34V
Gnd
Gnd
Next is a 14 pin connector on the top left side of the board CN801 those should read
34V
34V
Gnd
Gnd
-8.5V
Gnd
8,5V
8.5V
Gnd
13.5
NC
12.5
12.5
Check those supplies and see if they are correct or if any are missing
Mar 09, 2009 | Samsung HCL4715W 47" Rear Projection...
Power supply
ATX Version 1.2 - 20 wire motherboard connector Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6 Pin 7 Pin 8 Pin 9 Pin 10 3.3V 3.3V Gnd 5V Gnd 5V Gnd P_OK 5VSB 12V Oran Oran Blk Red Blk Red Blk Gray Purp Yell Oran Blue Blk Green Blk Blk Blk White Red Red 3.3V -12V Gnd P_ON Gnd Gnd Gnd -5V 5V 5V Pin 11 Pin 12 Pin 13 Pin 14 Pin 15 Pin 16 Pin 17 Pin 18 Pin 19 Pin 20 The color scheme used for the voltages in the 20 pin connector holds for the other ATX standard power supply connectors. However, brand name manufacturers often build proprietary power supplies or make up their own color coding, so I wouldn't throw out a power supply that supplies 5V where you think it should supply 3.3V. It's more likely a proprietary design than a failure.
Feb 21, 2008 | Computers & Internet
Panasonic CQ-DP133U CD Player Logo
79 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
