Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
The wash machine stops and the screen blinks F-21 and the wash machine does not drain. I did check to see if the drain was clogged and it is not Help
  • Anonymous Apr 21, 2009
The drain pump's filter most likely was clogged. You will need to open the front lower panel. It has 3 screws at the bottom near front edge. Once opened, you will see a white plastic cylinder with cover. Open it by turning counter clockwise and pull it. All the solid object that causes to clog the drain filter pump are there, coins, lint, etc...
Posted on May 08, 2009
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
A GE stackable washer/dryer that is stuck on spin?
Good Day,
your machine is normal is washing cycle?
if yes.do the same
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
Washing machine stop runnning with error f 21 what is it how can i fix it
The F21 error code means "long drain time" the reason it will not drain within the normal time is a clogged filter screen on the drain pump. The filter is pretty easy to clean,this tip i wrote will show ya how to clean it http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 16, 2011 | Whirlpool Washing Machines
What does f-21 means when it blinks and your washer machine stop
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Kenmore HE2 Plus Front Load Washer
HE 2plus problem
Hello, the F-21 blinking is an indication has a too long of a drain out condition, and what actually cause these is when the control call for the unit to drain and the water does not drain out in 8 minutes or less the unit will stop and flash F-21. So try checking the drain pump and pressure switch circuit.
Thanks
Jun 09, 2010 | Kenmore HE2 Plus Front Load Washer
Load stops and flashes F-21
F-21 is a code that indicates "long drain".Check the drain line for kinks or obstructions. Check the pump. Check eletrical connections at the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or a jammed impeller. Hope this helped and best wishes.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer has done GREAT for two years..now suddenly,
this means your drain pump is clogged--- there are 3 screws at the bottom of the lower front panel. Remove these screws and there is a drain pump cleanout located in the middle. Twist this off by hand can clean out the debris--- WATCH OUT LOTS OF WATER will come out so have towels ready.
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Message OE
OE : Drain Hose is Kinked or clogged or The Drain Filter is clogged - Clean and straighten the drain hose / clean the drain filter.
also do check for the pump blockage.
for more info on this check the following link
http://pastoralfarms.us/2008/04/21/lg-fl-washer-2277-oe-error/
Dec 23, 2008 | Washing Machines
Washing Machines Logo
50 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
