Question about GE Ovens
Have lost manual for ge range model # JBP30W0B4WW please advise how to set dials to clean oven thanks lmottaway
5 Suggested Answers
SOURCE: GE P7 Oven
I, too, have lost my manual and none of the timers work. I can never remember how long to run the clean cycle for, but will turn it off as it has been a little over 2hours and your post mentions 1.5hours.
I initiate the cleaning cycle by completing steps mentioned above and then turning the top dial (which has a clean range on it) clockwise until the clean light comes on. I then just time it by my watch to turn it all off. Then I wait a couple of hours before attempting to open the door. Don't forget to take the racks out, they are not suppose to go through the Clean cycle.
Good Luck,
Linda
Posted on Dec 20, 2007
  • 833 Answers
SOURCE: self cleaning oven instructions
Self cleans generally do a good ****on small messes in 2 -2.5 hours. Larger messes take 3. Leaving the racks in is okay...but they will likely lose their shiny appearance. Manuals are on the GE website.
Posted on Mar 09, 2008
SOURCE: lost manual for eaton/viking model # RS3025W-1.
set both knobs the temperature and the bake broil to the lock mode, set the time such as 3 to 4 hrs I think and hit start. You should then here the oven begin to lock.
Posted on Oct 16, 2009
SOURCE: I have an Ariston oven (model;208587057) but no manual
Hi
Press and hold the two buttons with the casserole dish on (one is crossed out) and use + or - to change the time.
Hope that helps.
Posted on Feb 22, 2010
My oven wont shut off and gets very hot way past set temp what up with this.
Good Morning Friend,
I understand that your Frigidaire electric oven, model# es 200/300, will not shut off. I also see that it gets very hot, way past the set temperature. First, make sure you have not put it into the self-cleaning cycle. If it is not in the self-cleaning cycle, I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, you will need to set the clock before starting any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
Range Cleaning Cycle not Working
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
TURNED THE OVEN TO "CLEAN" LAST NIGHT AND NOW THEY ARE FROZEN.... CANNOT GET THE DOORS TO OPEN AND THE DIALS ARE FROZEN AS IF THE OVEN THIKS IT IS IN CLEANING MODE... WE CANNOT FIND THE...
set the range as if you are setting it to clean and after you hear it cycle into clean then cancel and it should unlock ,,,, please remember to click on rating / thanks
Nov 27, 2008 | Frigidaire PLEB30T9FC Electric Double Oven
GE P7 Oven
Good Luck,
Linda
Nov 27, 2007 | GE JKP15 Electric Single Oven
Tappan Electric Oven
I have a Tappan double oven range. An older model #316065301
How do I operate the cleaning cycle? I set the start and stop times, Locked the door and switched to clean. The clean light comes on but it doesn't heat up much at all. Never locks. I have misplaced my instructions manual.
Any help would be appreciated.
Barbara
blueznmooz@aol.com
Nov 19, 2007 | Tappan 30IN ELEC IGNa Oven
Ovens Logo
108 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
