Question about RTO Pump Volute, Acura, Maverick,No IMP
We have a Acura Spa System & need help with heating.
We can not figure out how to start the heater, it is on a 7day or 24 HR time clock. We really don't have any good instructions. Thanks for help. Frustrated
    New Friend:
  • 77 Answers
Call Acura spa tech dept. at 951-684-6667. Have the model of your control pack avilable.They will answer your question direct you to a download of the proper manual.
Posted on Apr 22, 2009
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
How to wire a T174 intermatic time switch timer
Intermatic T174 wires exactly like the T104 240Volt timer.
Only difference between T174 ans T104 is the day skipper wheel on T174.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
These timers are very versatile and can be wired many ways, and changed to control different voltages by changing clock motor wires, or changing clock motor.
Voltages include typical 240Volt. But also 277V, 480V, 120V, 208V and 24Volt
Oct 25, 2012 | Intermatic T174 24 Hr 40 Amps Timer Switch...
Hi - My Intermatic T101P3 timer motor stops after it turns off the pool pump. I have one start and one stop time in a 24 hr period. I have to manually start the pump at the timer in the morning,...
Sounds like the clock leads are on the wrong posts, or at least the hot one is. If if was moved to the load side then manually starting the timer will also power up the clock motor. As soon as the clock trips the off timer, the pump and the clock motor are both off. Examine the clock leads to the wiring diagram inside the clock box cover to ensure they are connected correctly. I bet you'll find one of the wires is misplaced.
John
Aug 31, 2011 | Intermatic T101P3 Pool Timer IndoorOutdoor...
I have a blue hat toy co. time and space projection alarm clock. it says it is a 12/24 hr clock but we can only show military time. is there anyway to just show the 12 hr clock. it is confusing to my son....
We also purchased the same alarm clock and I accidentally figured out how to convert to 12 hour (AM/PM) format from 24 hour format. Once the time is set correctly, and you are out of the time set mode, you can press the UP key and it will toggle between the formats.
Dec 26, 2010 | Sharper Image Blue Hat Toy Company Kids...
How do you set the clock for 12 hr time, not 24 hour ??
On most clock radios, there is a Time button. Usually, just hold it down while adjusting the Hr. or Min. I have not seen too many clock radios that do not use that kind of setup.
Oct 28, 2009 | Audio Players & Recorders
Jandy Aqualink RS4 randomly turns on blower, pump, heater
I have has to deal with the same problem and have found that the spa switch is causing the problem. When I went into the lockout controls menu and locked out the spa switch I no longer had the problem. Once I figured this out and determined the spa switch was faulty I replaced the spa switch and everything is work correctly now.
Oct 09, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Changing from 24 hr system to 12 hr system
  • Press "MODE" (lower left hand button) three times to get to the screen where the numbers are blinking, indicating that you can adjust the time
  • Make note of the hour if you don't have another clock handy
  • Press "LAP/RST" (lower right hand button) once to get the hour numbers to blink, indicating that you can change them
  • Press "ST/STP" (upper right hand button) to move the hour forward until you go past 24
  • At this point, you will notice a little "A" next to the time to indicate AM, and if you keep going past 12 hours, it will cycle back to 1, this time with a "P" next to it to indicate PM
Apr 18, 2009 | Lucien Piccard 26024 Wrist Watch
I have an acura spa system. I need to know how to
How to replace 2 filters in above ground spa
Apr 17, 2009 | Pool & Spa
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
RTO Pump Volute, Acura, Maverick,No IMP Logo
608 people viewed this question
Top RTO Pool & Spa Experts
john h
old fart58
Craig Butler
Craig Butler
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
