Question about Sony PSP (Piano Black)
Black Screen Sony PSP (Piano black)
The green and orange light come on, but the screen remains black.
    Problem Solver:
  • 5 Answers
I think its bricked.If you can connect to the ac dc without the battery and the memory stick its semi bricked.If you dont have custom firmware then you need a pandora battery and a magic memory stick watch this video it gives all the information you need to unbrick it:http://www.youtube.com/watch?v=Y4sU9U8liik&feature=fvw
Posted on Sep 03, 2009
My sons psp has a black screen
Without a functional screen, the PSP doesn't have much of a purpose. If the power light next to your screen is off as well, all your PSP needs is a good long battery charge. But if the power light is on and the screen is still dark, a few quick troubleshooting steps can help you get to the root of the problem. If troubleshooting doesn't work, you will need to contact Sony eService through its support site, particularly if your PSP has recently been dropped or had liquid spilled on it.
Step 1Turn off your PSP. Remove the battery pack. Replace the battery pack, making sure that it is securely inserted. Turn the PSP back on. If the screen is still black, continue to Step 2.
Step 2Press any system button. If the backlight is turned off, pressing a system button should reactivate it. If the screen has turned back on, go to the PSP settings menu. Select "Power Save Settings." Select "Backlight Auto-Off." This option automatically turns off the screen if the PSP has been idle. If you do not wish to have this feature active, select "Off." If this step did not solve the problem, continue to Step 3.
Step 3Press the screen brightness button below the screen. This button is marked with a small donut-like icon. Pressing the button will incrementally increase the brightness of the screen. Holding down the button will turn off the backlight. It is possible that this button was accidentally pressed down after placing the PSP in a pocket or a backpack. If the screen remains black after the brightness has been increased to full, continue to Step 4 if your model of PSP is any but the PSP Go.
Step 4Open the top hatch on the PSP. This will eject the UMD disc. Only touch the UMD at the edges, as fingerprints can interfere with the disc's functionality. Clean the surface of the UMD with a clean, dry cloth. Do not clean the UMD with water or any other chemicals. If the disc looks scratched or damaged, this is likely the cause of the screen issue. Additionally, moisture can condense on the UMD if the PSP has undergone a recent temperature change, such as being brought into a warm house from a cold car. If the UMD looks wet, turn off the PSP and allow the UMD to air dry. Wait several hours before trying to restart your PSP.
Dec 27, 2011 | Sony PSP (Piano Black)
Im using psp 3001 with version 5.03 PROME-4 and Signed 5.03 HEN v7 PROBLEM: When i always turn ON my psp a. blackscreen only b. power light is on (GREEN LIGHT) c. shutdowns every 20 seconds...
hold SELECT and START and TRIANGLE and SQUARE = hold these 4 buttons while you start up the psp, hold until the psp shows a blank screen, then it will show the initial setup screen.
Mar 07, 2011 | Sony PSP (Piano Black)
My sony psp not work at all even screen also not display but battery charging ok
Just to be clear.
What happens when you turn the PSP on?
Green light come son for a few seconds then goes off?
Or no green light at all?
Oct 01, 2010 | Sony PSP (Piano Black)
Dropped my PSP and screen won't come on and power won't turn off. No sound or picture. Just blank screen and green power light.
Same thing with my friend. I'm gonna open it up and check for loose connections and if not im gonna try getting an LCD back light. I will email answer to you. Email me at ikilledhitleronthejohn@gmail.com. If you find problem first email me and vice versa :)
May 01, 2010 | Sony PSP (Piano Black)
My battery fell out while updating my psp, now the green light comes on but the screen stays blank!
Probably because some of the data got corrupted.
To reset to factory defaults (which is what I recommend doing), turn off your psp, hold start+select+square+triangle and then turn on your psp.
It should now boot up normally but with no data on it.
Apr 19, 2010 | Sony PSP (Piano Black)
My psp does not start it shows a green light but the screen will be black
You sir, are trying to get Custom Firmware.
Its because you cut your battery, and you need to get a new one. Then after that try to Format your Memory stick.
Apr 07, 2010 | Sony PSP (Piano Black)
Green light is on but not flashing. Its off and the problem is that we cant turn on.Baterry is fine, just no buttoms help to turn on, it doesnt help.what the problem could be?
If I understand right. Everytime you try turning the PSP on the screen stays blank /black. If so you will need to flash the console. Email me at mr_fix-it@live.co.uk if you need any more help.
Feb 13, 2010 | Sony PSP (Piano Black)
How do you turn a psp back on only the green light shows
Sorry about the problem you are having with your psp, meanwhile you can follow the simple steps that I'll outline below to see if the problem can be fixed.
Step 1. Switch off the psp and make sure it is not connected to any power source, then pull out the battery and fix it back.
Step 2. Switch it back on, and if it does show only the green light without having the screen come on, then i guess the screen could be damaged or other associated screen components.
Step 3. Don't open the psp because you are technical enough, please take it to a sony center closest to you and you'll have the screen changed or the associated component/componnts.
Regards
Jan 23, 2009 | Sony PSP (Piano Black)
Psp has black screen
its been bricked and needs to be rescued with service mode
May 05, 2008 | Sony PlayStation Portable (PSP) Console
Sony PSP (Piano Black) Logo
253 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
