Question about Fujitsu Siemens Pocket LOOX T830 Smartphone
T830 flash rom
Hi i'd like to inquire about original flash rom of t830. my phone is not working since i installed t830 flash update,even if ive done a had reset, the screen displays 'flash update error; please re-flash the image'. unfortunately ive done the update for so many times. but it didnt' work. please help . thank you and more power
  • 2 more comments
  • boomski Nov 06, 2007
    thank you. i really appreciate your mail. i will wait for the information. thanks Lukepok
  • nZito Dec 14, 2007
    Hi
    I have the same problem.
  • Lajka Jan 05, 2008
    I have same problem.
  • qusyairi May 21, 2008
    have the same problem. try using the flash boot still unable to flash
I to all, sorry for my english. I have resolved this problem, with the PocketLOOX8xxFlashTool.exe. The tool first try to connect to the T830, then it show you how to reset the PocketLoox to reflash it. The sequence is:
1) Reset by pressing Power Button + camera button + factory reset; 2) insert the usb cable in the T830 or insert it in the docking with the Power Button + camera button pressed. When you insert the usb cable, on the screen it show a new message "New USB download mode". Now PocketLOOX8xxFlashTool.exe can connect to your t830 and reflash it.
Good luck
Giancarlo
Posted on Jun 03, 2008
  • 3 Answers
Check the xda-developers-forum for help and -for example-
the new Windows Mobile 6 (unofficial!) Rom for t830/ t810:
http://forum.xda-developers.com/showthread.php?t=336328
You also find there updates for flashing with sd-card, maybe this
works..?
Good luck by bringing your excellent phone back to life!
Posted on Mar 16, 2008
Pls help me i have the same problem [email protected]
Posted on Jan 11, 2008
SOURCE:
I want to restore my stock rom (galaxy y)
If you want to restore your original rom make a update to your phone (Samsung kiss)
If you want to restore some apps use titanum backup
Nov 01, 2012 | Cell Phones
Hi. What is this ROM flashing about?
Flashing a ROM indicates that you taking an Operating System and are installing it on a phone. This replaces the current system files on a device with the new system files of the Operating System being flashed.
In the Android world you would generally be installing a custom Operating System that is a different version than the one originally on your phone, the same version with custom enhancements, or the same version being installed to correct possible problems with the phone.
Hope this helps
Justin
May 01, 2011 | Google Android
Change language from italian to english.. htc tyn II pro, thank you
Hi there!
You'll need to follow this steps to change the language of your HTC TyTN II
<p>1. Make sure you install Microsoft ActiveSync in your computer. Do a first time sync between your phone and the computer.</p><p> 2. Disable any screensaver and/or hibernation in your computer.</p><p> 3. Sync and again and flash with the HardSPL rom from OliNex. You can find this HardSPL software from here >> http://wiki.xda-developers.com/uploads/Unsigned_HardSPL_for_Blackstone_OliNex.zip The flashing completes in under 2 minutes.</p><p> 4. Reboot device. TouchFlo3D will launch into the native language the device originally came in. The new rom now enables you to flash other language roms, even official ones from HTC, bypassing licensing and verification checks (of course you should have the relevant ROM).</p><p> 5. Finally, flash again with the newset WWE (World Wide English ROM. You can download the official English ROM here: http://www.htc.com/hk-en/supportdownload.aspx?p_id=13&cat=2&dl_id=287</p><p> 6. Device reboots in english, or the language of the ROM you flashed.</p>
Take note that by doing this, the warranty of your phone will be voided.
Hope this helps
Apr 28, 2011 | HTC TyTN II Smartphone
My ro0ted m0tor0la citrus is stuck in a bo0t loop after i used rom manager 2 change the font. i didnt kn0w 2 flash my stock rom b4 doing this. ive tried factory reset, wipe cache, and recover update.zip....
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | Motorola Mobility CITRUS Smartphone
Mobile hung on align screen page despite aligning screen several times. mobile was working fine. suddenly system was hung. tried to hard format using call and end button on start up page. ever since the...
Please try this with windows XP
Make sure you:
Turned off any Firewall you have on the PC.
Not running the update in Safe Mode.
Not to perform any other work on your PC.
Make sure the phone is fully charged (important)
Do not update from a PC where you have limited rights. Eg. Internet Cafe, Work etc.
Prefer Laptop as if you have electricity dropped you will have some extra battery and wont harm your phone.
Use only one USB port for you Omnia update, the best one it works for you. Do not try multiple.
Steps used for updating under Windows XP (32 bit).
  1. Make the Install Microsoft ActiveSync 4.5 (once)
  2. Make Install the Samsung Modem Driver XP (once)
  3. http://rapidshare.com/files/179674742/MODEM_DRIVER_FOR_XP.zip
  4. Reboot the PC.
  5. After the first 2 steps try to disconnect your Omnia from USB and connect it back on. Repeat it 1-2 times so the PC can recognize the phone.
    Leave the phone connected for about 10-15 minutes. If it disconnects by itself most probably you have to repeat the procedure from 1st step.
    It is advised to reboot your PC also.
