Question about Pool & Spa
I have an acura spa system. I need to know how to
I have an acura spa system. I need to know how to set the heater on it to heat up the water.
How to replace 2 filters in above ground spa
Posted on Dec 11, 2010
Value position to heat pool
turn the valves so ALL the water goes through the heater and back to the pool
Apr 17, 2014 | Hayward Pool Products Pool & Spa
I have an Aqualink system, spa set to 104, it will heat to 94 and stay there, temp sensor is working, took water sensor out of line, plugged line, assumed heater would just keep heating, it did heat a
The heater may be wired just fine. The aqualink uses its water temp sensor to call for heat based on what you've set the thermostat to on the aqualink. However, most heaters have built in thermostats that over-ride the aqualink. Those thermostats come factory defaulted not to go over 94. Check your heaters manual on how to adjust the thermostat on the heater. Your heater should have its thermostats set to 104 and the aqualink will control the actual temp of the water by calling for heat based on what you've set the thermostat on the aqualink for. Hope this helps.
Oct 16, 2012 | Jandy Aqualink Rs4 One Touch Control...
GFI plug is heating up on spa causing motor to not come on
unless plug is bad u will need to check the motor or heater one of them is pulling high amps heating up plug--oil motor may help--but will need to check the amperage on the motor and or if heater is cause if no amp probe --when system is cooled plug in and turn down heat setting let motor for a while if plug heats up or motor goes off on over heat know problem is with motor or plug-if no change now add heater if plug gets hot and turns off when heater is applied know heater is problem
Jul 28, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Spa does not heat
Probably the same question but just in case...
First, test to see if power is getting to the element lead posts. You should have 230 VAC there if the heater is trying to work. If so, your element is bad and will need to be replaced. If not you will need to determine if a limit switch is tripped or bad, if the pressure switch is closing, and if the inline fuse has blown. Any one or combination of those failures will cause the heater to remain off.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Apr 21, 2010 | RTO Pump Volute, Acura, Maverick,No IMP
My spa will not heat. The heater shows that it's working but it will not heat the water.
When you say that the heater shows that it is working is it the heater that shows this or the Aqualink. If it is the aqualink it could be a temp sensor, probally the water sensor that is in a pipe comeing from the pump. But the first thing Iwant to think of is your temp is set on the Aqualink but the temp is not turned up on the heater. If your heater is not compatiable with the link you need to keep the thermostat at max and set to pool or spa to have it work. If it is compatiable it could be in the wireing between the two or you just may need to be sure the Aqualink is set to read and override the heater. Your menu can walk you through this or your book on the unit. Let me know how you do and we can check for further problems in your heater. If so let me know brand and model of same. Good luck.
Oct 24, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
We have a Acura Spa System & need help with heating.
Call Acura spa tech dept. at 951-684-6667. Have the model of your control pack avilable.They will answer your question direct you to a download of the proper manual.
Apr 17, 2009 | RTO Pump Volute, Acura, Maverick,No IMP
Heater will only heat spa water to luke warm.
sounds like it may be the thermostat on the heater. You are correct to check the filter first. if it is clean then it is probably the thermostat
Dec 19, 2008 | Jandy Laars Lt 250,000 Btu Heater
Pool & Spa Logo
136 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
