Question about Apple PowerBook G4 Mac Notebook
Freezing and forced restart
This has become annoyingly regular: working on the 15-inch G4 powerbook (aged 2, relatively heavy duty), it suddenly stops reacting to trackpad, mouse and keyboard ALTOGETHER (even forced shutdown or restart by command keys impossible). This tends to happen between, say, 20 minutes to an hour after start-up and regardless of applications launched. It is not a standard "freeze" in that running applications seem unaffected (eg iTunes or Real Player music keeps playing and cursor blinking), just no communication with the computer is possible. In some cases I ultimately get a dark-veiled screen with the white letters informing me in 5 languages I need to restart by the main switch button. In any case, eventually I have to just switch it off physically. In at least one case the problem remained even after the restart, but generally things go back to normal (only to recur one cycle later). I'd mainly like to find out whether this is a hardware or a software problem, and whether there are others with similar symptoms? Thanks!
    Problem Solver:
  • 12 Answers
This is definately a hardware problem. The screen telling you to restart that you described is known as a "Kernel Panic". This basically means that some component of the machine is so out of whack that the Mac OS can't control it. Hard to say exactly which component is causing this without going throught the whole process of elimination. Good Luck! -inky
Posted on Sep 19, 2007
Hi there
I just bought a mac book two weeks ago. everything was okay untill a few days ago.
Everything is fine still except for the letter keys on the keyboard which don't respond to any command i try to give to the computer.
All other keys are now operating on fn key. I really need help with this because i am doing a video and photo editing business with this laptop and now i am loosing a great deal of money.
2.1Ghz duo core processor. 1G ram. 120G hardrive.
Posted on Sep 20, 2008
SOURCE:
I have a Powerbook G4, and suddenly my airportcard stopped workin
OSX has become unreliable.
You could spend hours troubleshooting, or simply backup and re-install from disks, takes about 40 mins
Jun 20, 2010 | Apple PowerBook G4 Mac Notebook
MacBook won't recognize my Lacie Rugged Hard Disk. Disk utility will see it but won't verify it nor will it repair it. says it needs to be reformatted yet it won't even let me initialize it. it is brand...
Is your MacBook as fast as the Lacie Rugged Hard Disk is?
Because solid state drive wasn't available on MacBook Pro at the initial time when it launched. Hard drives on all current Apple laptops are equipped with Sudden Motion Sensor technology. In fact, the Apple laptops that came with Sudden Motion Sensor are: All Intel-based Apple portables such as the MacBook, MacBook Pro, MacBook Air, PowerBook G4 computers starting with PowerBook G4 (12-inch 1.5GHz), PowerBook G4 (15-inch 1.67/1.5GHz), PowerBook G4 (17-inch 1.67GHz), and iBook G4 computers starting with iBook G4 (Mid 2005) have Sudden Motion Sensor technology. You MacBook may not have come with that technology that could be the reason you are unable to connect it.
Sorry mate... too many limitations on
Feb 24, 2010 | LaCie Rugged All-Terrain (301017) Hard...
Powerbook G4 12" no video
Try this courtesy of your manufacturer
  1. If the computer is on, turn it off.
  2. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  3. Wait 5 seconds.
  4. Press the Power button to restart the computer.
If that doesnt work lemme know
Feb 03, 2010 | Apple PowerBook G4 Mac Notebook
Apple spinning, won't start
1. Let it spin for a while and see if it eventually gets to the desktop. Sometimes this will work.
2. Insert your Mac OS install disk, restart your computer (if you need to force it to quit first, push and hold the power button until it shuts off). Then when you restart, as soon as you hear the famous mac chime, press and hold the C key until the Mac OS disk starts to load the system on the disk. Once it reaches the install window, don't launch the install, but go to the top menu bar and locate the Disk Utilities App and launch it. Run a Verify, Repair and also a Repair Permissions. Once done, shut down and restart without holding the C key. You should be good to go.
These powerbook 15" models are awesome... keep it hummin!
Dec 14, 2009 | Apple Powerbook G4 15" Screen Mac...
Powerbook g4 Aluminum 15 LCD
it could be the inverter to the display, or the graphics chipset or the connection between them.
Nov 02, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Powerbook Aluminum G4 15 booting up problem
The backup battery connects directly to the logic board. From the symptoms you are describing (rather clearly, thank you), it seems apparent that your logic board may be faulty.
There are two more things you can try.
1) Reset Open Firmware: Unplug-replug your backup battery, then boot the system holding down Control-Option-O-F. Your machine will boot into Open Firmware. Type the following commands, pressing the "return" key at the end of each one:
reset-nvram
set-defaults
reset all
Your machine should restart at this point. If it starts successfully, you should be done. Otherwise,
2) Reset the Power Manager. Turn the machine all the way off (no power). Simultaneously press Shift-Control-Option-power button, then release. (Do not press the fn (Function) key during this sequence.) Wait five seconds, then press the power button. If it starts successfully, you should be done. Otherwise, you will need to see a man about a logic board, which is probably not a cost-effective repair on a 1GHz G4.
Nov 01, 2009 | Apple Powerbook G4 1.33GHz 512mb 60GB...
Restore CD
You don't need a "restore" cd.
You can just use any copy of Tiger.
Borrow one!
Jun 15, 2009 | Apple PowerBook G4 Mac Notebook
Colors on Mac G4 Powerbook display are severely distorted
Hi
Goto Apple>SystemPreferences>
in the System section choose UniveralAccess>Seeing and make sure it says Black on White is selected, that Use Grayscale is unchecked and contrast is set to Normal.
If it's not that then its your display and needs a service.
All the best
Sean
PiDigital
Dec 10, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple PowerBook G4 Mac Notebook Logo
351 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
