Safemode continues to reload - no options work.
My 7330 GZ Gateway notebook - on starting up keeps reloading the safemode screen. None of the options work.
  • 4 more comments
  • Mojomom Apr 17, 2009
    F8 does not work. The options I have are :safemode, safemode with networking, safemode with command prompt, last known good configuration, and start windows normally. None of them work.
    I can press F11 for recovery but I don't want to erase everything if I can avoid it. And I don't know that would fix my problem.
    I'm not sure I can do that. How do you suggest to do boot to a windows installation disk? I have only cd-rom and a few card readers.
    Well, I tried your suggestion and it did not work. I could change my BIOS. The Windows screen opened and then it went back to my safe mode screen. This screen that keeps opening is the warning screen after you haven't closed down your computer properly. It says a recent hardware or software change could be responsible.
    I believe I changed the order in the BIOS to boot to the cd, but no repair option is appearing. So I must be still missing something.
  • Kenny Wilson May 11, 2010
    Can you get to the repair options by pressing F8? Tell me all the options you have used. We can help
  • 41 Answers
If you can still get into your operating system try a couple of things first. Even if it is safe mode.
Option1: Perform a system check for any harware failures (start>run>chkdisk /r) make sure you put a space after the chkdisk.
Option2: If oyur computer was running fine before any updates or software changes you can do a system restore. (start>all programs>accessories>system tools>system restore). Note: this will only work if you have a previously saved restore points.
Option3: Try running a virus scanner if you do not have one use this http://www.avast.com/.
Option4: You must have a copy of windows XP (I am assuming this is your operating system). Restart computer>wait for prompt to boot from cd>let the cd load and then go into repair (R)>hit enter for your partition (the one your os is installed on)>when you are in recovery console use this command "CD " make sure you put the space otherwise it will not reconize the command> then type fixmbr. This should restore your factory boot file that might have been corrupted.
I hope any of these options help you out. Let me know Thanks
Posted on Apr 17, 2009
    President:
  • 778 Answers
If you boot to a Windows installation disk and choose the Repair Option and press "R" for it, you may be able to fix your current installation without losing anything.
  • 1 more comment
  • Frank  Fernandez
    Frank Fernandez Apr 17, 2009
    You will need a Microsoft Windows Operating System installation CD in your CD drive on boot. If your BIOS is set to boot to CD before the hard drive (if not you can change the order in BIOS) then just look at the scree for the prompt to "hit any key to boot to this CD" and then continue to the repair option.
  • Frank  Fernandez
    You will have to change the boot order in BIOS to boot to the CD in order to attempt a Repair Install of your OS. You may have a hot key to press on boot to access a boot options dialogue, depending on your BIOS also.
    The "Press any key to boot to this CD" will only appear on the screen for about 3 seconds so don't look away when trying to boot to a disk.
  • Frank  Fernandez
    The repair option will only appear after booting to the Windows CD and loading of files is complete. Just follow along as if you are going to format/erase the drive and at a point before you actually re partition and format the Hard Drive you should arrive at a screen that offers the Repair Installation by pressing "R" on your keyboard.
Gateway 7330 gz shuts off or monitor flickers
This probably isn't a driver problem. Your backlight power cable is probably loose. You can tell by getting a flashlight and looking closely at your monitor while it's powered on. If you can see your desktop items then it's a backlight cable problem. I had the same problem with my Gateway. You can remove the front bezel from your display to get to the cable. I just pressed mine up into the display as much as possible and put a little hot glue on it to keep it from backing out. I never had the flickering problem again. Good luck.
Jan 28, 2013 | Gateway 7330GZ Notebook
Hi, i want to start up the gateway recovery from windows (not system boot) does this have the option to automatically backup my information? if it does, which folder the system back up? Thank you very...
Not possible, and before you start you need to create your "System Recovery Disk" before you continue, if you haven't done so...and you need to backup any data you wish to reload after your re-install
Mar 22, 2011 | Gateway MT3705 Notebook
Immediately goes to start windows/start windows in safe mode screen over and over. none of the options work.
a startup, press f8, choose start window normally. If it doesnt work. u have 2 reload the system
Nov 21, 2009 | Compaq Presario X1000 Notebook
Can't boot.
Simpliest solution is to do a system restore. Reload Windows.
Some people think this is lazy tech work so ill give you a few other options.
1.run a check disk from a boot disk
2.reload the windows files and hope the problem is just a missing file
there are probably a few other things you can try, I just cant think of what they are right now.
Jul 13, 2009 | HP Compaq dc5000 Intel Desktop PC - Intel...
Blank screen
When u power up the computer press "del" or F2 key then check your harddisk is detected or not.
Also load optimal defaults settings.
then restart the computer press F8 key then enter in enable vga mode.then change screen resolution to 1024*768.
Please let me know.
Jun 06, 2009 | Gateway 7330GZ Notebook
Always on safemode choices
reload windows save all data you can on another drive by taking old drive out getting a adapter online usually a mini 25 pin ata make sure one end is a big 25 pin ata and plug it into a desktop and copy what you want put it back in and reload by inserting a windows cd and pressing enter when asked
May 18, 2009 | Acer Aspire One PC Notebook
Dissassemble a gateway 7330 gz
well power button on the plastic or the real power button on the board??? have ya taken out the top plate off over the power button???
Nov 15, 2008 | Gateway 7330GZ Notebook
Gateway Notebook PC 7330 GZ Power Problem
The most common problem is the plastic that covers the switch breaks. It's a poor design. Take out two screws along the top edge from the bottom near the middle and pry off the keyboard access cover. Then take off the circuit board and you should be able to turn it on and off.
Jul 06, 2008 | Gateway (SL1450-30151382) PC Notebook
Power Led Problems
You need to change the battery
Mar 06, 2008 | Gateway 7330GZ Notebook
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
