Question about Roper RES7646KQ Electric Dryer
Will start and run, but no heat.
The other day I went to use the dryer and it would not start. When my husband got home he went downstairs and changed the fuse in the circuit breaker. I pushed start and it ran for a few seconds and stopped again. I replaced the fuse once more and it is running, however there is no hot air, only cool. Is there are reset button, or what could this issue be? Are we better off to buy a new unit this one is about 7 years old.
  • 833 Answers
These units have two circuit breakers...generally hooked up in tandem. It is always possible that the heater element is out. Sometimes they open a breaker when they fail. If you see a wiring diagram on the back of the unit and are handy with a multimeter...available at the hardware store...you can trace this out. Remember to turn off the power if you do.
Posted on Dec 21, 2007
Enviro temp electric water heater started making the water TOO HOT. Is this dangerous? I'd like to get this fixed instead of replacing it if we don't have to. It has served us well up until now.
yes it is dangerous code allows up to and not exceeding 125 degrees. this link will point you in the right direction. I keep my water heater at 120 degrees
Aug 04, 2018 | Cars & Trucks
My dryer will not turn on
Several different possibilities. Tripped breaker, door switch, start switch, timer, motor, thermal fuse, and maybe more. Might need to call service for it.
Sep 09, 2017 | Dryers
Indesit is70c
its a saftey device, called a "thermodisk". It's purpose is to turn off the heating coil or stop gas flow in the event of over heating. If the thermodisk is bad, trying to over ride it (trying to get it to run) will trip the breaker. Its about 10 bucks and easy to replace.
Dec 31, 2013 | Dryers
Mdg2600bww is not ignighting, cleared ventline, turns on, just no heat
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Jul 02, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My maytag front load dryer turns on and runs,it does not blow any hot air
Jul 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Will not get hot
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker. Make sure that the lint filter and exhaust duct is clean.
Another common cause of a dryer failing to heat is a faulty heating element. You will need to replace it.
Rating the solution is highly appreciated
Jun 30, 2010 | Maytag SDE3606A Electric Dryer
I don't have heat to my dryer.
Make sure that Front of the dryer is not blocked, Air flow is needed to dry.
Another common cause of a dryer failing to heat is a faulty heating element.You will need to replace it.
Jun 29, 2010 | Kenmore Elite HE4 Electric Dryer
My dryer dont want to heat is electric dryer what you think it is
Rating the solution is highly appreciated.
Jun 26, 2010 | Whirlpool LER5636P Electric Dryer
DRYER WILL NOT HEAT
Jun 26, 2010 | Amana Dryers
Roper RES7646KQ Electric Dryer Logo
103 people viewed this question
Top Roper Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Roper Dryer Expert? Answer questions, earn points and help others
