Question about Fisher Paykel EcoSmart GWL15
My washing machine over fills then begins the agitating cycle but the water continues to enter the machine until it comes over the top
  • Rick Schmiedl Aug 08, 2013
    I have a F&P Washer Model GWL15. Replaced the water inlet control valves. The machine fills with the right amount of water but when it should start the agitator, in the washing cycle, the motor never starts. I can manually advance to the rinse cycle but the motor will still not run. The water pump runs to drain the hopper. A beeping continues, one beep every second. I tried unplugging and restarting with same results. Could the motor be bad? Thank You.
  • 686 Answers
YOUR WATER PRESSURE SWITCH HOSE IS CLOGGED YOU NEED TO ACCESS THE INSIDE OF THE CONTROL PANEL AND LOOK FOR A CLEAR HOSE EITHER BLOW OR USE A SMALL BLAST OF COMPRESSED AIR TO CLEAR THE CLOG(15-20PSI MAX)
Posted on Apr 17, 2009
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
    Hello there:
    If your cycle does not complete or The cycle doesn't advance
    When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
    Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
    No water during any cycle.
    if no water is coming in how is it agitating?is it filling at the beginning,then it starts to wash the clothes,now does it drain and then it won't fill again,send the model number and more info,
    Jul 02, 2010 | Kenmore 24032\24036 Top Load Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer keeps filling w/ water, only stops when changed to spin
    Your drain line is too low.
    OR the drain line is restricting air where it enters the drain stand pipe.
    Remove the drain line and hold it up high.
    Turn the washer on to fill. It should fill then stop.
    This example should explain what you must do to correct the drain line problem.
    Mar 12, 2009 | Whirlpool Washing Machines
    GE washing machine does not run, gives humming noise
    A washing machine is a simple product.
    When trouble shooting anything you have to know what is supposed to do and what is it not doing.
    At the begining of a washing machine cycle the machine fills with water until a switch is made telling the machine it is full and ready to agitate. Since it never fills it will stick in that part of the cycle.
    When you start a cycle and no water enters the drum you have one of three problems:
    1. The water supply is shut off.
    2. The solenoid valve that supplies the water is not opening.
    3. No power to the washing machine.
    Since you are hearing a hum, the machine seems to be trying to activate that valve,
    The humming noise comes from the electromagnetic field that activates the valve,
    Dec 04, 2008 | Washing Machines
    Washing machine fills, but won't agitate
    maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
    Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
    Whirlpool AWO3761 stuck mid-cycle
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Fisher Paykel EcoSmart GWL15 Logo
    115 people viewed this question
    Top Fisher Washing Machines Experts
    Dan Webster
    Dan Webster
    dweatherby
    Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
