Question about Compaq Presario Notebook
I have a presarion notebook V24oo USA I cannot get the poinetr mo
I did receive a notice that my computer was shutting down to protect iself.
  • mrninja
    mrninja May 11, 2010
    Did you get the infamous BLUE SCREEN? with or without an error code...chances are a driver went missing or got corrupt
  • Nasser Abou Agena
    Nasser Abou Agena May 11, 2010
    is it when go online or when you turn it on
Why do I have to go through the Start, Shut Down, process twice before my computer will shut down?
keeping it updated dont mean you dont have one when your computer dont shut down there is a parasite program keeping it on you need to check it, anti virus protection only protects against known viruses not one that has not been detected yet, once one is found then a program is made to fight and delete it, not before
Apr 07, 2010 | HP Compaq nc6220 Notebook
Laptop keeps on shutting down unexpectedley
If it shuts down randomly then you may have a virus. If you notice that it only shuts down when you hold it in your lap or on the bed then it means that it is overheating and you need to let air circulate in the area of the cooling fan. Also, if you recently "looked inside" the laptop and your forgot to put back a screw, that hardware device may disconnect itself and sending your laptop so a forced shutdown in order to protect itself.
Feb 16, 2010 | Acer Aspire 6920-6621 Notebook
I have a Compaq Presarion CQ60-249 USA notebook PC it turns on but the screen remains black
If the screen is always and completely dark, but the laptop works on an external monitor, then you have a faulty inverter.
The inverter is the high voltage board that supplies power to the backlight system, and it is often located at the base of the display.
If there is no picture on external display, then the prolem is often the motherboard.
Sep 10, 2009 | Compaq Presario Notebook
"protected"
First, disconnect all speaker wires from the unit and power it back up. If it does not go into protect. post a comment and I can walk you thru troubleshooting. If it goes into protect, it needs to be serviced.
Jun 24, 2009 | Sony STR-DE835 Receiver
Shuts down by itself
If there are no speakers connected and you still get the protection message, there is a problem internally. Exchange the unit while you can. The typical parts required to fix this problem will be over $75 US.
Dan
Mar 25, 2009 | Samsung Audio Players & Recorders
My kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Dec 03, 2008 | Kenwood KR-V7080 Receiver
Compaq Presarion C52TU
give me the details of the driver so i can give you the driver
Oct 27, 2008 | Compaq Presario 700 470024-192 Notebook
Green light flashing after shutting down computer to relocate office.
if its by the power button the led just indicates power after u have removed its source and reconnected it........this is normal nothing to worry about.
Sep 13, 2008 | Compaq Presario 5000 PC Desktop
Protect Mode
There are bad connections on the main board that are effected by heat. I would suspect that when the volume level is higher, the system shuts down sooner. This should be a simple repair that will not require parts. If you can solder, you should be able to repair this yourself. If not, the cost will be the local labor rate.
Dan
Jul 21, 2008 | Sony STR-DE345 Receiver
Compaq Presario Notebook Logo
43 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
