Problem with HP Operating Systems
Restore factory default on HP mini laptop.
14 Solutions
How to restore factory default on HP mini laptop? The laptop "mini 1120NR" got a preset owner name and password which I cannot change. Is there a way to restore it to its original factory default mode?
  • View Previous Comments...
  • avatar
    singher z Thanks for the help, but I tried and it didn't work because some F10 menu items cannot be reset (and not even selectable). So, I ended up downloading a OS restore file and created a reboot CD to repartition the whole thing, which of course erased everything previously installed. It seems the only way to go and now I got a clean PC basically.
    Hope this would help someone else. Basically HP mini cannot be reset on its own, but need a total OS restore.
    Apr 17, 2009
  • avatar
    singher z Sorry everyone that I don't have the solution to get back to mini original setting. What I ended up to do was finding a totally different OS (Ubuntu Linux) restore image to make a restore CD and then completely wipe out the mini HP OS and started totally fresh then.
    It seems the only way then for me to make using that mini pc possible. So, what I can suggest is that you too find some OS restore image file to make a restore CD and start from the scratch. You might be able to find a Windows restore image file to work with rather than a Linux one.
    Good luck guys!
    Aug 19, 2009
  • avatar
    singher z Hi, guys! I really don't have a way to restore the mini to the original factory setting. Instead, what I ended up doing was finding a different OS restore image file (Ubuntu Linux) to make a restore CD, which upon running a full partition wiped out HP mini OS completely and started fresh with Linux OS. It seemed for me as the only way to make it work then.
    So, my suggestion is that you search online to see if you can locate a Windows image file to make a restore disk, rather than Linux one. Just forget about the factory setting! It's really not worth it to spend over $100 for that, and I don't even like that HP mini's OS anyway, which is intended for totally PC dummies.
    Aug 20, 2009
  • avatar
    zayzay825 hello i put a background from goggle on my mini and i want the old background HOW DO I DO IT
    Nov 06, 2009
Operating Systems Logo
103,241 people viewed this problem
  • 154 people found this problem to be helpful.
  • 7 people are following this problem.
More Insights on Fixboard
14 Solutions
This solution has been voted best by the Fixya Commnunity
Hey guy's stop wasting your time on asking stupid questions! The hidden system recovery for HP mini 110 is this~
1st - Make it sure the Adapter and the Battery is already attached on your laptop.
2nd - Press the power button to turn it on.
3rd - When you see the HP logo on screen just easily press F6 rapidly.
4th - Stop pressing the F6 when the "Windows Starting" appears on.
5th - After that easily read all the useful instructions on how to system restore your HP mini 110.
Note: Don't mind the Dell, F10 or anything just do this ok?
Tech.Support ~ jhayr
  • avatar
    MX Geek Gal Thank you, thank you, thank you. This solution saved me big bucks to have someone else fix the netbook, and saved me hours of trying other solutions that were much more involved and destructive to the data. This worked like a charm, and I have restored and undone to the correct restore point, even though it does contain viruses and trojan horses. Note to self: make sure everyone in the house has a protected device, not just you - this was my husband's. Will get those bad bugs taken care of and hope all will be 100% again. Thanks!!!
    Nov 13, 2010
  • avatar
    lauw_bros Thank You Very much ^_^V
    Jan 12, 2011
  • avatar
    Timothy Owens omfg top of line fix bro ur awsome this works with all ur problems follow these steps its pro
    Sep 27, 2011
  • avatar
    Timothy Owens tytytytytytytytytytytytytytytytytyt omfg works like brand new this what ive been lookin for ur pro top line fix for all problems like no serial number no restore blue screens i hard more problems anyone on list this top line fix
    Sep 27, 2011
  • avatar
    petermbowen wow thanks man, nothing worked until i tried your solution, computer went back to factory restore point with free anti virus and everything. thank you!!!1.....
    May 08, 2012
  • hibatz
  • 1 solutions
  • Mar 26, 2010
I have the solution, fist connect the laptop to the ac adapter then turn it on and start pressing the F6 key (press then release, press then release a few times) then it will go to the recovery partition that is hidden, then just follow the on screen instructions. let me know if it works for you. or if you need more help contact me at hibatz@hotmail.com
  • avatar
    qdogstyle Thanks a Ton this was very helpful:)
    Mar 13, 2011
  • avatar
    timeteacher After all the websites, forums, HP technical guides, you are the genius. F6. The miracle button. Genius status to you. The HP mini notebook is different than other laptop/notebooks that use F11 guys. This person knows his stuff. Thank you hibatz.
