AIKO TV problem
This AIKO TV Model A6910 - when switched on, the stby LED comes on and that's all, tries to press CH up or CH down but nothing happen. Appreciate any helps regards spvaka
Afasdfs
Posted on Feb 28, 2008
Thanks guys,
The TV is on and I can watch DVD on AV mode, I do not know how to switch to TV mode from AV mode. I tried to press CH UP or CH DOWN but no response at all. Thanks for any help.
Check voltage to Hor. driver TX (approx. 25v.) If not present check Q904 for S/C or leakage. It controls the regulator/switching transistor supplying hor. driver TX. I tried a 100ohm resistor from base to gnd overrode the bias (Q904) and set functioned normally.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
When switched on, the stby LED comes on it is indication that supply input is there. the problem could be in no output from regulated output supply in your tv. if it is ok then horizontal section is to be checked.
Posted on Sep 17, 2007
Power and opc bottom blinking, tv won't come on
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Jan 08, 2016 | Sharp Televison & Video
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
I have a Sharp 70" (LC-70LE632U) LED TV. When you turn it on, the front led is on, but no screen. After a few seconds, the front led starts 5 short and 2 longer blink and continue this way constantly.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location
Nov 12, 2015 | Sharp Aquos LC-70LE632U 70 Inch 1080p...
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Hi, I have the ESPN college gameday remote and I lost the manual. Could someone please give me the code for a sylvania tv? Thank you.
Manually turn of the device the user wish to power scan (TV,PVR,DVD,VCR etc.
For more than 3 seconds press and hold the appropriate device key. The LED comes On, indicating that the remote is in programming mode.
Press and release the Power key. The LED blinks once and stays on, indication that the Remote is in power scan state.
Press CH up or CH down key repeatedly untill the device switches ON.
When the devise turn ON, press and release the SELECT key to program the remote with the new code and exit.
Mar 26, 2011 | Televison & Video
The remote and control panel are locked on my 52" LED LCD tv.
Hello
To unlock the remote control function do the following.
On the front pane touch control pad
1 Press MENU to display the MENU screen, and then
press VOL[--/+] to select "System Options".
2 Press CH [UP/DOWN] to select "Operation Lock Out", and
then press INPUT.
3 Press CH UP/DOWN] to select "Off", and then press INPUT
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
OK.
Feb 16, 2011 | Sharp LC52LE810UN 52 in LCD TV
I have a rca truflat tv and when I plug it in the standby red light comes on but nothing happens when I hit the power button. I have tried holding down the ch- and vol- buttons at the same time and nothing...
I work on a lot of this model RCA, a reputable tv shop can repair this type of problem for less than a new set. You really need a techician for component level repair of this nature.
Jun 17, 2010 | Televison & Video
My aiko tv is stuck on child lock. I have no remote and dont know how to get the child lock off.
You can try turning it on and pressing all the buttons down at the same time, that sometimes will reset tv's to factory.
May 12, 2010 | Televison & Video
System won't power up
ITS BROKE - YOU HAVE TO GET IT FIXED OR THROW IT OUT. SAME THING HAPPENED TO US -UNDER WARRANTY BUT WE HAVE TO PAY THE $80 TO SHIP IT TO THEM. WHAT A FARSE.
Aug 04, 2008 | Olevia LT42HVi 42 in. LCD Television
Televison & Video Logo
176 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
