Question about Whirlpool LER5636P Electric Dryer
The black wire burnt off on the line going into the heating elem
Its an admiral (ade7005ayw) electric dryer. The wire burnt off at the connector going into the heating element from the motor. Is it possible that the element shorted out? If so do you know if i need to remove the drum to remove the element?
  • lakeshowkb8 Apr 25, 2009
    The same thing happened to me, i found the problem replace the connector and it burned out again. what could be causing this?
    the same thing happened to me i found the burnt wire changed the connector cleaned up the terminal and it worked for a day and burned again. what is causing this? bad element? bad wire?
  • 659 Answers
No, you do not need to remove the drum. But you will need to remove the cover from the blower assembly. Using a volt meter, check the elements continuity to determine if it is bad or good.
Posted on Apr 17, 2009
I have an admiral dryer, model #ade7005ayw, that will not tumble. the motor will spin manually and the belt is brand new and properly installed. what could cause this problem?
This Admiral site lets you select symptoms, offers solutions, has videos, and instructions, plus authentic parts for ordering.
Worth a look.
My ADE7005AYW Model Overview from PartSelect com
http://www.partselect.com/Models/ADE7005AYW/Symptoms/Will-not-tumble/
Feb 28, 2015 | Admiral Dryers
Converting 4 prong admiral ADE7005AYW to a 3 prong
Hi pete
Go to the following webpage and you will find the answers you are looking for.
Bud
Apr 24, 2013 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Where is the heating element located in an admiral model no. ADE7005AYW
Take a look at this video to show you how to open the cabinet. The element is on the lower right side.
Nov 05, 2012 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Maytag Dryer MDE3706AYW has a burnt black wire, did the wire just have a bad day or do I need to replace the heating element and the wire?
All should be good. I think the element had run on due to a bad hi-limit thermostat that you said you replaced.
Oct 17, 2012 | Maytag MDE3706 Electric Dryer
How do you get to the element on admiral dryer model ADE7005AYW
to start, you need to unplug the dryer, then remove the front panel and look at the rear left and you will see the element. remove the 2 connectors and 2 screws holding the element and to install your new one just reverse the procedure. be carefull not to touch the new heating element coils. your skin oils will shorten the life of the element. good luck to you.
Feb 05, 2011 | Admiral Washing Machines
I have an Admiral ADE7005AYW that will not start. We have checked the plug and it is fine but the dryer will not turn on or light up. What could be the problem?
I f the cord is ok where it connects inside the dryer then There are several other things that could cause this.
A couple of the more common things to check are:
1. You could have a defective door switch. you can check the switch with an ohm meter for continuity.
2. You could also have a bad thermal fuse.Also check this thermal fuse for continuity. this fuse shuts the dryer down if it over heated. if the thermal fuse is bad check your venting for blockage or crimping.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5176934
Jul 11, 2010 | Whirlpool LER5636P Electric Dryer
Can't open Admiral ADE7005AYW
Try sliding a thin putty knife rearward at each front corner of the top while lifting upward slightly. Shine a light into the joint and look for metal joining the two halves. Once the top is loose, look for screws in the inside front edges and lift up on the front panel to release. Make sure to pull the power plug while working in there.
Oct 22, 2009 | Whirlpool LER5636P Electric Dryer
Can't find the heating element on my admiral dryer ade7005ayw
Normal 0 Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the element on the right hand side. Plug the dryer in to test to see if there is 240V going to the element posts. If there is voltage, but no heat, change the element. If it does not, you need to test the thermostats for continuity. If any of the thermostats are open, replace it. I hope this helps you.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Jun 13, 2009 | Whirlpool LER5636P Electric Dryer
Heating element
Might I suggest this site if you are a do it your self.
http://www.appliancerepair.net/dryer.htm
You have to raise the top take off the front and the tub should come out. Wala the heating element. Hope this helped, if not let us know.
Mar 16, 2009 | Dryers
Whirlpool LER5636P Electric Dryer Logo
204 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
