Nine Blinks- Replace D6116 and D6301 on the "G" board, do not solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
tv occasionally goes blank, it may return without any aid, but also may need to be turned off, then...
(More)
tv occasionally goes blank, it may return without any aid, but also may need to be turned off, then back on.
I have a 51" sony rear projection tv , it's about 6 years old, and it has thin red and green...
(More)
I have a 51" sony rear projection tv , it's about 6 years old, and it has thin red and green rainbow shaped lines across the screen , they show up mostly on a dark or black picture. Any help.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
