Question about Cell Phones
Cracked touch screen i9 phone
I cracked my screen on my i9 need replacement parts. where do i find them???
  • karlamoreno0 Apr 28, 2009
    my screen is broken i need help finding new or used screen
    Problem Solver:
  • 19 Answers
The I9 has a defect. The outer screen, which is glued, does not allow for expansion. My screen cracked after only a week of light use. My phone was NEVER DROPPED, and developed a small crack near the edge. Within two hours, the crack expanded to the other side of the screen. The phone i have was manufactured in the same month I got it. Motorola has some issues with their warranty system, and it only works sporatically. This phone will most likely be recalled.
Posted on Jun 30, 2009
Ebay has a bunch of replacement glass you can buy... I see that they range from 5.99 to 9.99 ... I need 1 as well!
Posted on Jul 13, 2010
A few easy steps to replacing the screen on the sci phone or i9 or 168+.
1. turn over the sci phone
2. take the battery case off
3. take out the battery, sim card, memory chip
4. take out the two screws on both sides at the bottom by the sim and memory card one has white on top of it by memory card
5. there are two snap pins on both side close to middle
6. to get them out, pull inside outward they will release and pull up
7. take back panel off, be careful the side volume button is going to fall out
8. take out the inside panel, by pulling the pins on each side (one in top left and bottom right) holding all the computer chip in place
9. open it and you will see the screen that's cracked (inner and outer) this if for outer
10. lightly push the outer screen out, the only thing holding it in-place is glue.
11. to get the new screen in replace with old, but new has to be soldered together, at the bottom
Posted on Jan 31, 2010
  • albert_tequi Feb 01, 2011
    a few easy steps to replacing the screen on the sci phone or i9 or 168 .
    10. you need a heat gun to heat the front screen carefully and with a little spatula separate the screen front the phone be careful other ways you will brake the flex (it's a jello tape or google it ok ) take your time and reheat the screen as many times you need ,ones you take out the screen carefully remove the flex and replaced on the new screen
    11. get the new screen in, replace and put everything back thanks
    .........................thanks to the guy who put this guide l a broke my flex and i have to bot a new one ..............that's why I correct this sheet ..............guide ....so be careful ............just put attention on what you are doing okay and you will fix it with no problems see you soon
Want to send text message and pic from i9 motorola phone to computer
Posted on Nov 20, 2009
I have an Unlocked I68+ Touch Screen Cell Phone I9 AT&T T-mobile.Support GSM GPRS 850/900 / 1800 / 1900 MHz ,Can't work with 3G SIM card. Does anyone have any experience using using one of these as a...
What do you mean when you ask this question? You have 2 phone and all of them are not support 3G so you only can use it to connect wap via GPRS. I think I9 is better than I68+. All them are made in China, have touch screen!
Mar 14, 2010 | AT&T Cell Phones
I have a Sciphone i9+++ Touch Screen dont work
you should visit the repairing centre..
Jan 23, 2010 | Cell Phones
-cracked screen on i9 cell phone but I don't know if its the lcd or the touch screen.
if the screen it cracked that means its neither the LCD or anything. Its cracked.
Im not trying to be offensive or anything Im just saying.
Aug 06, 2009 | Cell Phones
Sci phone disabled touch screen
Hey.. The problem with the i68's and i9's (Or the other Sci versions of the CECT's is the flex cable connecting the digitizer to the mainboard.. It's a easy fix, and will cost you about $8 on Ebay.. Look for a replacement touchscreen for your model and order it.. then, google the phone model and find the directions on taking them apart.. I have successfully repaired about 50 of them so far.. :)
Hope that helps!!
May 14, 2009 | Cell Phones
Can't get into my i9 phone
send it back, these phones are COMPLETELY worthless wihout the touch screen. the person i bought my phone was always happy to helpme out, hopefully yours is too.
Apr 21, 2009 | Dual Electronics CECT P168 Cellular Phone
Free games for i9 phones
The CECT i9 and i68+ have JAVA. Unfortunately, most of the free JAVA games out there, are designed for keypad input. You will have to look for specifically "touch screen" apps and games. And among those, not all of them will work. I am afraid it's going to be "trial and error" for a while.
As for HOW to load the JAVA apps and games on your CECT i9, here's how:
On your computer, with the i9 plugged in with the USB cable, drag the JAR or JAD files into the "RECEIVED" folder. After you're finished with everything you want to add, disconnect the i9. Touch your DOCUMENTS button, then "memory card," then "received," you will see your JAR/JAD files listed. Touch the file you want to install. The next screen, choose INSTALL. It will bring you back to the menu choices of "phone" or "memory card." Choose PHONE and select YES. It should give you a message when it has successfully installed. Then exit out to the main screen, touch the JAVA button. Select "Installed Java Software" and you should be able to use your newly installed JAVA apps and games.
Hope that helps.
Dec 23, 2008 | Dual Electronics CECT P168 Cellular Phone
I want to load Games on to my cect i9 touch screen phone, can you
I'm sorry to say that that guy is wrong because the CECT i9 does have java depending on who you purchase it from. If you want proof go on youtube and look at some videos of people actually downloading java games to their phone.
Dec 22, 2008 | Dual Electronics CECT P168 Cellular Phone
Cracked Screen
check details from this website :
http://www.banggood.com/new-replacement-touch-sreen-lcd-for-cect-p168-p168c-p-2005.html
Dec 14, 2008 | Dual Electronics CECT P168 Cellular Phone
Cect I9
how can I download music and videos on my i9 phone
Oct 30, 2008 | Cell Phones
Cell Phones Logo
1,933 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
