Philips tv for repair
Tv works for 5-10 mins then goes off and red standby light fashes
  • Anonymous Dec 18, 2007
    The color red does not work. Red standby light is flashing.
  • Anonymous Mar 14, 2014
    222222 appears on my Philips Tv screen and even I tried to put the tv in Tv mode the standby lights
The problem lost contact the jungle ic, if not working replace the jungle ic
Posted on Sep 18, 2007
  • 398 Answers
I have seen this happen on some of the newer Philips sets. If the screen voltage on the flyback transformer is set just a bit too low, the picture tube must be driven harder to produce a good picture. The circuits sense that the picture tube is being driven too hard and triggers the microprocessor to shut the set down. The first thing to try is to raise the screen voltage just a bit and see if the set still shuts down.
    Problem Solver:
  • 14 Answers
The TV is going into 'protect' mode- it is shutting down because the micro has detected a fault condition. There is a bad solder joint in the power supply section OR the VERTICAL IC has bad solder also. I would resolder the vertical IC first - that will solve 50% of these shutdowns. Good luck, Johnno
    An expert who has answered 500 questions.
  • 556 Answers
As you say that it works for 5-10 minutes it clearly indicates that all parts are 100% ok. problem is loose contact mostly in power supply& IF IT IS OK then loose contact in horizontal section. Good luck.
Posted on Sep 17, 2007
Why is my screen red when it should be black?
Search Results
    Philips Magnavox 8p6031c Crt Lens Fluid Repair Questions ...
    Recent Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & answers. Free expert ... Philips flat screen tv, Red flashing light. Light.
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Repair ...
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & fixes. ... My son accidentally spilled water on our Philips tv and when i turned it on ... I need a screen replacement of philips tv 60" ... Why the tv come on but a min after the red blinking come on an it turn off by it self what the problem?
    Magnavox Projection TV problem... ' Techlore
Jan 13, 2016 | Philips Magnavox 8p6031c Crt Lens Fluid...
Tv flashes red then shuts itself off after only on for 3 min
I have not repaired this particular model. But sometimes there is an IC they refer to as a standby IC. It may also be known as a controller IC. I call it the powerline regulator. And in one case the older Sony Projection TV had an audio output IC with a standby built into this IC. So,this advice is refering to a standby IC. And this IC may be in another form already mentioned. Please visit a Sony Tech. The work inside a projection TV is very complicated, you will need to see the specialist. Give them this note and go from here. Let me know how they handle the repair.Thanks for asking and good luck!
Aug 02, 2010 | Sony KP-65WS500 65" Rear Projection...
13 blinks on standby light
If you can post a few pictures of the boards in the unit to our forum at: Our techs will look over the boards and offer information to guide you in the repair.
I hope this helps, if so please rate our solution.
Corporate Computer
Mar 13, 2010 | Sony KDL-40XBR4 40 in. LCD HDTV
On my philips tv the red standby light is flashing
hola,tengo un reproductor de musica y a estado parado un tiempo,y ahora al enchufarlo se le enciende la luz de standby en rojo y no en verde como deveria ser.a que es devido este problema?1 saludo y gracias
Oct 21, 2009 | Philips 32PW6506 32" TV
13 red flashing standby lights tv turns on, then off
Seek professional serv technician. No listing for 13 fashes only up to 9.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
hi, i have read somewhere that you need to replace both 100u / 25 caps aswell.
the info came from a user on here called PaleFace but i cannot find the original post now and i have the same problem with my tv.
Jul 24, 2008 | Philips 37FD9954 37 in. HD-Ready Plasma...
TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
Mar 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Red light fashes 6 times
Six blinks=no horizontal (H STOP), no raster, goes to the blinking self diagnosis function immediately. check the horizontal circuits, not sure what the repair will cost you.
you can try this to reset the tv to manufacturer defaults, but there is no guarantee it will clear the problem. to do this, with the tv in standby, quickly press "display", channel "5", volume "+", then power. once the service menu is up, press 8 and then enter, and lastly the power button.
this should reset to factory defaults. once again, no guarantee this will help, but the no horizontal (h-stop) diagnosis should give you something to ask the repair techs about over the phone to get a rough estimate of repair cost.
Nov 17, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KV-32HX15U Flashing standby light
Hi. Thats a nice tv you have there. If your able to get free estimate from repair shop go for it. It could only be dry joints but it could be loptx & other components which could be pricey.
Sep 23, 2007 | Televison & Video
Red light flashing on tv
My 37" TV Will not yurn on . The green light goes on for 2 seconds then goes off and red light starts flashing. What Repair/Part is needed.
Aug 31, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