    Mar 14, 2011
  • avatar
    gypsylove YOU PEOPLEARE ALL ON CRACK!!! DOES NOT WORK, YA DUMB A**'s
    Aug 15, 2011
  • avatar
    jordan_kantr your the dumb ****, it does work. assbag
    Nov 12, 2012
Mini DOES have factory restore capability, Press F11 repeatedly after restart (may need to go through HP's quickstart overlay 1st ie: start windows)
Then Recovery Manager loads and you can pick "Factory Image Recovery" or utilize other options.
info from: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00810334&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&document=&key=null&product=4041526#N128
  • avatar
    Mayoshaq Thank You! This was perfect
    Feb 21, 2011
  • avatar
    Steve Mather Yes. This is the druids we have been looking for. So simple a wookie could do it.
    Feb 28, 2013
SINGHERZ,
CAN YOU HELP ME RESTORE A HP MINI 110-1037NR BACK TO FACTORY SETTINGS? PLEASE GIVE ME A STEP BY STEP INSTRUCTION ON HOW YOU DID IT?
  • Mary
  • 81 solutions
  • Apr 17, 2009
Te mini should have a small hidden restore partition. Re-start the computer and press the F10 key when you see the HP start screen. this should take you into the HP recovery console. Follow the onscreen instructions to restore factory defaults.
Good Luck.
  • avatar
    jester12414 it's actually the F11 key.
    Nov 19, 2010
  • avatar
    Steve Mather Yes. This is the druids we have been looking for. F11 for the hp mini. So simple a wookie can do it.
    Feb 28, 2013
The recovery option comes when you press F5
Hibatz is right, bravo hibatz. Continuously clicking F6 just after turning on the computer resolves the problem. Thanks hibatz.
CTRL-F10 does the trick for systems made by Dell, maybe you need to do the same thing.
Pressing the F10 key or any other F# key does not provide restore options. I tried every F# key because I thought the same thing. I contacted Best Buy where it was purchased and they want $130 to restore the hard drive.
Going through some of these fixes with my HP 311-1037NR with built in verizon wireless aircard it seems f6 repeatedly openes th Memory diag. press and hold f10 opens the bios. PRESS AND HOLD F11 OPENS TH SYSTEM RECOVERY. In this the computer will format the hard drive reinstall the factory software. I takes a good while though and there is a option to back your stuff up.. but i did that way before trying to restore my laptop. Good Luck..
PS. dont forget to have your charger pluged in and do this as soon as you see HP
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01895783&lc=en&dlc=en&cc=us&product=4041526#RestoreWithinWindows
Hit F11 at start up.
Go to the website for the computer you need help on, they usually have the answers.
IT STILL HAS NOT FIX MY PROBLEM AS F 10 F6 AND F5 DONT WORK AND WHY SAY ITS DELL AS DELL DONT EVEN MAKE HP DAH
Hey I had this problem today and I have finally found the way to fix it!!!!
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-77449-1&lc=en&dlc=en&cc=us&lang=en&os=4062&product=4041502
Go to this site from a desk top and DOWNLOAD this program... you will need a USB flash Drive once finished DOWNLOADING you will then send it to your USB FLASH DRIVE then put that USB FLASH DRIVE into your laptop when it is powered off and turn it on it will start the process for you just be patient. You can then CREATE YOUR BACKUP and then continue on to RESTORE your laptop setting to a earlier setting you can choose the date your self. There is also other options there if RESTORE is not what you are looking for.
I hope this is usefull to you I did this and it worked also I did it because I could not get past the password as I did not know it...LOL.
  • avatar
    Vi teitsma was this free to down load ?
    Aug 10, 2012
My hp mini 110 doesn't do nothing only key that works is the f 10 and the esc menu and it's doesn't recover nor reboot. When I restart it its just hp then it goes black nothing no windows nothing what can I do ? I tried everything except slamming it on the floor ugh
  • avatar
    Humingbird34 any luck fixing it Minenanotuya?? my hp mini is doing the exact same thing, and to make matters worse i have lost my usb stick that had the recovery files on it so cant even try that! anyone help????? pleasssssssssssssse
    Feb 22, 2011
Add your solution
Full Name
Top HP Operating Systems Experts
Amit Joshi
  • Solutions: 51
  • Level: 1
  • Achievements: 1
Expert Badge
Are you a HP Operating System Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More Operating Systems Related Problems
Unsolved Problems:
Loading... Loading...
