Question about Toshiba 50H82 50" Rear Projection Television
Problems after convergance IC fix
I have a Toshiba 50H82 and ran into the convergance issue. I replaced the convergance ICs with stk394-160 but did not change any resistors.
When I buttoned everything up and powered on I had the following issues.
1) Still poor picture (as expected)
2) No Sound
3) Only buttons on front panel that work are power, Touch Focus, TV/Video and channel up.
4) Remote does not work.
The Menu & volume button may work, but not sure because when using TV/Video the inputs will change but the typical GUI doesn't come up. So with no sound and no way to see what menu is doing they may actually be working ... it's just an issue with the GUI not coming up.
Touch focus completes operation without an error message, so I took that as a good sign. But I need to get into service mode, but can't do that without the remote.
I have checked fuses 850, 851, and 852. All good. The resistors under the ICs appear to be fine also.
Any suggestions on what to try next?
  • 1 more comment
  • Zach Carroll Apr 17, 2009
    Thanks tviceman -
    Yes, the tv was competely working before I went in, with exception of convergance problem.
    You are correct, the OSD will not show up. So, no channel numbers, no volume indicator, and no OSD.
    When selecting ANT input there is white noise on screen. When selecting Color Stream input I get a picture, although a poor one.
    I would like to get to the manual convergance in service mode, but I can't get the remote to operate at all (TV/Video, Channel Up on remote will not work either).
    Sounds like a good starting point. Is the microprocessor you mentioned QA01?
    There are two OSD pins on the QA01 but they are both not connected in the schematic. There is a H_Sync, Sync_AV1, and Sync_VCD.
    Do you know which pin on the processor ties back to the flyback Xfmr?
  • Anonymous Apr 22, 2009
    las letras e imagenes se notan sombreadas en los bordes de otro color parece convergencia cuando apreto el boton toch focus s ejecutan dos lineas de barrido rojas despues sale en pantalla touch focos fallo agradeceria mucho su ayuda
    Novelist:
  • 159 Answers
Try not to mix areas in the tv chasing several problems.
  1. Lets get back: i hope the tv was doing fine before to start digging into it ( was it?) Was the tv complete tested before to make sure the buttons were working all and the audio was there. I mean each part of your tv has different solutions:
Think you have an animal with several heads now:
  • the buttons in the panel (some working is good! some others can be replace and there it go all panel works)
  • audio mute (maybe no signal and automatic mute is there. or maybe really audio is damaged. Leave it at the end is another area.
  • Touch focus is the the program controlling convergence digitally talking. If the tv is not yet fix with the amplifiers then the problem still landed in another area not in the digital control.
Finally Start over! Get into de convergence and get your three tubes at least close to convergence (forget auto focus now) three screens together or almost but three rectangules with white noise. No having GUI you mean OSD (i gess) (on screen display) channels appearing when you push that button or audio level line or menu letters (several buttons have to be touch to make sure of there is not OSD.
if the tv has not white noise the screens are without convergence. you are digging in a set with maybe 5 problems the three you told me plus the other posibilities im gessing and i hope you don't have. So slow down with the repair and try step by step. bye now.
Posted on Apr 17, 2009
  • jose martinez Apr 17, 2009
    The OSD problem is related to a resistor blown or different value. This line inicially comes from the flyback (the processor needs the last peak of horizontal trace to allow OSD explore following the erase pulse. I've seen the two scenarios, is just this pulse cannot go into the OSD pin in microprocessor (control) and changing these components and bang. The other bad scenario: if you have the pulse but micro is already out at least this pin, (you tell me you can get some switching (video 1 etc) is good answer to believe the micro can be ok..
    yes, you need a series of steps into the remote control to get convergence to software level.
    and finally if the remote send some commands (you) and the tv answer those keys at least one, thats' great! Look for another original remote control (needed to adjust convergence) I'll go remote control.
Blurry picture and purple and green color on top and bottom screen, cable channel indicatoe showing doubled
Tv have a problems known as a convergence problems,it dead.The tv convergence board,require 2 STK convergence ICS and some or all it resistors to be replaced to solved the convergence problems.The shop will,cost u $300-350 for parts and labors.
Aug 08, 2010 | Toshiba 50H82 50" Rear Projection...
Why is my toshiba tv showing double
The tv have a problems known as a Convergence problems,it dead.The tv convergence board require it 2 STK convergence ICS and some or all it resistors to be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Aug 03, 2010 | Toshiba 50H82 50" Rear Projection...
Color shadows
Tv have convergence problems.Ur tv have a "Hyper board" the tv Hyper board convergence are dead on it.The 2 STK convergence ICS and some or all it resistors are dead.Must changes these parts to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 25, 2010 | Toshiba 50H82 50" Rear Projection...
Will a REBUILT PTS PART number pd0637 toshiba hyper, number on part MVPU14 2L20DD work as a hyperboard in a 2002 50h82
Most of these hyperboard are inter changeable.But must Check the 2 STK convergence ICS munbers on the ICS parts have the same printed #---?
Apr 01, 2010 | Toshiba 50H82 50" Rear Projection...
Hi I have a toshiba 50h82 tv that is 7 years old with a convergence problem with the red and green lines that is going to cost $400 to fix but now that I am thinking about it before the convergence problem...
You are describing 2 different problems. The convergence problem can be fixed by either resoldering the convergence ICs or replacing them. These ICs cost about $25 each and there are 2. I suspect that the $4oo is for replacing the convergence board. This should not be necessary as the board can be fixed. Also, the brightness problem can be dirty CRTs, dirty mirror or faulty coolant fluid on the CRTs. If the picture was good prior to the convergence problem, the set is probably worth the repair if you can get the board fixed. While the board is being repaired, the service shop should be able to tell whether or not the brightness can be adjusted.
Dan
Oct 12, 2009 | Toshiba 50H82 50" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
42H83 Convergence
Yes the convergence ICs need to be replaced, however so dont the six 1.8 ohm 1watt resistors as Toshiba recomends replacing those six resistors when the ICs are changed. You can get the 50H71 / 50H82 Convergence repair kit as the 42H83 is identical to the 50H71 series, so the kit will work for your model. Heres the link where you can get the kit.
http://servicemanuals.vstore.ca/
Aug 10, 2008 | Toshiba 42H83 42" Rear Projection...
Convergence
you can replace these your self if you can solder and are mechanical. there are two stk ic attached to a silver heat shield
You can call or on line give them the model number and tell them you are looking for the convergence ics The part store .com
www.partstore.com
Be careful unplug if it looks to hard please call your local tv shop the fix for a shop is around 250.00
Thanks doctor video
May 20, 2008 | Toshiba 42H81 42" Rear Projection...
50h82 red convergence ic replacement
The quick answer is part number 23135090 from tritronicsinc.com or any nearby supplier. However, if the problem is intermittent (or even if it's not), you should be sure to check the solder connections along each end of the black or brown jumper wires near the IC's as they have caused problems in the past. Also, if the symptom you have is with the Red Convergence grid bowed at the top of screen, check Q783 p/n 23205037 as well. Good Luck and have Fun!
Feb 02, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
469 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
