Question about Apple eMac G4 Desktop
Cursor turns into spinning wheel everytime i click on something and spins awhile before loading
  • Apple Master
  • 3,866 Answers
This particular mac had problems with its capacitors bulging or even exploading causing irratic system failures, please check where you put you memory modules open that capartment and check for the mini can of soda looking capcitors it there bulging are leaking then your going to need a new logic board
Posted on Apr 22, 2009
1992 chevrolet 4X4 Z71
I believe that is standard for a stock 4X4, If you have true posi 4X4 all 4 wheels will turn at the same time in your case when the 2 spinning wheels spin under load the other 2 kick in
hope that helps you
Rob
Jan 08, 2014 | 1992 Chevrolet C1500
My wife restarted the rinse cycle to add fabric softener. Now the cycle timer isn't working. Washer will not drain OR spin. Everytime the timer gets to the spin cycle, it agitates instead. It is a...
Lay the drain hose down to floor level, and drain of the water into something.
Then try it on spin, if it spins o/k, then the pump or filter is probably blocked.
Hope this helps.
Jan 19, 2010 | Indesit W 123 Front Load Washer
The washer fills and drains, but won't agitate
sounds like the clutch is not properly engaging and if this is the case it usually meens it has to be replaced
Oct 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
My megawdss will not spin everytime can you help
I had this problem, may be an easy fix if similar issue: Remove back cover. Take a look at the underneath the drum towards the right hand side. There may be a hook on a wire hanging there. If it is just hanging, there, it should be hooked onto a grey coloured lever, which has a hole on the edge of it. This is the drum brake which during the spin cycle releases the brake allowing the washer to spin. Hook the hook onto this grey lever through the hole. Replace the back cover. Test the machine with a towel or something, allow it to fill a little, then jump to the spin setting and see if it spins. Worth a shot, these are great machines.
Sep 27, 2009 | Baumatic MEGAWDSS Front Load Washer /...
Hoover 600MB Top Loader, Won't Spin
I have the same problem. Just started missing the spin cycles and now I need to find which part to replace.
So far I think it could be: Aged contacts in the Timer, a faulty spin/no spin switch, or something to do with the brake/release mechanisms etc. ..I do know that the problem is electrical because everytime the motor starts the spin works fine; therefore eliminating in my opinion, the mechanical gearbox bits as a cause.
Jun 22, 2009 | Hoover HTC243 Top Load Washer
Referral from Ekse. DLP Samsung spinning noise
the most likely cause would be either the color wheel or the cooling fan. If you listen at the rear cover can you dtermine where the noise is loudest? does the noise instantly go away when you turn the power off after its been on awhile? If so its the color wheel, If not its the cooling fan.
Sep 06, 2008 | Televison & Video
Loud increasing "ticks" during spin cycle
take the two screws out of the front bottom panel and fill the machine up with water then get a flashlight and turn to spin and if you look at the top of the transmission behind the motor watch for any water flying out it there is that is the cause of the problem if not you have a bad motor
Jan 27, 2008 | Amana NAV5800A Top Load Washer
Amana spin cycle
it sound like the motor is bad,
Dec 31, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud clicking during spin, won't spin full speed
manofred, you either have something in your pump or the coupler is starting to break up. Tip the washer back and take a look. See if there is a bunch of black debris under the trans. If so, your coupler is failing. The pump will come off with 2 clips and 2 clamps. Check to see if something is in the impeller. Check the attachments....Catriver...post back.
Feb 13, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Apple eMac G4 Desktop Logo
388 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
