Question about Irons
Philips careeza soleplate cleaning
I have a philips iron, with a careea soleplate. something has stuck to the soleplate, possible froma printed t-shirt. how do i clean the soleplate to remove the stuff stuck onto it?
  • 1 more comment
  • Anonymous Mar 25, 2008
    NYLON
  • Anonymous Jan 09, 2009
    same problem, tried scouring pad, goobegone, nothing working; love this iron, it's a shark.
  • Anonymous Apr 01, 2014
    need to clean the soleplate
Change your iron
Posted on Oct 03, 2007
SOURCE:
The bottom of my rowenta focus has a burnt grainy film on it. How do I clean it and prevent it from happening again. I've only used it approx 4 times but it is over a year old.
Rowenta FOCUS STEAM IRON DZ5164 DZ5164U1 user manuals
will give their specific instructions.
Rowenta has a kit, including a paste cleaner for iron soleplates, available from Amazon.
Home made cleaners include a paste of baking soda and vinegar. Rub on, let sit, and wipe with a wet cloth. (Some add a drop or two of dawn dishwashing liquid)
Another home made cleaner is the Mr. Clean Magic eraser, thoroughly wet, and rubbed over the soleplate.
Make sure to wipe the soleplate with a clean wet cloth at the end to remove cleaning residue.
Clean your iron's soleplate while the iron is cold, and don't use something scratchy like a steel wool pad, to avoid scratching the surface.
Aug 11, 2017 | Rowenta Irons
Philips 6104 duble speed
follow this test and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the power cord and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber
If the iron produces too much or too little heat, test the power cord Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 29, 2013 | Philips HI-296 Iron
The steam button is stuck on (pushed in) but there's no steam.
follow this steps. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Nov 15, 2012 | Black & Decker Irons
How do you clean the soleplate? I have some residue/buildup that does not wipe off. I already did the self-clean to remove deposits but there is still "stuff" on the soleplate
You can use Rowenta Sole plate Cleaner. If you cannot find it locally, check online at retail sites like Amazon.
If you want to try a home made cleaner, Avoid abrasive cleaning powders or scouring pads.
Begin with a cold iron that is unplugged from the electrical outlet. Use a mild dish washing soap or laundry detergent to create a sudsy solution. Use a nylon mesh pad, sponge, or a clean cloth dipped in the solution to completely wipe off the soleplate of the iron. Wipe the soleplate clean with a damp cloth or rag.
If the soleplate is the victim of a starchy build up or corrosion of some form, you will need to use something a little stronger. Use a clean cloth dipped in white vinegar to remove the build up. Wipe the soleplate clean with a cloth dampened in clean water.
If this does not work, then you will need to heat a solution of white vinegar and salt until the salt dissolves. Using a clean cloth sipped in the heated solution, wipe the iron's soleplate clean. Continue wiping until you have removed all of the build up or corrosion. Remember to wipe the iron completely clean with a cloth dampened in clean water.
Let me know if you have any other questions. Thanks.
Read more: http://www.doityourself.com/stry/cleaniron#ixzz1L4J0N8Yh
May 01, 2011 | Rowenta DZ1700 Iron
Something burnt on the bottom of soleplate. Will not iron off.
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaning a Steam Iron Soleplate
heatman101
Nov 29, 2010 | Tefal Ultraglide 1549 Iron
How to clean a phillips gc 8320 steam iron
<div class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Hi,<br />Here is a tip that will help you with that problem...<br /><br />Cleaning a Steam Iron Soleplate</span></div> <div class="solution-text"><span><br /><a href="http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate" target="_blank">http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate</a></span></div><span> <div class="solution-text"><br />Cleaning a Steam Iron White Scale and Brown Water</div> <div class="solution-text"></span> </div> <div class="solution-text"><span><a href="http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown">http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown</a><br />heatman101</span> </div><!-- /solution text --><!-- helpful bar -->
Aug 26, 2010 | Philips Irons
Cleaning Carezza soleplate of iron
heatman101
Jul 06, 2010 | Philips GC 8220 Iron
How do I cal clean my Phillips iron please
heatman101
Mar 21, 2010 | Philips HI-296 Iron
Irons Logo
1,793 people viewed this question
Top Irons Experts
Marvin
Marvin
Are you an Iron Expert? Answer questions, earn points and help others
