Full load motor won't run trys but no speed
Full of water and clothes will not run hums
  • 1 more comment
  • Robert Siebenaler
    Robert Siebenaler Apr 17, 2009
    full of water and will not run hums '//// no clothes inside cycles perfect...
    Fagor
    Model FF-50
  • Robert Siebenaler
    Robert Siebenaler Apr 18, 2009
    front load
  • Robert Siebenaler
    Robert Siebenaler Apr 22, 2009
    no I am in Vanuatu S.Pacifac.. I believe it is French made
  • 686 Answers
POST MODEL NUMBER PLEASE
Posted on Apr 17, 2009
  • 1 more comment
  • James Chandler Apr 18, 2009
    is this top load or front load
  • James Chandler Apr 21, 2009
    are you inthe USA this does not seem to be a model we have here. Ive never heard of this I may not be able to help. What is the name brand?
  • James Chandler Apr 22, 2009
    I am sorry I cannot help you for I have never seen or heard of this type of washer. We do have front loads here in the U.S but I am positive they are built differently than the U.S models. Once again my apologies.
Won`t start to dry second load of clothes after the first. dryer humms?
If hum is coming from motor and it won't restart until it cools down, it usually means the motor is going bad and overheating. This could also be caused by excessive lint around motor area or blocked vent but usually the motor itself.
Mar 22, 2015 | LG Dryers
Whirlpool front load washer model WFW9050XW00 - Machine stopped still loaded and with door locked. I was able to unlock and remove clothes leaving water and heavy suds. Tried running drain-spin and...
Your pump is jammed with a blockage, remove the filter and check the pump behind it is revolving, usually a hair grip or button in there...remember the washer is full of water so you will have a lot of water coming out
Sep 05, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Condensor Fan won't stay running
Check capacitor if its good its the motor
Aug 30, 2012 | Gibson Heating & Cooling
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 21, 2012 | Kenmore 43142 Front Load Washer
After spin cycle clothes r still soaking wet. cleaned coin catcher. ideas???
If the spin cycle is kicking in, then you can be pretty sure that the water has all emptied from the drain cycle, otherwise it wouldn't start the spin. So the chances are the coin catcher clean was not going to be the fix. The Highest probability is simply a case of overload. If the load is to great and the balance is thrown off as a result then it won't get up to full speed (the motor has several windings, so it slowly steps up from a slow spin, then up a step, then another, then full speed. poor loads will cause it to fail to kick in the fastest spin. Having said this, if that's not the case, then I'm afraid to say you may well have a motor, or a controller module fault. If so, it could get expensive.
To test, run the shortest cycle you can with the machine empty. It will be a lot easier to hear and see this way. Make sure that you hear the empty pump eject the water and that you then hear it runn on a little after all the wayer is gone. This will show if it IS in fact enptying completely. Presuming it is, now watch and listen as the spin kicks in. Does it reach full speed when there is no load? If it does, then check the weight of your DRY load doesn't exceed the recommended load (remember a pound over weight will be several pounds overweight once wet!). If it doesn't get up to full speed with no clothes in it, I'm afraid its time to call an engineer.
Feb 09, 2011 | Washing Machines
Start of the cycle the drum will start to turn but just hums. trys to turn the other way and does the same. it will eventully stop and throw a LE code = over load and motor. All this with or with out...
sounds like if it hums something has the drum fouled if nothing catching the drum then i would say the motor is at fault sounds like the motor is trying to start off the running winding instead of the start winding or a starting capacitor on the motor is bad
Jan 24, 2011 | LG WM-1832C Front Load Washer
Wont start
Clean the trap. take off bottom cover and unscrew larege white stopper
Apr 11, 2010 | Kenmore 46462 Front Load Washer
Frigidaire Washer Model #WILL-1 - won't spin or pump out water
Can you access the location of you motor?
try to open the back and unscrew the cover and see if you can see the motor, try to start it but don't get near to much just enought to see if it is moving or not.
if it still running and rotating see the belt maybe it is too loose or maybe it is to tight,
But if it just humming, turn it off and unplug, see if you can rotate the motor with your hand, if you can then you'll need a starting capacitor, you got to buy one and install.
But if it is hard to turn even without a load, then you'll need to bring your motor to a service center to check for the bushing and shafting and lubrication.
your motor winding is still ok since you heard a humming sound, that problem would be the mechanical part.
Nov 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Mah2400aww
The problem is the washer is defective.
Jan 18, 2018 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
Top Washing Machines Experts
