Question about Kitchen Ranges
Dislodged oven door, can't re-attach.
Hotpoint electric stove, 20 years old. We accidentally dislodged oven door trying to move the stove. Now we can't re-attach the door. Can you help?
  • 3 Answers
All oven door hinges have small grove or tooth that must be engaged to opperate correctly.
Reinsert hinges one at a time, noting there is a small "tooth" or "gap" on each hinge.
This gap must engage with the lower part of opening in which you place door hinges. When you engage one tooth, do same on opposite hinge. Door now works correctly.
Posted on Apr 17, 2009
Top oven/grill. Element has dislodged from the screw connection. Attempted to screww back the element and there seems no thread for the screws to attach to the oven. What are my options?
Hello Michael Clift - I am happy to assist you. First, I will need your model number (and serial number if you have it) to better address the issue at hand. Thank you.
Jan 16, 2013 | Electrolux EOD6330 Ultrafan Electric...
I have a new (about 7 months old) SMEG SAP112-8 60cm Linear Pyrolytic Oven. The knob to turn the oven on does not seem to work. You usually push it in (and meet some resistance) to turn the oven on, then...
We have experienced the same problem. We have a service tech coming to fix it. The knob has come off. It seems that the internal spring has dislodged itself. This will be claimed under warranty. Ours is 5 months old. Our other Linear combo oven and coffee machine seem to be more solid/sturdy.
Dec 24, 2010 | Smeg Linear Pyrolitic Single Oven Electric
How long should I run the self cleaning on a HotPoint self cleaning oven. Its about 30 years old.
STOP... Please don't use that function on a stove that is this old. Is what I would like to say.... but I don't want to be an alarmist..
You see what the invoking of the "Self Clean" function does, is that it interlocks the doors, and heats the internal temperature up to an incredibly high temperature, far and above usual usage, this is to literally burn off anything.
Now what's wrong with that?. well usually even in the older modern ovens the Thermostat and or Thermistor and or the Door Interlocks, often fail, then or shortly thereafter rendering the stove up for a fix.
In a stove 30 years old, i would imagine all of those would eventuate? (Tongue in cheek) If the stove is in good condition, one should be Ok.
So if it were me, I dunno if I would risk it?. In saying this all, I guess the repairs that may have to be done, are NOT that major, nor too expensive, and IF these parts fail, then I guess they would maybe fail sooner or later anyway, but I know for a fact that the doing of this self clean, can be thwart with disaster.
I feel it is my duty to warn you of this eventuality, so that if you do proceed, then you are forearmed with the knowledge.
As for, the answer to the question, how long should one "Run" the self clean for. Well this is usually determined by the unit itself, you will know when it has finished, when, the door interlocks release and you are able to open the door. This can be up to 6 - 8 - 12 HOURS later in some case, (You would have to check your manual) I guess it takes quite a while to cool down from around 900 degrees!
Sep 22, 2010 | Hotpoint RB757 Electric Kitchen Range
Husband removed oven door when fully open instead of when 1/4 open as the manual suggests, now the door clicks a couple times as it is nearly closed, model number 95592 Kenmore electric smoothtop range...
Try removing and refitting it a few times otherwise you will probably have to get new door latching mechanisms. You may just be lucky that they have been dislodged but they are most likely to have been broken. The clicking is the door interlock mechanism trying to lock and unless it succeeds the oven will not work.
Oct 24, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
Hotpoint self-cleaning oven will not release door latch and open.
no you will have to replace the catch if its more than 20 years old maybe you should think about buying a new oven
Sep 27, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Hot point oven 20 years old cleaned oven now door
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jun 15, 2009 | Hotpoint DY46 Style Line Stainless Steel...
HOtpoint Electric stove/oven
You have not responded to my clarification request, so I'm guessing that you have resolved this issue. If not, let me know if I can still be of assistance.
Aug 26, 2008 | Hotpoint RGB745 Gas Kitchen Range
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Main oven door does not shut properly
i removed the side panels which exposed the hinge mechanism. I have then removed the whole door and the associated hinges by simply unclipping the retaining springs.
Dismantling has revealed that the pivot pins have become dislodged from their housing, and this is why the door was not shutting properly. I am now spot welding the pins back into position.
Also noted is wear in the slots in which the pins rotate but am hoping that it is all still serviceable as I think spares for Stoves are expensive.
One other point to note is the very poor design of the whole hinge assembly. Not what I expected from Stoves.
Jul 31, 2008 | Stoves 720EF Electric Double Oven
Kenmore Electric Range - Door handle
I had the same problem with my stove. I tried to replace, glue the srews and other things, but nothing really worked well. It's a shame that Kennmore has such a design flaw in their stoves, but did nothing to help their customers.
Here is the solution that worked for me:
Fix the thread with helicoils (these are inserts that create a new threat in the handle). You can find the instructions how to use the helicoils on Youtube.
I replaced the crews with new screws that fit to the helicoil threat and now the handle is safely secured.
Regards
Michael
Jan 03, 2008 | Kenmore 96213 Electric Kitchen Range
Kitchen Ranges Logo
495 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
