Question about Craftsman 25cc Gas Line Trimmer
Craftsman weedwacker keeps dying
My craftsman 32cc weedwacker dies on me when i go full throtle how do i fix that?
  • 3 more comments
  • larryf48 Apr 22, 2009
    how do I mix gas and oil for my weedeater/trimmer
  • saminky May 10, 2009
    I have the same problem with a 32cc Craftsman weedwhacker. I replaced the whole carb and it ran great for one day. I started it up this morning and the problem is back. I cleaned the muffler screen and cleaned everything in the fuel system before I bought the new carb, then bought a new gas can and mixed new super unleaded gas with a new bottle of oil right out of the store.
    It runs quite a while when I let it idle, but it will eventually die then, too.
  • Anonymous May 16, 2009
    I have a craftsman gas 30 cc weedeater. the fuel lines were split but how does one get the fuel filter back in the tank. The hole is offset inside the gas tank so how can I get it installed properly?
  • Anonymous May 17, 2009
    fuel lines devolved inside the gas tank, we replaced but now it just keeps stalling.
  • Anonymous Mar 28, 2014
    Replace throttle cable
  • 12 Answers
If the weedwacker runs OK on 1/2 choke or even better on full choke then most likely the cause is the carb gaskets are stiff and can no longer pump the fuel. Of course make sure the fuel lines are are the right ports (return and supply). While you have the carb apart clean all of the passages with carb cleaner.
Posted on May 15, 2009
  • 3 Answers
Hey, someone asked how to put the filter back on the tube. . i just did this today
What i did was use fish tank tubes and connected it pushing the tube all the way in ((really tight fit)) then when it hit the bottom i took a paper clip bent it like a hook and hooked the tube inside the fuel tank and pulled it out. I then placed the filter at the end of the tube and popped it back into the gas tank.
Now i have another problem but I won't hijack this thread.
Posted on Jun 02, 2009
My 32cc 4 cycle craftsman weedwacker won't run off choke
MORE THAN LIKELY YOU HAVE BEEN USEING ETHANOL FUEL NEED A METANOLE FUELCLEANER AT MOST AUTO PARTS SUPLYER THEY SELL A FUEL CLEANER FOR SMALL ENG. IF NOT THAT MAKE SURE FUEL LINE IS NOT CRACKED
Nov 15, 2011 | Garden
I had to replace the fuel lines on my craftsman 32cc weedwacker. I removed the throtle line from the carburator and now I can't figure out how to replace it. I would appreciate any help offered.
There should be a little hole on the carb linkage that is usually triangle shaped and the cable has a little "S" looking linkage on it work it into that hole on carb.Good Luck...
May 06, 2011 | Garden
Poulan 32cc multi-attatchment weedwacker will run with full choke. When you take choke off, it slowly dies. If you give it gas with the throttle trigger, it sounds like it's being muffled and then dies. ...
Try backing out high speed screw counter clock wise a guarter turn. Also check muffler for blockage. Spark arrester screen may be blocked. Remove screen, clean or replace. I use bernzomatic tourch to burn off deposits.
Oct 03, 2010 | Garden
Need to know the 2 cycle oil to gas ratio for a craftsman 32cc weedwacker trimmer
My Craftsman 31cc 2-Cycle Gas WeedWacker Model C216.51318 manual calls for a Fuel Mix (gas:oil) of 32:1
Jul 11, 2010 | Garden
Craftsman model 358.791042, gasoline weedwacker wont stay running
let it warm up first and then pull the trigger. if that doesnt work, it might be the diaphram . they are cheap.
May 10, 2010 | Garden
The high speed needle valve needs adjusting and it takes a special splined tool to adjust it. I currently am trying to find where I can purchase the tool to adjust the high and low carburator screws.
Mar 17, 2010 | Craftsman Garden
Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
6,708 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