  6. Make sure that have backup all your important stuff (contacts, pictures etc).
  7. Switch OFF the phone by holding the Power button for ~5 seconds.
  8. Run the updater. (Works the same way for Original or Cooked ROMs)
  9. Switch ON the phone again by holding the Power button.
  10. Press START and happy flashing. Do not move your phone or the USB wire as it might fail during flashing.
  11. Wait until the updater shows JOB DONE! DO NOT DISCONNECT BEFORE.
  12. Disconnect your phone.
  13. Leave the phone to reboot 2 times, calibrate screen and finish the start-up procedure.
  14. Enjoy the new firmware.
This is for windows 7 and vista
Things you'll need on Vista:
VMware Workstation (latest will work)
Microsoft Windows XP CD or .ISO image and the serial key
2gb of free disk spaceSafety Tips before starting:
Use the ones that mentioned for Windows XP.
Make sure you turn off the USB on the Windows Mobile Device
Center.How-to disable it. Go to Windows Mobile Device Center:
Mobile Settings -> Connection Settings -> Untick "Allow USB Connections".
After flashing tick it back.Let's start:
  • First install VMware's Workstation. You can get a trial version at http://www.vmware.com/
  • If you have an .ISO image of your Windows XP CD on your hard disk like I do, you won't need the CD, otherwise you'll need it. If you don't have the image, put the CD into your CD/DVD-ROM.
  • Run the workstation.
  • Go to FILE -> NEW -> VIRTUAL MACHINE and choose TYPICAL. On the next tab select the source from where you want to install a virtual Windows XP operating system (CD or image).
  • On the next tab, press next. When the dialog appears, choose YES.
  • Now enter a name for your virtual XP machine and choose a location where you want to save the machine - it's good to have at least 2gb of free space!
  • On the nex tab, I've chosen 2.5gb. I think that's enough, if you wish only to flash your ROM. You can choose to install the machine to a single file or splitted. I've chosen single.
  • On the next tab, click Customize Hardware button and select "USB Controller". Make sure High-Speed USB 2.0 and Auto connect USB devices are checked. Press OK, then press FINISH.
  • Maybe you'll get a warning from VMware but don't bother, just skip it.
  • The Windows installation process should follow. The installation took on my PC for about 25min.
  • When the setup has finished, you can normally run and use Windows XP via WMware.
  • Update your XP machine via Windows Update, reboot and start flashing.
Flashing:
  3. Reboot the PC.
  4. After the first 2 steps try to disconnect your Omnia from USB and connect it back on. Repeat it 1-2 times so the PC can recognize the phone.
  5. Make sure that have backup all your important stuff (contacts, pictures etc).
  6. Switch OFF the phone by holding the Power button for ~5 seconds.
  7. Run the updater. (Works the same way for Original or Cooked ROMs)
  8. Switch ON the phone again by holding the Power button.
  9. Press START and happy flashing. Do not move your phone or the USB wire as it might fail during flashing.
  10. Wait until the updater shows JOB DONE! DO NOT DISCONNECT BEFORE.
  11. Disconnect your phone.
  12. Leave the phone to reboot 2 times, calibrate screen and finish the start-up procedure.
  13. Enjoy the new firmware.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 29, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
BIOS 1004 cpu not support
I got it :-)
Damn Asus , it was a hard session ;-)
1. Make an ISO from your original Asus CD denn insert (with isobuster or something) the Bios Firmware 1004 in the main Dir name the file M2N-MX.ROM
2.Burn a Second disc with the 0804 Bios ROM also rename the 0804 Rom to M2N-MX.ROM
3. Go to EZ FLASH with ALT + F2 and then insert the 1004 CD wait till Erasing is ready Then Turn OFF your PC :-) so you crashed the bios thats what you need to run the embeded CrashFRee Tool
4 After you turn your PC on insert the 0804 CD then it flashes the this Rom and we are Happy :-)
mfg Eddi Hope this helps someone
Apr 16, 2008 | ASUS M2N-MX Motherboard
How to Flash nokia3230 phone Rom and update its software?
hi vjvinayak,
according to maklean, may be it not be possible to upgrade firmware by ourselves. But, damnly it is not necessary to buy 3rd party flashers because it can be done by ourselves easily also.
Process for it is :
1) if u want to save ur data, then backup it 1st in ur MMC.
2) turn off the phone.
3) press and hold 3 buttons ( green dial button + * + 3 keypad ) at once and turn on the phone.
4) hold those buttons until formatting screen appears.
5) when it is completed, phone is to be restarted.
6) and my work is finished.
I guarantee u that this method will flash ur phone rom.
If u like this method, send me feedback. I will help u in other cases also. I have a large database of codes or tricks to use in mobile phones.
Sajan
mine id is [email protected] & [email protected]
Jan 15, 2008 | Nokia 3230
Ipaq 4150 dead after computer crash during ROM upgrade
Put it on bootloader then try to update it again.if its not work then you have to find a same device and copy rom image to sd card then you can flash from sd card to your bricket with bootloader....good luck
Oct 07, 2007 | Orange SPV M1000
Dead PC
Hi, When flashing a BIOS, you would need a bootable diskette (or CD) with basic DOS and the ROM .bin or BIOS update files plus the flashing software. In the CMOS/BIOS setup, you have to instruct the computer to boot first from the floppy diskdrive (or the CD as the case may be). Then run the flashing software/application and type in the filename of the new BIOS. Most modern motherboards no longer uses jumper switches to allow/disallow BIOS writing/update. If for some reason there are jumper switches, perhaps we can confirm if you would post the brand/model/version of the motherboard/computer. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 09, 2007 | E-Machines C1641 PC Desktop
Fujitsu Siemens Pocket LOOX T830 Smartphone Logo
1,896 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Ekse
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
