Question about RCA DRC8300N DVD Recorder/VCR
I have a vhs/hq ..i have visual but no audio for a program i recorded last thursday. I tried recording from tv now and still no sound but picture. I played other movies or previous recorded things in vhs and it played both a & v. Please help with this problem. all advice is appreciated! RMS
  • 36 Answers
Try first to ensure that the scart lead at the back of the set or any AV leads that you are using are secure and tight.
Sometimes if the scart lead is not pushed home correctly it will lose audio. Try then to record a sample of video and try playback.
If there is still no sound try another scart lead first.
It will be a process of elimination I'm afraid.
Regards
Marc
Posted on Apr 17, 2009
I have a jvc HR XVC15u HOW TO RECORD FROM A VHS TO DVD CAN THIS BE DONE Panavision DMR-E55 How to recorder VHS RECORDER Slav R5UC HQ and SLV-975 Terry
If you have a VHS recorder available, there are inexpensive kits from Monoprice.com .
USB 2.0 Video Grabber with Audio
https://www.monoprice.com/product?p_id=5616
Go here. Approximately $10 or about.
Feb 17, 2018 | JVC Computers & Internet
Cannot get picture/menu on screen!
The Sony recorder is connected to the TV via the RCA cables (for both audio and video)? How many inputs does your TV have? One cable input and one RCA line in (making a total of two? Did you eliminate the possibility that the recorder might be defective by trying it on another TV?
Dec 25, 2007 | Sony RDR-VX555
In February, someone asked: "When
What are the tapes that you are trying to copy? are there genuine copies of films? YES THEY COULD BE COPY PROTECTED how they do that? simple they record the tape with the most minimum srength of signal, if you try to copy it you lose signal strength trough the copy process than the video looks a bit scrambled/discoloured and the sound is bad, if it's the case you could buy a video signal booster (if still available in stores) than you have to copy with a VCR that is separated from the DVD recorder so that you can install the booster from the output of the VCR to the input of the DVD recorder.
Hope it helps!
Jan 04, 2011 | Televison & Video
VHS to DVD: audio and visual dont match on playback
Hi, this is a problem with cramming too much info onto dvd.
For a good quality dvd, it needs to have about 1.5 to 2 hours of video on it. The more you put it the lower the quality it becomes. Don't forget though , it will never be better than the original.unless you have some specialist software to tidy up sound and flickers in the video.
So I would stick with one tape to one dvd if you want to keep the quality.
DVD's are cheap anyway, you can buy a spindle of 50 Verbatims for £10.
I hope this has helped you understand a little better, but if you need more assistance, then please ask.
Regards - Anthony
Feb 11, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Losing Audio Halfway Through Recording
The audio failure sounds more like a VHS player failure than a DVD software/recorder failure. Both audio and video are transferred at the same time to the DVD, and as long as the DVD recorder is working, that's really all there is. I would check the VHS player and confirm that the sound actually works all the way through.
Mar 02, 2017 | Pinnacle Dazzle DVD Recorder
Pictue but no audio on VHS playback..VHS record to DVD visual/no
Hi
please check the format settings, maybe the audio is not in good settiongs!~
Thanks!
Feb 01, 2009 | RCA DRC8300N DVD Recorder/VCR
No sound Problem - Philips VR550 VHS VCR
If your pre-recorded tapes also play without sound, then check the scart lead is in straight.
If not, then it's more likely to be a dirty audio head.
Try a VHS head cleaner tape.
May 20, 2008 | Philips VR550 VHS VCR
VHS playback - no picture
Do you have a scart lead connected ? if so it is not in properly, and it would not be channel c26, but the av channel on your TV that you would need to be on.
Feb 17, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
No sound on tape
hi , many faults for that 1- have you tried to play an old tape with sound to check that the video plays sound ?? if you have the sound of a previous tape then move to 2- from where you are recording if you are recording from tv rf channels then move to 3 or if you are recording from dve chek the audio connection that are coming from dvd to video and change it 3- the remaining last fault is you have a dirty audio head needs cleaning and if you don't know how to do so go to qualified person and if you are familiour with that open case and clean and if no refer to 5 5- the audio head it is a chrome cube with a black two thins lines in the right of the mechanism near the pinch roller rounded thing that draws the tape to move get a clean cloth and spread alchohol on it and rub the rectangle cube audio head up and down ovewr the two thin black things inside it please don't forget to do excelent rate cause i here to help you regards
May 06, 2007 | Aiwa VX-C131 13 in. Combo
RCA DRC8300N DVD Recorder/VCR Logo
94 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
