Question about Dell OptiPlex GX260 PC Desktop
I have a Dell Optiplex GX 260 that will not boot. I get two beeps and a message to press F1 to retry or F2 for setup. Also, back panel diagnostic lights are A.B,C green, D amber. Any ideas?
  • Vern_2010 Apr 17, 2009
    The only message is press F1 to retry boot or F2 to enter setup. I read that the diagnostic light pattern meant other failure, but there is no other message. I tried a different keyboard, but it didn't make a difference.
  • holly10284 Apr 29, 2009
    I am trying to reinstall the operating system. I went into the bios and set the boot sequence to boot CD-ROM first and HD second. I press F12 and choose to boot from IDE CD-ROM. I then receive the message 'strike F1 to retry boot or F2 for setup'. If I press F1 I receive the same message. If I press F2 I go into setup. Any advice?
  • 700 Answers
Try to set it to boot first in cdrom in bios setting then place a bootable cd in cd drive that will run in DOS mode. If this boots up with a command prompt. Then your hard drive has a fault, could be a corrupt files or missing files.
Post comment if it does not help so we can device another solution.
Posted on Apr 17, 2009
    Scholar:
  • 59 Answers
What exactly is in the message? It is important because this refers to "other failure" and it can be a bunch of stuff easily.
Try to use another keyboard and disconnect all peripherals except the keyboard. does it boot now?
if not type the message it shows on the screen...
I have an Optiplex GX 620 Mini Tower that displays a NIC failure error at boot. The error message reads "NIC failure. Press F1 to reboot or F2 to go in to setup." The PC did not boots
it means your hard disk is not detected by system, check all connections of hard disk, if problem remains check with another working hard disk
Jul 29, 2012 | Dell OptiPlex GX260 PC Desktop
I have a dell optiplex gx 270 when i start it say no boot device available press F1 to retry and F2 for setup in setup i am not able to locate where to check weather it is picking HD and CD...
one step you can check boot device menu by clicking f2
first boot device should be HDD hard drive
if it is also correct then surely the hard drive is faulty and you need to contact dell at 1-800-624-9896
Aug 16, 2011 | Dell OptiPlex GX270 PC Desktop
OptiPlex GX110 PC Desktop: Hello.. I'm having Dell Optiplex machine.When I t...
Generally an indication that the Hard Drive isn't detected
Things to check, go to BIOS F2, reset defaults and reboot, see if the HDD is seen. If it is, the battery on the motherboard is likely dead and needs replacement (Watch battery at Walmart, 3 dollars)
If the HDD doesn't detect after resetting the BIOS, then most likely a Hard Drive failure
May 18, 2010 | Dell OptiPlex GX110 PC Desktop
RAM installation
Hi hunter555,
First off, you've done a lot of work for nothing. What you need to do is put back the new memory. When the Dell Bios boots, it confirming that it has detected the new memory. What you need to do is hit the F1 key to reboot and continue on to the XP installation. When you open the case, it will say the same thing. Don't worry about it, it's only confirming that the case was opened. Typically, I shut off the case intrusion detection, only because I'm always adding things to the machines and it's just a extra step I have to take to boot. However, it's good to know that your bios is confirming that you've opened the case, and that you've put in new memory. You want to make sure that the setup recongizes the entire memory in the banks. So, go to the system information page and make sure that it's reading the original and the additional memory 256k you added. Otherwise your done.
Good Luck
Mark
Jan 14, 2009 | Dell Optiplex GX150 Tower Computer - 1GHz...
Hi from albania tech
Normally this is an indication of a failing hard drive.
Nov 18, 2008 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 PC Desktop wont boot
Your cd Rom is also not working properly
Jul 04, 2008 | Dell OptiPlex GX260 PC Desktop
1 beep and won't boot...Strike F1 to retry or F2 for setup utility
hi! i have a prob with my pc its an DELL GX OPTIPLEX 270. It doesn't work in the boot, it lunch me a message at the first screen (strike f1 to retry boot, f2 for utilities). I have try many solution but it doesn't work. So, plz if any one can help me to solve my pc.
i'm waiting for and thx.
Jun 13, 2007 | Dell OptiPlex GX110 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
1,146 people viewed this question
Alun Cox
