Question about Car Audio & Video
6 Disc Changer > Err
I have 95 BMW CD Changer in the trunk. The stereo screen shows CD and then Err. I can't slide the CD holder out either.
  • mormeglow Apr 17, 2009
    The CD holder is out! Now that the whole thing is opened, I tried putting in again to see if it'll work. It loaded and starting playing songs to my surprise. But you are right about crooked holder. There are several black rubber bubble holding each corner, and they appear to be deflated. Are these the spring you are talking about that are causing the holder to be misaligned? If so, do I replace the bubble or simply out of luck, and has to get a new one altogether? Thanks for you help.
  • Anonymous Mar 24, 2014
    loud pops that eventually shut down audio and creates a "err 3" readout, stereo comes on every time vehicle is started regardless of setting to "off" prior to shutting off the ingnition
Don't waste your money and buy those repair manuals. There is an easy fix for this. The rootcause is most likely related to your disc tray (crooked carrier or broken spring). Just get a small screwdriver and take out the two black srews of the inner faceplate, covering the cassette tray itself. Please make sure you do not drop those tiny screws. Use a magnetic tip screw driver. Take the faceplate off. You will see a litlle lever in the center. Just push it aside and your cassette will pop out with no problem. That simple. So don't waste your money!!!
Posted on Apr 17, 2009
The built in sat nav screen keeps going up and down without switching on and also the radio cd does not switch on. any advise would be appreciated
bmw navigation radio cd changer repair
www.hitechserv.com/electronics-repair/oem-navigation-dvd-cd.../67
We repair all models of BMW GPS CD Changer Stereo ... shows on the screen, no audio, display shows no navigation disc but there is a disc inside, do not play CD. ... If there is sound but your blue tooth or satellte tuner is not working "if your car is equipped with blue ..... The MK3, MK4 computers has a GPS module built in.
3 Series (E46) built-in Sat Navs - Gassing Station - PistonHeads
www.pistonheads.com/gassing/topic.asp?t=862860
PistonHeadsJun 9, 2010 - I don't know much about the OEM sat navs, other than that they cost no less than ... would need to be re-positioned and CD player becomes redundant. ... on forums, they do the job, just about and sometimes not too well at all.
Nov 01, 2015 | Cars & Trucks
2007 ford taurus air bag light on after replacing stereo
The CD changer option is similar to the single-disc player. The CD changer has the ability to toggle between the stereo and the multi-disc changer. In the 2007 Ford Taurus, the CD changer is located either in the vehicle's trunk or in the center console and has a magazine that can hold up to six CDs.---------------------------------------------------------------------------------------
Launch CResetter Oil Lamp Reset Tool
Mar 07, 2013 | Cars & Trucks
My radio volume just stopped working but you can see the channels and change from different stations what is wrong with it
If you have volume but cannot control it, this is a common problem. The volume is optical so it may just have dust in it, but I have had zero luck cleaning them. The only solution I know is to replace the whole head unit.
If you have an HK factory stereo with no volume at all, and the four channels went out one at a time, the amp in the trunk has failed. Another common problem. The amp is on the driver side above the wheel well. You have to remove the driver side rear deck speaker to get the trunk lining off without tearing it. The screws that hold in the speaker are beneath the speaker grill in the rear deck. Good luck getting a 15-year-old speaker grill up without breaking the snaps. Slide a putty knive in from the sides to try to release them, but they will break anyway.
If the amp has failed, you can just bypass the amp but you will have no subs or tweeters. I did that while looking for a good deal on a junkyard amp. You can buy a new HK amp from BMW but they are prohibitively expensive. You could buy an alternate brand amp and add crossover circuits to power the subs and tweeters if you are really handy with electronics.
If you have an HK system in your BMW and you replace the head unit, use the antenna power wire from the new stereo as the 'on' signal for your HK amp in the trunk. Your FM may not work quite as well because the BMW head unit communicates with the antenna amplifier. Also, if you have a BMW CD changer in your trunk, no other head unit will communicate with that other than the original BMW head unit.
Other than the CD changer and the antenna amplifier, the wiring adapter that you can get from Crutchfield or from Amazon will make the stereo head unit replacement plug-and-play.
You may need a special five-sided wrench to get the old stereo out. You can buy that wrench on line if you can't force some other tool into those two cap screws that hold the stereo in.
Sep 18, 2011 | 1996 BMW 3 Series
I get E-01 error of my cd changer
The fault is actually inside the CD changer, when one disc is selected the changer moves the gearing inside to slot from one CD to the other.
While this operation is happening the selection arm jams !!
Then giving an error at the radio display..
To fix the problem, disconnect the CD changer from the trunk of the car,
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again,
grease the moving parts with light lubricant
Good Luck
Feb 24, 2011 | Mercedes-Benz C-Class Cars & Trucks
Wont play through stereo
the changer plays through the fm on the radio, you need to find out what station it is tuned to. should be between 88 and 95 or so. you could just try seeking until the changer is picked up.
Jul 09, 2010 | Pioneer CDX-FM687 6-Disc CD Changer
Can't get CDs out of a 6 CD changer magazine for 2000 740i
their should be a slide button on magazine push that and cd holders should slide out
Apr 09, 2009 | 2000 BMW 7 Series
Cd player
Try turning your cd disc over, it may be installed upside down!
Jan 06, 2009 | 2001 BMW 5 Series
Pioneer cdxfm128 12 disc changer
Err 11, Err 12, Err 14, Err 17
Dirt or a scratch on the disc stops the laser
beam from being able to focus.
Dirt or a scratch on the disc hinders the track
Clean or replace scratched disk.
There ya go, clean or replace the cd that is displayed.
Nov 15, 2008 | Car Audio & Video
Getting ERR message on CD Player
My kids always cause this one ! Switch off power, remove cover. Remove four screws holding top black plastic disc cover and then remove all of the black plastic ( x 7 ) disc holders. You may find that the aluminium cross structure has come adrift. Replace into the slots again and replace all the disc holders. If you want, you can check before replacing cover, by then ejecting and 'disc skipping'. It should thne be ok. If it has been forced, the aluminium cross structure thing may have also come out of the slot it should in in on the right hand side. Slide the disc frame in or out until it can be fitted and retest.
Jan 14, 2008 | Teac PD-H570 7-Disc CD Changer
"Err" message
i had err 2 screen. removed case (about 10 screws, took just a few minutes) and found 1 disc was had been knocked out of the tray. removed all discs. replaced case. works fine again
Dec 29, 2007 | Denon DCM-280 5-Disc CD Changer
Car Audio & Video Logo
382 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
