My acer aspire 1 notebook was left running and after a while i tried to go on line and its saying server cannot be found.i went to preference and tried to click on network connections and nothing happens.
I rebooted the lappy as well as the router.The indicator lights up, informing me that the wireless is connected. The problem is the error message is saying server not found. I rebooted the lappy as well as the router.The indicator lights up, informing me that the wireless is connected. The problem is the error message is saying server not found.
You can't post conmments that contain an email address.
Check that your wifi connection is still connected, it may have timed out and needs to be manually reconnected. If not reboot the Router and the laptop.
Proxy - Go to Start > Control Panel > Internet Options > Connections > LAN settings. Remove Proxy server option. If this gets you on the internet go to next step.
IE - Go to http://support.microsoft.com/fixit/ Select Internet Explorer option. Select Fix performances, page... Select Crashes or errors. You now have an array of MS fixes, including an auto Fixit installation. This is a new and dynamic site. Respond back with feedback, and GL
Microsoft changed its log-in protocols since
the Aspire One was released and the version of Messenger installed is
unable to connect to the Microsoft servers.
You can get to the Live Update function by clicking on the settings
icon from the home page (bottom right of your screen) you will bring up
the settings window (obviously). Inside here, you will see the Live
update icon (mine’s on the bottom left next to Touchpad).
1. Make sure you’re connected to the Internet.
2. Click on the Live Update icon.
3. Click on “Update” and if there are any updates, they will be listed and you have the opportunity to install them all.
4. Click on Install and your Aspire One will automatically download and install the updates for your netbook.
tell me what you get. also try to disable the connection and then reenable the connection. I doubt that the manufacturer sells a linux system withe the drivers fully installed.
you didn't mention which version of windows are using so i am going to assume that you have windows XP if that is not the case then let me and i can provide you with an alternate solution.
1. click on the start button 2. click on run 3. type ncpa.cpl 4. right-click on local area connection(if using ethernet cable) 5. single-left-click on internet protocol (tcp/ip) 6. click on properties 7. click on set dns servers manually instead of obtaining automatically 8. enter 208.67.222.222 and 208.67.220.220 as the primary and secondary servers. 9. restart the computer
if it still doesn't work 1. click on the start button 2. click on run 3. type cmd 4. click ok 5. type nslookup www.google.com 6. hit enter
We
have been made aware of the network icon issue in Linpus Linux , and
have been provided with a temporary workaround, while the software
vendor investigates this issue. Please follow the steps below: 1. Open the terminal by "ALT+F2" and then type "terminal" ->Run. 2 Run "mv ~/.gconf/system/networking ~/" to clear all the root network connections.
There is one space between mv and ~ and one space between networking and ~
After doing this, it will not have "ANY" network connections that may have been previously setup in network manager. Reboot the unit and the network icon will appear. You will need to configure your network again.
Check the wireless card connections physically. I received a Aspire one that had a wire disconnected from the card itself. if that is in tack find out what driver you are using for your card using "lsmod" see if there are alternatives. Try a live boot USB linux and see if your wireless card functions under that if it doesn't it is hardware if it does it is software. I would switch to another linux like sabayon or ubuntu eeepc versions they function better. I run Sabayon on both of my netbooks. Ubuntu ha sbetter support though.
i have acer aspire 4715z madel notebook.i instal vista but it didn't acept drive (wifi did not detect).so ppease send vista drive particularely wifi drive.
